RV10 Trim Tab Cable Anchor Brackets
zackrv8(at)verizon.net
PostPosted: Sat Jan 07, 2006 6:58 pm    Post subject: RV10 Trim Tab Cable Anchor Brackets Reply with quote
Guys,
  Dave will sell the Trim Tab Cable Anchor Bracket (replacement for the WD-415 that is supplied with the kit) for $15 a piece.  I have installed these brackets on my Rv10 kit.  Dave is an engineer and told me that these brackets are 3 times stronger than the steel weldment that Vans supplies in the kit.  It also has more threads to grab the trim tab cable.  It has a wider "footprint" than Vans weldment yet it still clears the Trim Tab cover plate doubler with no problem.  4 holes are pre drilled.  Very easy to install.  Made of 6061 aluminum.
  If you want a set, please call Dave at 302-437-6087.  He can answer all your questions.
Zack
#40512
rvbuilder(at)sausen.net
PostPosted: Sun Jan 08, 2006 7:47 am    Post subject: RV10 Trim Tab Cable Anchor Brackets Reply with quote
Do the four holes match the original four holes or will we need new cover plates if already drilled?
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Joseph Czachorowski
Sent: Saturday, January 07, 2006 8:59 PM
To: RV10-List(at)matronics.com
Subject: RV10-List: RV10 Trim Tab Cable Anchor Brackets
carl.froehlich(at)cox.net
PostPosted: Sun Jan 08, 2006 9:37 am    Post subject: RV10 Trim Tab Cable Anchor Brackets Reply with quote
I just got 4 for my project and a neighbors.  Nice work.
Carl
RV-10 # 40528
RV-8A (220 hrs).
