naumuk(at)windstream.net Guest
Posted: Sun Mar 08, 2009 12:21 pm Post subject: D-100 |
All-
Has anyone successfully had-wired a D-100? If so, please contact me off list.
Do not archieve
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
Posted: Sun Mar 08, 2009 1:19 pm Post subject: D-100 |
Sabrina-
I'm trying to wire the harness from scratch using B+C components. I'm
unsure of the schematic. I could really use a reverse-engineered diagram of
the Stein cable.
Bill
jaybannist(at)cs.com Guest
Posted: Sun Mar 08, 2009 1:34 pm Post subject: D-100 |
Bill,
Do you have the Dynon Installation Guide? The diagrams for both cables and connectors are all laid out there.
Jay
Posted: Sun Mar 08, 2009 1:53 pm Post subject: D-100 |
Jay-
Yes, but they're written in Greek.
I just found out I could by a pre-made cable for what I paid for the components. Live, get kicked in the butt, and learn.
Of course, if you can read Greek, I'll send you the appropriate scans. I'm lost.
Bill
Posted: Mon Mar 09, 2009 2:05 pm Post subject: D-100 |
Sabrina-
No, you wouldn't. When I decided to go with the B+C kit (at) $72.50, it was
a deal because pre-made cables were $150. Now you can get the pre-made
cables for $79.95. Not worth the trouble.
Bill
Posted: Mon Mar 09, 2009 3:49 pm Post subject: D-100 |
Sabrina-
I have a D-100.
Bill
Posted: Mon Mar 09, 2009 3:54 pm Post subject: D-100 |
Sabrina-
I now realize you were talking about the remote compass, rather than a
D-10/D-100. Another lister said you could mount the remote comass forward.
I'll see how that works but have a backup plan.
Bill
Posted: Mon Mar 09, 2009 4:39 pm Post subject: D-100 |
You can also mount compass sensors in the wing tip.
-- Craig
Posted: Tue Mar 10, 2009 2:18 pm Post subject: D-100 |
Craig-
Yeah, if you're 4 inches tall and can duck under the (Riveted) skin!!
Bill
Posted: Tue Mar 10, 2009 9:55 pm Post subject: D-100 |
Craig-
After staring at the wings in my basement, a wing mount is still
possible because I haven't riveted my fiberglass tips yet. After running a
whiskey compass around my airframe I agree, you probably can't find a better
location. Good idea- thanks.
Bill
Posted: Tue Mar 10, 2009 10:18 pm Post subject: D-100 |
Just be aware of possible interference from the wires to the strobe (if you
have any).
The wings of my first XL were also closed when I bought it. The tip was
accessible but I was worried about retaining the wires running back to the
wing root through the lightning holes. I thought about clamping some
lightweight tube at both ends (and possibly in the middle through an
inspection hole) but never implemented the idea. Have you thought of a
solution?
-- Craig
Posted: Wed Mar 11, 2009 2:40 pm Post subject: D-100 |
Craig-
1. I have a belly strobe rather than tip strobes.
2. If I do go with the wing installation, I'll restrain where I can and
add additional shrink wrap on the outside of the cable to those areas of
possible abrasion.
I had a plan B until I mounted my solenoid on the tray I put in mounted
behind the seats. I could move the solenoid, but then I'll eventually be
installing the access steps and that will probably screw things up. I could
solve the problem by eliminate putting on the access steps yada, yada, yada.
If the remote compass isn't happy in the starboard outboard wing, it's
not going to work.
Bill
