		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Thu Feb 05, 2009 7:08 am    Post subject: Installing Door Windows |
				The instructions call for installing the windows in the doors while the doors are not on the plane.  While it might be easier that way, I am wondering if there would be any advantage of bonding the windows while the doors are on the plane, locked closed.
 My thoughts are that it might be possible to induce a small amount of twisting/distortion when bonded off the plane, vs being bonded on the plane.
 Thoughts would be appreciated.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		pascal(at)rv10builder.net Guest
				 Posted: Thu Feb 05, 2009 7:32 am    Post subject: Installing Door Windows |
				If you're using Weld-on, the stuff runs.. it is MUCH easier to do it on a
 table than the plane.
 I did it on a table and there was no issue. I would suggest putting the
 Weld-on while flat, let it sit (after all the tape is removed) than put it
 on the plane after 2 hours, and lock it down, not needed but that would be
 be better than the mess that would occur from the weld-on dripping down the
 door.
 Sent: Thursday, February 05, 2009 7:08 AM
 Subject: Installing Door Windows
  plane.
  Gary Blankenbiller
  RV10 - # 40674
  Engine, Fiberglass - SB
  (N2GB registered)
  http://forums.matronics.com/viewtopic.php?p 28643#228643
		drfred(at)suddenlinkmail. Guest
				 Posted: Thu Feb 05, 2009 7:33 am    Post subject: Installing Door Windows |
				orchidman wrote:
  Gary Blankenbiller
  RV10 - # 40674
  (N2GB registered)
 Much easier to do off the plane.  Any small twist will be taken care of
 by the hours of filling and sanding at time of final prep for paint.
 Dr Fred.
