s.clive.richards(at)homec Guest
Posted: Sun Nov 23, 2008 3:19 am Post subject: 0-200 Starters |
Peter
I believe what you call the adapter is the outer race of the needle bearing if you go for a B & C starter you will need to pull this bearing out completely & press in a plug which is effectively the outer race with a sealing cap supplied with the starter kit to seal oil port.
Ray fitted a B & C starter to reduce weight in his HD but also the sprag clutch in the original starter was not very reliable as they wear out & I believe are expensive to replace.
Clive Richards
Rays G CBDG 601HD 265 Hrs
| - The Matronics Continental-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Sun Nov 23, 2008 4:04 am Post subject: Re: 0-200 Starters |
Your right about the clutch drive being expensive. I priced one locally and it came to $365.00. Now I am looking into a sky-tec starter that is lighter and slides right in at $512.00
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
vk3eka(at)bigpond.net.au Guest
Posted: Sun Nov 23, 2008 2:25 pm Post subject: 0-200 Starters |
Thanks Guys,
I'm beginning to think the sky-tec is the way to go.
Cheers
Peter.
