colleenandbrett(at)comcas Guest
Posted: Sat Oct 18, 2008 11:32 am Post subject: Installing the Vertical Fin on a RV-6AQ |
After installing the vertical fin on my RV-6AQ I find that the rear edge of the vertical fin is 3/16 - 1/4 inch forward of the rear edge of fuselage skins. I assuming that rear edge of the fuselage skins is to be trimmed to match that of vertical fin.
Is this correct? I have not found anything in the plans or instructions that addresses this.
Thanks.
Brett Herrick
Columbus, IN
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
webmaster(at)flion.com Guest
Posted: Sat Oct 18, 2008 12:05 pm Post subject: Installing the Vertical Fin on a RV-6AQ |
If your rear spar lines up with the rear bulkhead (it must, or how did you mount it?) then everything is fine. Trim the trailing edges to match. I waited until I fit the empennage fairing and then trimmed everything at once.
Patrick Kelley – RV-6A – 1st Engine start today!!
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of Colleen and Brett Herrick
Sent: Saturday, October 18, 2008 12:32 PM
To: rv6-list(at)matronics.com
Subject: Installing the Vertical Fin on a RV-6AQ
Thanks.
Brett Herrick
Columbus, IN
[quote] [b]
