Question - Countersinking Wing Spar
sshook(at)cox.net
PostPosted: Sat Mar 11, 2006 7:17 am    Post subject: Question - Countersinking Wing Spar Reply with quote
I have come to the point where its time to CS the main spar and the #30 Countersink that is recommended by the plans seems to run out of blade before it makes the CS hole deep enough for the #8 screw.  My test piece that I am using is dimpled correctly.  I have the 3-blade CS set from Cleaveland.
PS) I already have made myself a pilot out of a scrap 1/8 aluminum stock.  That part works great
Any help would be appreciated.
Scott
N696JS – Wings
dan(at)rvproject.com
PostPosted: Sat Mar 11, 2006 7:50 am    Post subject: Question - Countersinking Wing Spar Reply with quote
Oh, also, get yourself a c-sink cutter with a larger diameter.  Sorry, I misread your question at first.  A larger diam cutter will fix the problem.
)_( Dan
Follow the instructions.  Rivet the nutplates first they will serve to center the pilot.
When I built mine I didn't trust that.  I could have.  I wasted all sorts of time using a backup strip with a pilot centering hole.  Worked fine but took too long.  Could have done it in less than half the time -- by (a) following the plans, and (b) using a ball bearing microstop cage rather than the cheap bushing version that came with my Avery kit (I upgraded to a ball bearing cage from Avery eventually).
)_( Dan
RV-7 N714D (833 hours)
http://www.rvproject.com
sshook(at)cox.net
PostPosted: Sat Mar 11, 2006 9:21 am    Post subject: Question - Countersinking Wing Spar Reply with quote
I have a 3/8 #40 pilot, 3/8 #30 pilot, a 7/16 #27 pilot and a 7/16 #19 pilot.  I moved up to the 7/16 #27 pilot but did not try it with the nutplate installed.  I just enlarged my homemade “tool” a bit to accommodate the pilot.
Scott
N696JS – Wings
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway
Sent: Saturday, March 11, 2006 8:50 AM
To: rv7-list(at)matronics.com
Subject: Re: Question - Countersinking Wing Spar
)_( Dan
sshook(at)cox.net
PostPosted: Sun Mar 12, 2006 4:06 pm    Post subject: Question - Countersinking Wing Spar Reply with quote
Thanks for the follow-up Dan.  Worked perfect!!  I rechecked my test dimple and the skin was slightly off.  I was able to complete both spars’ countersinks yesterday.
Sent: Saturday, March 11, 2006 8:49 AM
)_( Dan
