Tough to set rudder rivet
daveleikam(at)wi.rr.com
PostPosted: Mon Feb 27, 2006 3:29 pm    Post subject: Tough to set rudder rivet Reply with quote
Probably an old question from a new -10 builder.  How do you squeeze or set the rivet on the lower right side of the rudder (You know the one).  I am considering using a blind rivet on both sides.  Anyone?  Thanks!
Dave Leikam
#40496
indigoonlatigo(at)msn.com
PostPosted: Mon Feb 27, 2006 3:48 pm    Post subject: Tough to set rudder rivet Reply with quote
Left a red piece of tape over the hole waiting for someone to make a good
sugggestion before I use a blind rivet also.
I even back tracked thnking that these could have been riveted out of
sequence but that wouldn't have worked either.
Waiting!
JG. 409
CC: <daveleikam(at)wi.rr.com>
Subject: Tough to set rudder rivet
Date: Mon, 27 Feb 2006 17:27:36 -0600
Dave Leikam
#40496
seipel(at)seznam.cz
PostPosted: Mon Feb 27, 2006 4:04 pm    Post subject: Tough to set rudder rivet Reply with quote
I used a MK319BS.
PJ
#40032
Thanks!
Dave Leikam
#40496
jeff(at)westcottpress.com
PostPosted: Mon Feb 27, 2006 4:09 pm    Post subject: Tough to set rudder rivet Reply with quote
Hi Dave,
There are a few approaches that work.  I took some meat out of the center of a bucking bar, leaving about a 3/16" thick surface on either side that I could slide in between the rib flanges... allowing me to buck the rivet (my tech counselor was quite impressed).  I'd take a picture of it to show you but it's on loan to another builder.
Avery also sells a yoke with a tapered head that will work... but you're looking at $85.00.
Jeff Carpenter
40304
Wings/Forward Leading Edge
Dave Leikam
#40496
Eric_Kallio
PostPosted: Mon Feb 27, 2006 5:17 pm    Post subject: Re: Tough to set rudder rivet Reply with quote
Dave, I was shown how to use a thin nose yoke that was ground down a fraction of an inch. Using this I was able to squeeze the first rivet without a problem. For the other side it took two of us, one to squeeze the rivet and one to flex the spar just a hair. I was able to get the very edge of the yoke in the gap and used the edge of a wide flush set on the manufactured head. I would squeeze the rivet a hair and as it set I was able to get the yoke farther in the gap, until I was able to fully set the rivet. Sounds more painful than it was. The hard part will be finding the yoke.
Eric Kallio
40518
Tailcone
wcurtis(at)core.com
PostPosted: Tue Feb 28, 2006 11:16 am    Post subject: Tough to set rudder rivet Reply with quote
[quote]How do you squeeze or set the rivet on the lower right side of >the rudder (You know the one). >... > >Dave Leikam >#40496 Used the 15000 bucking bar at the below link: http://www.yardstore.com/index.cfm?action=ViewDetails&ItemID=380&Category=74 The small pointed end is great for tight spaces. William Curtis http://wcurtis.nerv10.com/
PostPosted: Tue Feb 28, 2006 12:44 pm    Post subject: Tough to set rudder rivet Reply with quote
That bar, without some modification, will not fit that space.
Jeff Carpenter
40304
>Dave Leikam
>#40496
William Curtis
