alternator problems
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
lawrencesalerno(at)sbcglo
PostPosted: Sat Jul 12, 2008 6:58 am    Post subject: alternator problems Reply with quote
Just a note about a problem Iam having with my alternator. I am showing a voltage surge, from 12.5 to 16.0, it is regular every 1 to 2 seconds, any thoughts on what to look for first. Any help would be appreciated. Thanks RV6A, 67MK, Larry Salerno [quote][b]
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
John Brunke
PostPosted: Sat Jul 12, 2008 7:40 am    Post subject: alternator problems Reply with quote
Sounds like it could be the voltage regulator. I had one go on my -6. It caused some damage before I could get everything shut off. An overvoltage circuit from B&C would have prevented the spike to my components.
One was installed shortly after.
It was just a bad regulator.
ghfrost(at)earthlink.net
PostPosted: Sat Jul 12, 2008 9:40 am    Post subject: alternator problems Reply with quote
Larry,
I do not know if this applies to you but I have a Nippondenso (Toyota automotive) alternator in my RV-6. While in NM visiting with my son my alternator started behaving similarly to yours. I can't recall how high it surged past 14 but it disturbed me enough re: toasting the battery that I called Van's. They said it was likely the voltage regulator and that it would probably be OK for the trip home to OH. Fortunately I went to the NAPA store and bought a new part anyhow, for installation install when home.
On the way to Borger TX, I dealt with the surges by turning the alternator field off and on until it finally did not come back on. When turned on it would go to normal charge and then creep up again. At Borger, with no charge I had to install the new part. No A&P to borrow tools from but a friendly guy came by with a pickup and loaned me what I needed to install the new voltage regulator. There are 3 terminals and 2 wires which I thought were connected properly. Not so. So I turned off most electrical stuff. By Guthrie OK, with low battery and no radio, I selected the non controlled field with several A&Ps, but all working on rush jobs, but they loaned me tools so I could finally get the wires right. Guthrie had friendly people, a courtesy car, a nearby motel and barbecue restaurant. Since the new voltage regulator went on I have had no further alternator problem.
George
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronics.com/Navigator?RV6-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
