RV ator
densing(at)carolina.rr.co
PostPosted: Mon Jan 09, 2006 6:11 am    Post subject: RV ator Reply with quote
To those subscribing to the THE RV ATOR, have you received the 6th and last
issue of 2005?
Dale Ensing
eanderson(at)carolina.rr.
PostPosted: Mon Jan 09, 2006 6:21 am    Post subject: RV ator Reply with quote
I have not as of this date, Dale
Ed Anderson
willfly(at)carolina.rr.co
PostPosted: Mon Jan 09, 2006 11:47 am    Post subject: RV ator Reply with quote
Hi Ed,
Mike Munn knows all about the AD and it depends on the serial number of the engine.
BTW after the story of your last adventure I decided a good nick name for you would be "Dusty". I started to LOL when you turned the air on. Oh well all is well that end well, even if you are Dusty.
See you in LAL my friend.
Cappy
PostPosted: Mon Jan 09, 2006 1:32 pm    Post subject: RV ator Reply with quote
Cappy, as long as I can provided "entertainment" with wear and tear limited
to seat cushions then all is well {:>). Went out today and glued down the
vinyl so should be ready to go. Weather permitting will see you there on
Friday.
Ed
