F1013-L Longeron Tist
ron.mcgann(at)baesystems.
PostPosted: Mon Jan 02, 2006 11:00 pm    Post subject: F1013-L Longeron Tist Reply with quote
G'day all,
VHMUM(at)bigpond.com
PostPosted: Tue Jan 03, 2006 12:15 am    Post subject: F1013-L Longeron Tist Reply with quote
Hey Ron where are you as I am building a 10 in Melb
Chris
owl40188(at)yahoo.com
PostPosted: Tue Jan 03, 2006 9:37 am    Post subject: F1013-L Longeron Tist Reply with quote
Hi Ron,
n223rv(at)wolflakeairport
PostPosted: Mon Jan 09, 2006 6:35 pm    Post subject: F1013-L Longeron Tist Reply with quote
I believe the right one is bent to match one side of the template and
the left side is bent to match the other side of the template. If you
look at the template drawing in the plans and then look a couple of
pages further, it will show both the top and bottom of the template and
it will be labeled which side is left and right. The parts should be
mirror images except the left one has a bunch more hole where the
doubler rivets on over the baggage door.
