RE: Was Constant Speed - I/O 390 engine performanc
pcondon(at)mitre.org
PostPosted: Mon Jan 09, 2006 8:28 am    Post subject: RE: Was Constant Speed - I/O 390 engine performanc Reply with quote
Does the extra 7 CID per cylinder yield 5% improvement in total ??? Or
is it more likely a new engine (proper compression and all that)is
responsible for the performance increase......
Is the I/O 390 an angle valve engine ? Was the 360 a parallel of angle
valve engine ??
Dana,
I put approximately 300 hours on the IO360 before converting to the
IO390.
The IO390 added approximately 5% in all parameters.
Dick Martin
RV8 N233M
the fast one
