Posted: Mon Mar 23, 2009 4:59 pm Post subject: doors |
OK, speaking of doors ..... has anyone suffered damage because the wind
caught the doors? Any other concerns with the doors??? Any 'fixes'
that you'd do when you're assembling the doors??? I'm getting ready
to do mine ..... educate me!!!
Linn
Tim Olson wrote:
winds are 20+, taxi isn't the worry,
holding the doors when you open them is a bigger concern.
gengrumpy(at)aol.com Guest
Posted: Mon Mar 23, 2009 5:29 pm Post subject: doors |
Best add a strap you can hold onto when you open it. Also use it to
pull it closed.
I don't let my passengers open the door if there's any wind to speak
of.....
grumpy
N184JM
On Mar 23, 2009, at 9:00 PM, linn wrote:
wind caught the doors? Any other concerns with the doors??? Any
'fixes' that you'd do when you're assembling the doors??? I'm
getting ready to do mine ..... educate me!!!
Linn
Tim Olson wrote:
> the winds are 20+, taxi isn't the worry,
> Tim Olson - RV-10 N104CD - Flying
> do not archive
pascal(at)rv10builder.net Guest
Posted: Mon Mar 23, 2009 5:33 pm Post subject: doors |
The adjusting and making the doors line up will require you to "fix" that
fit after you trim everything
The trimming to get the doors to close will require a whole lot of "fixing"
the aligning/leveling of the doors with the canopy will require lots of
"fixing" with flox and micro
The whole door is a "fix", expect lots of hours fixing it to fit.
My advice concerning the seals is buy a smaller one than what Van's thinks
will work, it's pretty sad to see perfectly fitting doors not fit at all
after installing the seals and having to start all over again trying to
"fix" it to fit..
Have fun! I just finished mine took months to complete, but can be done in 1
month non stop, aka- I took breaks between pages to let things set and
replace electric tools that the composite cutting and mainly sanding
destroyed, .
Pascal
Sent: Monday, March 23, 2009 6:00 PM
Subject: doors
caught the doors? Any other concerns with the doors??? Any 'fixes' that
you'd do when you're assembling the doors??? I'm getting ready to do
Linn
> do not archive
Dave(at)AirCraftersLLC.co Guest
Posted: Mon Mar 23, 2009 6:24 pm Post subject: doors |
We did a repair for a lucky customer whose door came open just after
take-off. He was able to land straight ahead. The door opened all the way,
broke the gas strut brackets off the door, but otherwise had no other
damage. We did a very thorough inspection of the hinges and other attach
structure and it was all fine.
I taxi with the doors open all the time. I think opening the doors in a
crosswind would be pretty safe, just a hassle because of all the other
wind-related issues, but I don't think you'd break anything.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
daveleikam(at)wi.rr.com Guest
Posted: Mon Mar 23, 2009 7:35 pm Post subject: doors |
think of it this way..
expect the worst, like my fixing, and be pleasantly surprised when you
discover I had no idea what I was doing and you get it done without any
issues. Sure beats me telling you its easy; just trim, tuck and snip snip
and your done.
You'll thank me one day
Pascal
Sent: Monday, March 23, 2009 6:27 PM
Subject: Re: doors
I just started mine, thanks for the vote of confidence... Sheeesh!
partner14
Posted: Mon Mar 23, 2009 8:51 pm Post subject: doors |
If I was going o do them again,,,, GOD forbid, I would insert a strengthening plate aft of the door handle. Then you'd have something to actually fasten a strap to.
My 2 cents.
Don McDonald
Received the FAA's blessing today with an airworthiness cert!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
--- On Mon, 3/23/09, linn <pitts_pilot(at)bellsouth.net> wrote:
Subject: doors
Date: Monday, March 23, 2009, 7:00 PM
--> RV10-List message posted by: linn <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
OK, speaking of doors ..... has anyone suffered damage because the wind caught the doors? Any other concerns with the doors??? Any 'fixes' that you'd do when you're assembling the doors??? I'm getting ready to do mine ..... educate me!!!
Linn
Tim Olson wrote:
40636 |
Posted: Tue Mar 24, 2009 6:45 am Post subject: doors |
As for doors...
It takes a very long time to get them to fit perfectly C like sailplane quality.
As mentioned C I put an additional hardpoint(hardwood block) in the leading edge C above the pin location C so I could instal a locking mechanism C like that on the baggage door.
I put an additional 6"X6" spider foam block in the rear area of the door above the rear pin location.
Everything was verified to fit prior to lamination of the door halves on the fuse. Windows where later laminated on the door with the doors on the fuse.
In the rear additional foam C one should put a hardpiont in that location( either hardpoint only to screw a fastener into or put the fastener into the door before laminating the halve for the strap that will be used to pull the door closed.
That additional foam will keep the rear half of the door from being so flimsy or compressible from the in or outside.
DId anyone notice that the canopy's Rt front portion which attaches to the fuse stand proud and therefore might makes the Rt door stand more proad where the door transitions from the canopy to the metal fuse???????????????????Or was my conopy removed from the mold a little too early and got warped??? Left side was dead on.
| Quote: | Date: Mon C 23 Mar 2009 21:00:48 -0500
Subject: doors
--> RV10-List message posted by: linn <pitts_pilot(at)bellsouth.net>
OK C speaking of doors ..... has anyone suffered damage because the wind
Linn
Tim Olson wrote:
> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> When the
> winds are 20+ C taxi isn't the worry C
> do not archive
Albert Gardner
Posted: Tue Mar 24, 2009 7:15 am Post subject: doors |
Let me pass on the report I got from an RV-10 owner concerning the "Lose of
Door in Flight" situation. The part I like was the statement 'the plane flew
fine.'
Albert Gardner
Yuma, AZ
"After the P seals are added to the doors it can be rather hard to close
them. Since the rear latch is difficult to see and you pull the door closed
from the forward edge the rear pin is the most likely to not be engaged. My
passenger failed to close it properly and I did not check it before
take-off. Immediately after rotation and within 200' of the ground there was
a loud bang and it became very noisy and windy. The plane flew fine, I kept
it to about 90kts, did a 180 and landed without further incident. The door
pulled through the bolts at the hinge and the gas strut broke loose both at
the door and cabin attach points. The door halves had mostly delaminated,
the window was broken, and the inner shell had broken through at the curve
but was easily repairable. There was no damage to the empennage."
_________________ RV-9A N872RV
RV-10 N991RV |
jcumins(at)jcis.net Guest
Posted: Tue Mar 24, 2009 7:59 am Post subject: doors |
Congrats Don. I am sure your inspection will go off with out a hitch.
When I get to the doors I will sure come visit you for advise.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Monday, March 23, 2009 9:48 PM
Subject: Re: doors
My 2 cents.
Don McDonald
Subject: doors
Linn
Tim Olson wrote:
> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> When the winds are 20+, taxi isn't the worry,
> do not --> http://www.matronics.com/Navigator?RV10-List
sp; --> ht - List Contribution Web Site; &nb; http://========================
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
partner14
Posted: Tue Mar 24, 2009 8:33 am Post subject: doors |
Passed already... yesterday. then took the FAA inspector, Dilly, out for a bbq dinner. Great guy, unbelievable that he's a govt employee. Basically inspected my plane on his own time. Now for finishing my flight training. Headed to Dallas this weekend for RV10 training and the hp endorcement with Alex. The ducks are lining up!
Sure, come on up anytime.
Don
--- On Tue, 3/24/09, John Cumins <jcumins(at)jcis.net> wrote:
Subject: RE: doors
Date: Tuesday, March 24, 2009, 8:56 AM
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com ] On Behalf Of Don McDonald
Subject: Re: doors
My 2 cents.
Don McDonald
Subject: doors
Linn
Tim Olson wrote:
| Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com | 012
40636 |
Posted: Tue Mar 24, 2009 8:55 am Post subject: doors |
Congrats, wish I was going to Dallas with you. But in due time hehe. 50000 more rivits to go.
Chat soon.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Sent: Tuesday, March 24, 2009 9:31 AM
Subject: RE: doors
Don
Subject: RE: doors
When I get to the doors I will sure come visit you for advise. |
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Subject: Re: doors
My 2 cents.
Don McDonald
Subject: doors
Date: Monday, March 23, 2009, 7:00 PM |
Linn
Tim Olson wrote:
> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> When the winds are 20+, taxi isn't the worry,
| Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List=nofollow>http://forums.matronics.com | 01
23456789 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 5 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 6 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 7 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 8 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 9 | Quote: | | http://forums.matronics.com | 0 | Quote: | | http://forums.matronics.com | 1
