IO-360 conversion to carb
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
tompkinsl(at)integra.net
PostPosted: Thu Mar 12, 2009 11:12 am    Post subject: IO-360 conversion to carb Reply with quote
I was not considering this swap, it has already been done on a flying kit plane that is now for sale. TTAF & E is over 300 hrs.
My question was seeking input on issues to consider other than the carb icing issue that I mentioned. If it still has 8.7:1 pistons as represented, then it probably makes a little more than 180 HP but less than a FI engine since the FI engine, at least theoretically has more even fuel distribution. For the same reason, I would predict that the carbed version would have slighly poorer fuel economy.
My question is really whether to live with it (as someone has for 300+ hrs.) if the alteration is reflected in the price or if the alteration should be viewed as something that absolutely has to be reversed.
I apologize for not making a more detailed post in the first place. Hopefully, this post is clear enough that you don't need to do any mind reading.
Larry
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
