Which O-320 to replace my O-290?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
carlosh(at)structuralaz.c
PostPosted: Mon Oct 06, 2008 1:31 pm    Post subject: Which O-320 to replace my O-290? Reply with quote
Hello,
Well after starting my condition inspection on our PL-1 this weekend, we
found that 3 of the 4 jugs are below 60/80 on the compression test. We
have an 125 hp O-290-G on a conical mount and a fixed pitch prop. We
would like to replace this engine with a 150 hp O-320-XXX. We're looking
to keep this as simple as possible so we want to do a replacement
without redoing the mount, cowling and baffles if possible. I am not an
engine guy but I have done a little reading in the types of 320's out
there, but there is entirely to much information for me to understand
with out some direction from others that know a lot more than me.
Thank for your help!
Carlos in Arizona
Carlos Hernandez <carlosh(at)sec-engr.com>
Structural Engineers Company
2963 W. Elliot Rd. - Suite 3
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
CONFIDENTIALITY NOTICE
The information in this email may be confidential and/or privileged.
This email is intended to be reviewed by only the individual or
organization named above. If you are not the intended recipient or
an authorized representative of the intended recipient, you are hereby
notified that any review, dissemination or copyingof this email and
its attachments, if any, or the information contained herein is
prohibited. If you havereceived this email in error, please
immediately notify the sender by return email and delete this email
from your system.
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
wturansky(at)cox.net
PostPosted: Mon Oct 06, 2008 3:33 pm    Post subject: Which O-320 to replace my O-290? Reply with quote
Carlos,
I'm interested in an O-290 for an upgrade to my 7ECA Champ. If you
decide to replace your engine and want to sell your O-290 please give me
a call. I'm local, my plane is at CHD. My number is 480.326.2172.
Walt
Carlos Hernandez wrote:
<carlosh(at)structuralaz.com>
Hello,
we found that 3 of the 4 jugs are below 60/80 on the compression test.
We have an 125 hp O-290-G on a conical mount and a fixed pitch prop.
We would like to replace this engine with a 150 hp O-320-XXX. We're
looking to keep this as simple as possible so we want to do a
replacement without redoing the mount, cowling and baffles if
possible. I am not an engine guy but I have done a little reading in
the types of 320's out there, but there is entirely to much
information for me to understand with out some direction from others
Carlos in Arizona
mike109g6(at)insideconnec
PostPosted: Mon Oct 06, 2008 3:34 pm    Post subject: Which O-320 to replace my O-290? Reply with quote
Carlos,
I have a 0-320B1A 160HP conical mount 0TSOH with accessories, set up for C/S
prop with governor. If interested email me offline at:
mike109g6(at)insideconnect.net.
Mike H 9A/8A
ideaz1(at)sbcglobal.net
PostPosted: Mon Oct 06, 2008 5:03 pm    Post subject: Which O-320 to replace my O-290? Reply with quote
Here's the Lycoming page with all the O-320 specs so you can find the best
match for your needs.
http://www.lycoming.textron.com/engines/series/pdfs/320ci%20Engine%20Insert.pdf
Dirk Z Carson City Nv
Hello,
have an 125 hp O-290-G on a conical mount and a fixed pitch prop. We would
like to replace this engine with a 150 hp O-320-XXX. We're looking to keep
this as simple as possible so we want to do a replacement without redoing
the mount, cowling and baffles if possible. I am not an engine guy but I
have done a little reading in the types of 320's out there, but there is
entirely to much information for me to understand with out some direction
Carlos in Arizona
PostPosted: Mon Oct 06, 2008 8:19 pm    Post subject: Which O-320 to replace my O-290? Reply with quote
Thank you for that Dirk. At least know I know which o320 can use conical
mounts.
Dirk Zahtilla wrote:
<ideaz1(at)sbcglobal.net>
best match for your needs.
> Hello,
> test. We have an 125 hp O-290-G on a conical mount and a fixed pitch
> prop. We would like to replace this engine with a 150 hp O-320-XXX.
> We're looking to keep this as simple as possible so we want to do a
> Carlos in Arizona
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
