		mshimei(at)bellsouth.net Guest
				 Posted: Thu May 22, 2008 4:07 am    Post subject: 4 stroke in a kolb |
				I  have been working on a Generac conversion for my Ultrastar for several months now. I had to rebuild the cage and am working on a motor mount to use a direct drive version that hand props to start. There is one currently flying in a thunder gull in Illinois with 30+ hours now. The engine will weigh the same as the Cuyuna that was removed with 5 more Hp. I would have more progress,but I am taking care of a sick parent(who wants to see my lawnmower engine plane fly). Mark in Florida.
		Dana
				 Posted: Thu May 22, 2008 5:34 pm    Post subject: 4 stroke in a kolb |
				At 08:06 AM 5/22/2008, Mark wrote:
   	  | Quote: | 	 		  | I  have been working on a Generac conversion for my Ultrastar for several months now. I had to rebuild the cage and am working on a motor mount to use a direct drive version that hand props to start. There is one currently flying in a thunder gull in Illinois with 30+ hours now. The engine will weigh the same as the Cuyuna that was removed with 5 more Hp.... |
  Same weight as the Cuyuna?  I though the Generac conversion was around 120 lbs, isn't it?  The Cuyuna is 69 without the redrive.  If it's really that light it could be a great engine for that class of aircraft.
  Any pictures?
  -Dana
   "A government that robs Peter to pay Paul can always depend upon the support of Paul."-- George Bernard Shaw    [quote][b]
		ulflyer(at)verizon.net Guest
				 Posted: Thu May 22, 2008 5:40 pm    Post subject: 4 stroke in a kolb |
				Hi Mark,
  Interesting project.  Question - did your Cuyuna have any type of reduction drive - belt, gear box, etc.
  Problem is to get the HP your have to turn RPM - turning a prop that fast normally reduces its efficiency.  Like to hear more, good or bad as you progress.  I hope this works for you.  I used to have a FireFly, now I  presently have a Hawk flying and Gull under slooow construction.  Looking for more fuel efficient engine.
  jerb
  At 07:06 AM 5/22/2008, you wrote:
  [quote]I  have been working on a Generac conversion for my Ultrastar for several months now. I had to rebuild the cage and am working on a motor mount to use a direct drive version that hand props to start. There is one currently flying in a thunder gull in Illinois with 30+ hours now. The engine will weigh the same as the Cuyuna that was removed with 5 more Hp. I would have more progress,but I am taking care of a sick parent(who wants to see my lawnmower engine plane fly). Mark in Florida.
		customersupport(at)tnkolb Guest
				 Posted: Fri May 23, 2008 4:52 am    Post subject: 4 stroke in a kolb |
				MARK PLEASE KEEP US POSTED ,SOUNDS  INTERESTING,  TRAVIS.
  [quote]   ---
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Fri May 23, 2008 7:14 am    Post subject: Re: 4 stroke in a kolb |
				The Cuyuna UL-202 weighs 58 lbs and the Cuyuna 430 weighs 65 lbs without the prop/redrive
 I would be very interested in this conversion if it was in the under 100 lbs category for my own UltraStar.
 I think that puts it outside the Part 103 Ultralight category.
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
				 Posted: Mon May 26, 2008 6:59 pm    Post subject: 4 stroke in a kolb |
 more Hp. I would have more progress, but I am taking care of a sick
 parent (who wants to see my lawnmower engine plane fly). Mark in Florida.
 The Cuyuna has a 2;1 belt reduction,exhaust,intake ,pullstart,and carb.No prop. Total weight is 81lbs.
  Valley engineering has a prototype that is down to 78lbs with prop, and 200# thrust. But their ignition is run on a battery. I am trying to use the existing mag setup AND make a hub with a thrust bearing as to not wear out the case. We are also thinking of putting it on my friends Firefly that has 630hrs on the 447(1 decarb) and is looking for something else to try besides the ˝ VW.
 Did a lot of work on the airframe today,lot of TIG welding….Mark
