toaster73(at)embarqmail.c Guest
Posted: Mon Aug 18, 2008 3:55 pm Post subject: Van's Experimental IO-540 |
Wondered if anyone could tell me what all comes with a Van's experimental IO-540 engine. I am probably going to take the plunge before end of the month with the "sale" price.
What I am interested in is any type of paper work or user manuals, break-in procedure etc. etc.
Also does anyone have the specs on the magnetos, engine fuel pump, starter, etc...those items actually included with the engine. And can any of these items be switched out or left off?
Chris Lucas
#40072 Finishing...hah!
GenGrumpy(at)AOL.COM Guest
Posted: Mon Aug 18, 2008 4:19 pm Post subject: Van's Experimental IO-540 |
In case you haven't called them, you should get engine log and owner's manual plus break-in procedures. I suspect you will get mags unless you specify otherwise. Fuel pump is part of the engine. Starter is separate. Best bet is to call them and talk direct.
grumpy N184Jm
In a message dated 8/18/2008 6:57:57 P.M. Central Daylight Time, toaster73(at)embarqmail.com writes:
| Quote: | Wondered if anyone could tell me what all comes with a Van's experimental IO-540 engine. I am probably going to take the plunge before end of the month with the "sale" price.
Chris Lucas
="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
It's only a deal if it's where you want to go. Find your travel deal here.
DLIUDVINAITIS(at)aol.com Guest
Posted: Mon Aug 18, 2008 4:35 pm Post subject: Van's Experimental IO-540 |
CHRIS,
I RECIEVED MY 540 LAST MONTH, YOU WILL RECIEVE A 1HR ENGIN RUN UP TEST LOG (ENGIN READY TO MOUNT AND FIRE UP) , MANUALS, ENGIN LOG, MAGS OF COURSE, AS FOR THE STARTER I HAVE NOT UNPACKED ALL THE FOAM AROUND ENGIN.
DAVE LIUDVINAITIS
#40466, FUSELAGE, FIBERGLASING, DOORS
Chris Lucas
Kellym
Posted: Mon Aug 18, 2008 4:45 pm Post subject: Van's Experimental IO-540 |
Of course you don't really want those Slick mags right now that require
immediate servicing to correct the recently discussed problems. If there
isn't a starter, that would give you the chance to choose which flavor
you like.
DLIUDVINAITIS(at)aol.com wrote:
| Quote: | CHRIS,
ENGIN.
DAVE LIUDVINAITIS
Chris Lucas
KCHD |
carl.froehlich(at)cox.net Guest
Posted: Mon Aug 18, 2008 5:52 pm Post subject: Van's Experimental IO-540 |
What sale?
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Sent: Monday, August 18, 2008 7:54 PM
Subject: Van's Experimental IO-540
Chris Lucas
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
pascal(at)rv10builder.net Guest
Posted: Mon Aug 18, 2008 6:11 pm Post subject: Van's Experimental IO-540 |
www.Vanaircraft.com
go to bottom of page there is a sale on a certain amount of engines.
Pascal
Sent: Monday, August 18, 2008 6:50 PM
Subject: RE: Van's Experimental IO-540
What sale?
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Chris Lucas
0 [quote][b]
Posted: Mon Aug 18, 2008 6:12 pm Post subject: Van's Experimental IO-540 |
Go to vans website...they have an offer going on their engine deal with Lycoming
Posted: Mon Aug 18, 2008 6:38 pm Post subject: Van's Experimental IO-540 |
The sale is until end of month, it says 11 engines at that price, but they will sell any amount of engines at the sale price until 8/30 I was told.
-Chris
