RV10-List VANS IO-540-D4A5 Lycoming and Crank SB/AD
pcondon(at)mitre.org
PostPosted: Wed Mar 22, 2006 7:13 am    Post subject: RV10-List VANS IO-540-D4A5 Lycoming and Crank SB/AD Reply with quote
Someone posted yesterday that their (or all) of VANS IO-540-D4A5 are
NOT subject to this action. A word of caution here....the Lycoming
SB/AD DOES mention the IO-540-D4A5 as a possible candidate for the
Crank problem. Read the front of the SB/AD, check the number on the
crank flange and the serial number to verify. Of course, if a rebuilt
engine was done within the time frame indicated by the SB/AD then
further investigation is warranted (shop records, part ids, repair
billing records, assembly records & log book entries). Total Lycoming
bulletin is on Mikes website (Thanks Mike)
http://www.mstewart.net/deletesoon/sb569.pdf
