Vor Antenna
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
peter(at)mather.com
PostPosted: Tue Feb 24, 2009 6:39 am    Post subject: Vor Antenna Reply with quote
Hi all
After a long, cold (by UK standards) winter when it was too expensive to heat the workshop, the weather has improved and building can restart. Over the winter I've been pondering the panel/avionics and have just largely completed the final panel layout and wiring (www.tailwindbuild.blogspot.com). Originally I wasn't going to install a Nav radio but just picked up a Garmin SL-30 cheap so am intending to use that. This means I need to locate a VOR antenna so I'm interested in ideas for choosing and locating a VOR antenna in my build. In my Vans, which has metal wings but fibreglass tips, I've installed a Bob Archer antenna inside the wingtip which works very well. As I understand it these rely on using the wing as a ground plane. Obviously this won't work on the Tailwind. The easy solution is to put a normal V antenna on the VS but that means a lot of wire back to the panel and more drag. Has anyone used any sort of internal antenna, either wing or fuselage mounted successfully? Details would be appreciated.
Peter
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
owenld(at)earthlink.net
PostPosted: Tue Feb 24, 2009 10:22 am    Post subject: Vor Antenna Reply with quote
Peter
When I built N171E I put an antenna on the VS and one inside of the wing. Both worked fine but the one in the wing was weaker when the station was on the opposite side from the antenna. I finally used only the one on the VS. I probably oriented the antenna wires forward but can't remember for sure. I test flew N171E in 1978 so don't remember that detail.
Lou Owen
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
