Trim Speed & Tail Wire Run
Tim(at)MyRV10.com
PostPosted: Mon Mar 13, 2006 3:14 pm    Post subject: Trim Speed & Tail Wire Run Reply with quote
I think the speed is just right during takeoff and landing and
I wouldn't want to slow it down any during those phases. I was
considering a switch to select high or low speed. Your idea
of doing it with the boost pump sounds pretty good, actually.
Conti, Rick wrote:
Flying RV-10s,
I have read that the trim motors run too fast for easy trim in level
flight. I have a speed controller I plan on wiring via a relay. The
speed controller will only be in the circuit when the fuel pump is off.
I want "regular" trim speed during the critical phases of flight
(takeoff & landing). However, do you think the speed is too fast even
for takeoff and landing? I have a second speed controller I can use if
that is the case.
Also - what wire routing did you use for your tail nav and strobes (if
any)? My concern is where to enter the empennage.
Thank You
Rick Conti
Senior Engineering Manager
The Boeing Company
office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
jesse(at)itecusa.org
PostPosted: Mon Mar 13, 2006 4:21 pm    Post subject: Trim Speed & Tail Wire Run Reply with quote
My dad has never said anything about the trim speed being too fast. He
seems very happy with it after 200 flying hours.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of
May. You may call me at 352-505-1899 and leave a message that I can check
from down here. Any I-TEC questions can be directed to the I-TEC office at
352-465-4545.
Tim(at)MyRV10.com
PostPosted: Mon Mar 13, 2006 4:48 pm    Post subject: Trim Speed & Tail Wire Run Reply with quote
It's not extreme if you just tap it. It actually isn't too bad. It's
just at high speed, it takes a bit of tapping back and forth sometimes
to get it just right. In addition, I had a spooky experience once where
a notebook on my lap laid on the trim switch for nose-up trim. It only
takes 1/2 second of the button being held down to give an EXTREME and
immediate pitch up, when you're at cruise speed. If you're flying
IFR and have charts, and stuff on your lap, you don't want anything
hitting that trim button. Slowing down the trim a bit ... only during
high speed operation, would not only make trimming it perfectly a
little more precise, but would add some safety as well. It does not
need to be slower at low speeds though...you'll want full speed trim
at lower airspeeds.
I don't think that this is necessarily a "gotta" do, but I think it's
probably a good idea. Test it for yourself. Fly along at 140 KTS
or so and hold the nose up trim for 1/2 second....then see what you
think. I also think that if someone has no worries at all about it
after doing the test, they should feel comfortable leaving it as-is.
It's another builder-preference item, as are most all of them.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545.
kmechols(at)yahoo.com
PostPosted: Mon Mar 13, 2006 8:43 pm    Post subject: Trim Speed & Tail Wire Run Reply with quote
I have no personal experience with this product but do find it interesting.
They suggest using a flap position sensor to determine high vs. low speed, but
it would seem easy to use your idea of the fuel pump switch too.
http://www.f1-rocketboy.com/tcm.html
-Kevin
> Flying RV-10s,
> that is the case.
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
rvbuilder(at)sausen.net
PostPosted: Tue Mar 14, 2006 4:01 am    Post subject: Trim Speed & Tail Wire Run Reply with quote
 I am going to use Aircraft Extra's trim speed adjustment.  It plugs into your pitot system and automatically switches speeds after a preset airspeed is reached.  http://www.aircraftextras.com/RelaySpeedCont1.htm
  I am also going to use their flap positioner as it will adjust the trim for you also.
http://www.aircraftextras.com/FPS-Plus.htm
Michael Sausen
RV-10 #352 Working on Fuselage
