Remote oil filter
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
kellymeiste(at)jcwifi.com
PostPosted: Wed Mar 22, 2006 2:59 pm    Post subject: Remote oil filter Reply with quote
With spring now here I'm ready to replace my winter 10W-30 oil for my normal
Castrol 20W-50. I hate changing the filter as it's difficult to get at,
plus it dumps oil all over the muffler below when changing. I'm
contemplating going to a remote oil filter to simplify this process. With
more oil required to fill the additional oil lines and larger filter, plus
getting the filter away from the engine & muffler I hope to cool the oil
just a little better.
My question is, has any of you done this on your EA-81 yet?
If so can you tell me a little about your installation, and also were you
purchased the remote oil filter kit (part # if you have it)?
Thanks for any advice,
Kelly Meiste
Stratus powered 601 HD (130 hours)
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
Bill(at)flyinmiata.com
PostPosted: Wed Mar 22, 2006 3:18 pm    Post subject: Remote oil filter Reply with quote
Try www.batinc.net . They have the adaptors, mounts and also
thermostats.
Bill Cardell (TurboDog's Dad)
www.flyinmiata.com
1-800-FLY-MX5S
tech 970-242-3800
larry(at)macsmachine.com
PostPosted: Wed Mar 22, 2006 4:55 pm    Post subject: Remote oil filter Reply with quote
Kelly,
I found the difficulty of removing and replacing the filter was much
easier some time ago by putting
the leverage outside the motor mount. I used a nylon belt-wrench with a
square steel tube handle. This
was adapted to fit a large size socket extension 12 inches long. The
belt is fit the usual way onto the filter so that the
wrench and extension work the firewall-side of the filter while
extending out the right side. This method makes
getting the filter off a breeze. Doesn't stop the excess oil that
dribbles onto the muffler. I use a wad of paper
towels to capture that and a pan under. The extension works well both
ways, but one has to be careful
as it's easy to over tighten the filter. This method eliminated my need
for a remote oil filter which is going to
drip wherever you put it.
Larry McFarland
Kelly Meiste
bryanmmartin
PostPosted: Wed Mar 22, 2006 5:11 pm    Post subject: Remote oil filter Reply with quote
I usually just put a piece of scrap aluminum on the muffler under the filter
when removeing it. The oil dribbles down on to the aluminum and runs down
into the drain pan.
Bryan Martin
do not archive.
on 3/22/06 7:54 PM, LarryMcFarland at larry(at)macsmachine.com wrote:
Kelly,
Larry McFarland
> plus it dumps oil all over the muffler below when changing. I'm ...
> Kelly Meiste
Bryan Martin
do not archive.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
