M-14P Not Flown in Three Years
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
peteairways
PostPosted: Sun Jan 25, 2009 12:43 pm    Post subject: M-14P Not Flown in Three Years Reply with quote
I recently put a deposit on a Yak-55M that has not flown in about 3-years. A condition inspection was just done on the aircraft. The engine was run and checked over per requirements of the condition inspection and given a good bill of health.
My question is this: Do I need to worry about any of the parts in the fuel system not working properly from sitting idle for 3-years?(ie auto-mixture, aneroids, valves in the fuel tanks etc.) Any advice on what I should look out for on the little used M-14 would be appreciated!
Thanks, Pete
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
doug(at)ripleyair.com
PostPosted: Mon Jan 26, 2009 4:58 am    Post subject: M-14P Not Flown in Three Years Reply with quote
Pete, I don't know the specifics on M-14s regarding this, but I do know that
if it had auto gas in the carb there is a potential problem with "varnish".
Not a problem if it had avgas in it.
george(at)gesoco.com
PostPosted: Mon Jan 26, 2009 6:25 am    Post subject: M-14P Not Flown in Three Years Reply with quote
You may experience some oil leaks at some point. The only other issues may
be high oil consumption due to corrosion in the cylinders. The more
important issues are the hoses and things like that.
George Coy
Coy Aircraft Sales
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
SKYPE george.coy
mark.bitterlich(at)navy.m
PostPosted: Mon Jan 26, 2009 12:35 pm    Post subject: M-14P Not Flown in Three Years Reply with quote
Pay particular attention to the fuel vents and make sure they are not
clogged with ANYTHING. Especially little bugs that build nests in tiny
little openings, which happened to me when my 50 sat for just one week
at Kissimmee Florida. Other than that, other folks covered all the
really important stuff, like hoses and varnish. Some 55's also did not
come with a stock air system. Some had them added, modified, etc. etc.
That said, you should consider pulling your air tank, and have it
inspected for internal corrosion and then have it pressure checked.
Make several taxi checks and make sure your brakes are freaking perfect.
A brake issue in a tail dragger is bad juju, especially a high
performance version.
Good luck... Great airplane.
Mark Bitterlich
N50YK
mikspin
PostPosted: Fri Jan 30, 2009 7:00 pm    Post subject: Re: M-14P Not Flown in Three Years Reply with quote
Pete,
Can you contact me off list? Thanks
Mike Hastings
acromike(at)gmail.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
