Filler for "Unwanted" Rivet Holes ???
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
gareywittich2000(at)yahoo
PostPosted: Wed Mar 25, 2009 9:03 pm    Post subject: Filler for "Unwanted" Rivet Holes ??? Reply with quote
Greetings:
What material have you Builders used to fill in a couple of unwanted holes in the Skin, where a rivet can NOT be placed to plug the hole ????
Is Super-Fil a possible solution ????
Thanks, Garey Wittich Santa Monica, CA
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
Smcm75(at)aol.com
PostPosted: Thu Mar 26, 2009 5:14 am    Post subject: Filler for "Unwanted" Rivet Holes ??? Reply with quote
In a message dated 3/26/2009 1:04:26 AM Eastern Daylight Time, gareywittich2000(at)yahoo.com writes:
Nope try cutting a little circular patch from .016 aluminum about 3/4" dia. mix up a small batch of b-2 compound and stick the patch on the hole from the rear. Then clean the b-2 out of the hole if it oozes in with MEK. After the b-2 is set up you can fill the hole with featherfill and it will never vibrate out.
Feeling the pinch at the grocery store? Make dinner for $10 or less.
John Brunke
PostPosted: Thu Mar 26, 2009 1:39 pm    Post subject: Filler for "Unwanted" Rivet Holes ??? Reply with quote
Ok you got a new one on me. I tried looking up B-2 compound and couldn't find anything on it. Is this stuff like JB weld?
Smcm75(at)aol.com
PostPosted: Fri Mar 27, 2009 3:25 am    Post subject: Filler for "Unwanted" Rivet Holes ??? Reply with quote
In a message dated 3/26/2009 5:40:17 PM Eastern Daylight Time, jdoody727(at)comcast.net writes:
B-2 compound is trade named Proseal that is the black rubber like junk that is used to seal all rv fuel tanks. it comes in two jars the base which is white and the hardner which is black. If I remember correctly the mix is 10 parts base 1 part hardner. it has the consistancy of warm peanut butter prior to hardning to a solid rubber like finish product.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
