		experimentalab(at)yahoo.c Guest
				 Posted: Mon Mar 16, 2009 7:21 pm    Post subject: 582 Thermostat/Bungee wraps... |
				Hello all,
  Haven't posted in several years, as my recreational flying has been sporadic at best, but I'm looking to get a few more hours under my belt as available work continues to slide...I'm flying a Model 3 behind a grayhead 582, C-box and 3-blade GSC.
  I just replaced the bungees through Kitfox Aircraft, and they told me 4-5 wraps would be sufficient. Well I nearly lost a few digits, but I was able to get four wraps out of the new bungees...Now the old bungees were wrapped 5 or 6 times around each, and there was plenty of play...Now after a good taxi-test, both new bungees seem to have settled with about an inch gap between the bottom of the fuselage and the gear bar. Is that about right, because I can't imagine how to get another wrap out of them!
  Also, as I was taxiing out the other day I noticed the water temp and CHT's rising slightly higher than normal...pulled off and shutdown to find the radiator cool to the touch. My best guess is that the thermostat is sticky after several months of sitting. I'd rather not drop $150 on a new one ouch...any ideas on where I could find a more cost-effective part?
  Thanks!
 Andrew
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		akflyer
				 Posted: Mon Mar 16, 2009 7:58 pm    Post subject: Re: 582 Thermostat/Bungee wraps... |
				OMC 3853799
 I bought mine at Napa.. I think it was 6.29
 if they are sagging that much, you need to get a buddy to help and get more wraps on it.
  _________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
		gary.algate(at)sandvik.co Guest
				 Posted: Mon Mar 16, 2009 8:19 pm    Post subject: 582 Thermostat/Bungee wraps... |
				I seem to recall that the genuine Rotax thermostat has an internal by-pass in the event of diaphragm failure. You might want to look into this a little more closely.
 When I used to wrap my bungees it was a two man job. Inside the cabin I use a long screwdriver with the tip bent at 90 deg to reach down and pull up and stretch the bungee. The person underneath would assist. i could easily get 5 to 6 wraps with this method.
  Regards.
  Gary Algate
  GPLM Exploration
  Direct Ph: +61 (0)88179 5032
  Office Ph: +61 (0)88276 7655
  Cell Ph: +61 (0) 417 975 584
  This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
 "akflyer" <akflyer_2000(at)yahoo.com>
 Sent by: owner-kitfox-list-server(at)matronics.com
 17/03/2009 02:39 PM
 Please respond to
  kitfox-list(at)matronics.com     To
  kitfox-list(at)matronics.com   cc
     Subject
 --> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
  OMC 3853799
  DO NOT ARCHIVE
  Soldotna AK
  Avid "C" / Mk IV
  582 IVO IFA
  Full Lotus 1260
  hander outer of humorless darwin awards
  http://forums.matronics.com/viewtopic.php?p 34937#234937
           -Matt Dralle, List Admin.
		Guy Buchanan
				At 08:58 PM 3/16/2009, you wrote:
  	  | Quote: | 	 		  OMC 3853799
 Good job Leonard. You have no problem running a 160F thermostat? I
 think stock is about 135F.
 Guy Buchanan
 San Diego, CA
 K-IV 1200 / 582-C / Warp / 300 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
		Guy Buchanan
				 Posted: Mon Mar 16, 2009 9:18 pm    Post subject: 582 Thermostat/Bungee wraps... |
				At 08:20 PM 3/16/2009, you wrote:
  	  | Quote: | 	 		  Now after a good taxi-test, both new bungees seem to have settled
 Too loose. Check the archives.
 (http://www.matronics.com/searching/search.html) There has been a lot
 of past traffic regarding how to tighten bungies. You can get six
 wraps without too much trouble.
 find a more cost-effective part?\
 I've broken two now. You're right, they're expensive. However I'll
 bet they're the same ones the karts use. Let's spend some time
 tracking down a cheaper source. (I ran through four pages of Google
 and didn't find anything obvious, but it looks promising.)
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
		Fox5flyer Guest
				 Posted: Tue Mar 17, 2009 2:59 am    Post subject: 582 Thermostat/Bungee wraps... |
				The OMC t-stat Snake is talking about works fine--actually better because it
 allows the engine to quickly come up to a better working temp, especially in
 the cold country.  Some people drill a 3/16 hole in it to allow air to get
 through, but I forget why.  I think it's something to do with allowing the
 hot coolant to mix with the cooler stuff so there is no cold seizure
 potential.  ...or something like that.  $150 for a Rotax unit?  Was that a
 joke?
 Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 402+ TT
 "The aim of an argument or discussion should not be victory, but progress."
 - Joseph Joubert
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Tue Mar 17, 2009 5:58 am    Post subject: Re: 582 Thermostat/Bungee wraps... |
				 	  | Quote: | 	 		  | I just replaced the bungees through Kitfox Aircraft, and they told me 4-5 wraps would be sufficient. Well I nearly lost a few digits, but I was able to get four wraps out of the new bungees...Now the old bungees were wrapped 5 or 6 times around each, and there was plenty of play...Now after a good taxi-test, both new bungees seem to have settled�with about an inch gap between the bottom of the fuselage and the gear bar. Is that about right, because I can't imagine how to get another wrap out of them!  |
 Andrew, the gear tubes should sit up against the bottom of the fuselage when two good sized people are in the seat.  Six wraps will do it.  The trick is to not loose any of the progress you make on each wrap while you make the next wrap.  A helper is good to have.  I do mine by myself using water pump pliers with the jaws padded with friction tape to hold the last wrap while I make the next wrap.  I'm an old skinny guy.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
				 Posted: Tue Mar 17, 2009 7:26 am    Post subject: 582 Thermostat/Bungee wraps... |
				Thanks Guy...Is that thermostat a 160 as opposed to the stock? I'm almost embarrassed to say that the 4 wraps was WITH a buddy! I guess I'll have to go and give it another shot then! What we did was wrap a knot around the loop and used that to pull the bungee through....didn't leave much room so maybe the screwdriver method will work...
 Andrew
		akflyer
				 Posted: Tue Mar 17, 2009 7:42 am    Post subject: Re: 582 Thermostat/Bungee wraps... |
 Guy Buchanan
 San Diego, CA
 K-IV 1200 / 582-C / Warp / 300 hrs. and counting |
 Run this thermostat in 5 planes here locally with no issues.  flown them from -35 to 85 above and have not had any problems to date.  With this being said, I am not making claim that you may not have an issue.  I went through 2 "genuine Rotax" thermostats yet none of us have had an issue with the "after-market" one I listed.
 Remember, you must treat all my statements, stories, or tales as if they are 100% snake oil.  I don't want to loose my #1 salesman status LOL
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
		msm_9949(at)yahoo.com Guest
				 Posted: Tue Mar 17, 2009 8:20 am    Post subject: 582 Thermostat/Bungee wraps... |
				How long were those bungies Andrew? Relaxed, new ones should be 60" from loop to loop. While 6 wraps is a knuckle-busting event (no place for ladies or children) it's do-able. Those who say it's a snap are freaking wizards in my estimation.
  Marco Menezes N99KX
  Model 2 582-90 C-Box 3:1 w/clutch
 --- On Tue, 3/17/09, Andrew Matthaey <experimentalab(at)yahoo.com> wrote:
   	  | Quote: | 	 		  From: Andrew Matthaey <experimentalab(at)yahoo.com>
 Subject: 582 Thermostat/Bungee wraps...
 Date: Tuesday, March 17, 2009, 11:25 AM
  Andrew
 arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Kitfox-List
		larry huntley
				 Posted: Tue Mar 17, 2009 8:49 am    Post subject: 582 Thermostat/Bungee wraps... |
				It is a snap! I will try to take pix of the proper  tools and procedure. My wife and I can install one six wraps in a lot less than  10 minutes.     Larry Huntley
  [quote]   ---
  _________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
		Paul A. Franz, P.E.
				 Posted: Tue Mar 17, 2009 10:03 am    Post subject: 582 Thermostat/Bungee wraps... |
				On Tue, March 17, 2009 7:25 am, Andrew Matthaey wrote:
  	  | Quote: | 	 		   Thanks Guy...Is that thermostat a 160 as opposed to the stock? I'm almost embarrassed
 After a little fiddling around, I found this to be a fairly simple one-man job. I use
 two Vise-Grips and Channel Lock pliers. Make the first wrap and clamp it securely so
 that the Vise Grip handle is blocked from rotating. Then make another wrap easily with
 both hands now free use the Channel Lock plier to pull it tight to the point that the
 bungee won't stretch anymore then use the second Vise Grip to clamp that wrap also
 making sure that the handles will be supported from movement when you clamp and let
 go. Then make another wrap with both hands free, pull it tight and move the second
 Vise Grip to the new position. Repeat this process until you've got all the wraps you
 can fit in the space. Then have a cup of coffee or beer and admire your work so far.
 The last step is connecting the two ends of the bungee. I have a tool that allows you
 to apply as many wraps of safety wire as you want and will pull that safey wire as
 tight as you want it.
 My first try I had those safety wires so tight they injured the bungee. I think the
 joint should be made so it compressed the connection to about half the starting
 diameter. I used 12 wraps of safety wire which is 6 doubles.
 I'll post a couple photos of the tool on the Forum.
 Paul A. Franz
 Registration/Aircraft - N14UW/Merlin GT
 Engine/Prop - Rotax 914/NSI CAP
 Bellevue WA
 425.241.1618 Cell
 Democracy must be something more than two wolves and a sheep voting
 on what to have for dinner.
 -- James Bovard, Civil Libertarian (1994)
 A liberal is someone who feels a great debt to his fellow man, which
 debt he proposes to pay off with your money.
 -- G. Gordon Liddy
  _________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
		Lynn Matteson
				 Posted: Tue Mar 17, 2009 10:42 am    Post subject: 582 Thermostat/Bungee wraps... |
				Could it be that you have a bungee cord that is too large in
 diameter, or too strong? When I built my first set of skis two years
 ago, I wasn't sure what diameter cord to buy so I got 1/4, 5/16, 3/8
 and 1/2. The 1/4" was stronger than the 5/16"...thanks, Aircraft
 spruce. : )
 Lynn Matteson
 Jabiru 2200, #2062, 615.2 hrs
 Sensenich 62x46
 Status: flying
  will work...
  Andrew
  ============================================================ _-
  contribution_-
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
				 Posted: Tue Mar 17, 2009 12:36 pm    Post subject: 582 Thermostat/Bungee wraps... |
				You're obviously a wizard, Larry. Question: are there pointy heads under the pointy hats?
  Marco Menezes N99KX
 --- On Tue, 3/17/09, Larry Huntley <asq(at)roadrunner.com> wrote:
  [quote]From: Larry Huntley <asq(at)roadrunner.com>
 Subject: Re: 582 Thermostat/Bungee wraps...
 Date: Tuesday, March 17, 2009, 12:49 PM
		Guy Buchanan
				 Posted: Tue Mar 17, 2009 3:16 pm    Post subject: 582 Thermostat/Bungee wraps... |
				At 03:55 AM 3/17/2009, you wrote:
  	  | Quote: | 	 		  $150 for a Rotax unit?  Was that a joke?
 Not far off the mark. CPS has them for just over $120. It should be a joke.
 I'm kind of intrigued by the 160F thermostat; I'd like my engine to
 run hotter most of the time. If Leonard doesn't have cold seizure
 problems using it in Alaska, nobody will.
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
		larry huntley
				 Posted: Fri Mar 20, 2009 7:22 am    Post subject: 582 Thermostat/Bungee wraps... |
				Hi Marco,
    Pointy head, hhmmm.  Are you assuming I  have a sharp mind? Quite a compliment.   ;o)  I took a pic and  will send in a separate post.   Larry
  [quote]   ---
		dave
