speckter(at)comcast.net Guest
Posted: Sat Mar 18, 2006 6:15 am Post subject: Nose wheel mounting problem |
Quote: | I mounted the nose wheel in the fork and was not happy with the bearing situation. It appears to me that the wheel is spinning between the bearing and the center rod not rotating the bearings as it appears to be designed. Does anyone else have that problem.
In my thinking the outer sleves on each end should exert pressure inward to the bearing to hold it to the center shaft so that the rollers can indeed roll not slip between the inner race and the center rod.
This may not be very clear but if someone knows what my issue is and wants to call me feel free.
Gary Specketer
770-403-3450
40274
