		fritzsch(at)eskimo.com Guest
				 Posted: Fri Apr 03, 2009 10:31 am    Post subject: Which Quickbuild Would You Recommend? |
				I am working on my elevators and thinking about how I want to proceed.
 While I may go all self built, I want to consider all of my options.
 This question is mainly for those who are flying or have finished their
 fuselage.  If you had to make a choice of one or the other, would you go
 for the quickbuild wings or the quickbuild fuselage?
 Dave
 Dave Fritzsche
 40813
 Puyallup, WA
		bkbrown(at)minetfiber.com Guest
				 Posted: Fri Apr 03, 2009 10:58 am    Post subject: Which Quickbuild Would You Recommend? |
				QB Wings
		Tim Olson
				 Posted: Fri Apr 03, 2009 11:14 am    Post subject: Which Quickbuild Would You Recommend? |
				I'll counter that with QB Fuse. Depends on if you like
 building or like flying.
 Bob and Karen Brown wrote:
  QB Wings
		rv(at)thelefflers.com Guest
				 Posted: Fri Apr 03, 2009 11:18 am    Post subject: Which Quickbuild Would You Recommend? |
				I don't think you'll get much debate.  QB Wings over QB fuselage.
 The fuselage goes together quicker and is more interesting (i.e. less
 repetitive work).  The fuselage requires less proseal too!  (i.e fuel tanks
 are built in the QB wings)
 I think a better question to ask is what will be the quality level of the
 QBs with the new factory?  Unfortunately, nobody will know that answer until
 this summer when they start to ship.
 I'm doing a standard build of both.
 bob
		pascal(at)rv10builder.net Guest
				 Posted: Fri Apr 03, 2009 11:33 am    Post subject: Which Quickbuild Would You Recommend? |
				Depends on how much you want to build, I would go SB the whole way, as I
 did, you lose so much of the building experience getting the QB. If you are
 sold on one or the other the fuselage requires more work than the wings did,
 the only section in the wings that are a challenge is the fuel tanks and
 that just requires an attention to detail, if you are meticulous in applying
 the proseal that section can be fun as well and really no big deal.
 So if in a rush, get the fusellage QB if not do the SB and enjoy the
 building process.
 Pascal
 From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com>
 Sent: Friday, April 03, 2009 10:25 AM
 To: "RV-10 Matronics" <rv10-list(at)matronics.com>
 Subject: Which Quickbuild Would You Recommend?
  While I may go all self built, I want to consider all of my options.  This
  Dave
  Dave Fritzsche
  40813
  Puyallup, WA
		Tim Olson
				 Posted: Fri Apr 03, 2009 11:40 am    Post subject: Which Quickbuild Would You Recommend? |
				Gee, I don't know.  I've met more than a handful of people
 so far with leaky rivets on fuel tanks from QB Wings.  I'd
 never want to have my tanks built there based on what I've
 seen so far in that respect.   But, you're right, based
 on the new Philippines issues, it may be safest just to
 skip all the QB stuff and do it all yourself.  You'd save
 enough to buy or almost buy a GNS-430W while you're doing it.
 As far as I'm concerned though, the proseal job of
 building tanks may suck, but it certainly is bearable
 and it's over pretty quick...I'd do it again no
 problem.
  bob
				 Posted: Fri Apr 03, 2009 11:55 am    Post subject: Which Quickbuild Would You Recommend? |
				The reason I said wings is...that's the part that's flying, it's the
 majority of rivets.  I've bought two sets of QB wings...both were almost
 flawless.  I can't do that good of riveting myself...I went QB all the way
 on my -7A.  On the 10, went QB wing...happy with that, but would have been
 fine either way really.  I'd say look at a QB wing if you can...then look at
 a first timers wing...make your choice.
 Bob
		sstella(at)incisaledge.co Guest
				 Posted: Fri Apr 03, 2009 12:23 pm    Post subject: Which Quickbuild Would You Recommend? |
				I just ordered slow build wings and I'm fine with slow build all the way but
 it depends on how fast you want to finish. I heard of issues with leaking
 quickbuild tanks in the past. I don't know if it has been resolved but that
 might be something to consider.
				 Posted: Fri Apr 03, 2009 12:55 pm    Post subject: Which Quickbuild Would You Recommend? |
				I don't know what percentage of QB tanks leak vs SB or "owner built"...but I
 can't believe it can be much different.  With over 50 RV's based at this
 airpark and in my own experiences of being around people who have finished
 up their planes and fueled and flown...I just don't see a huge difference in
 how many leak...QB vs SB.  I've seen just a few leakers from each type, but
 I don't really see a chronic problem either way.  Chalk up my QB tanks
 (knocking on wood now) and everyone I know around me as non leakers.  The
 only leakers I know of around here (total of maybe six) except one or two
 have all been owner built tanks.
 Bob
		dlm46007(at)cox.net Guest
				 Posted: Fri Apr 03, 2009 1:11 pm    Post subject: Which Quickbuild Would You Recommend? |
				Both QB, of course I got the early QB wings and fuselage. Also I put every
 rivet in the Glastar project so don't need the additional experience.
		Phil.Perry(at)netapp.com Guest
				 Posted: Fri Apr 03, 2009 1:14 pm    Post subject: Which Quickbuild Would You Recommend? |
				I wish I hadn't ordered a QB fuse (Or wings for that matter) last
 December.
 I'm feeling like July or August is optimistic at this time.  I really
 wish I had ordered parts only.
 I'd cancel my order now, but I'm stuck between a rock and a hard place.
 If I cancel, I'm starting over from scratch 5 months late and I might be
 getting a QB fuse in a few months.  A fuse completed to QB status is
 more than 3-6 months of work for me to do.  So it's a catch 22.
 If I was ordering again, I'd just order the parts.  Regardless of wings
 or fuse.
 Phil
				 Posted: Fri Apr 03, 2009 1:48 pm    Post subject: Which Quickbuild Would You Recommend? |
				Simple math:
 Wings = 2
 Wing Fuel Tanks = 2
 Fuse = 1
 Fuse Fuel Tanks = 0
 QB wings, SB Fuse IMHO.
 Robin
		Kelly McMullen
				 Posted: Fri Apr 03, 2009 3:12 pm    Post subject: Which Quickbuild Would You Recommend? |
				Have you had any updates on the QB delivery time? My order is a couple months behind yours.
 On Fri, Apr 3, 2009 at 5:13 PM, Perry, Phil <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)> wrote:
  [quote]--> RV10-List message posted by: "Perry, Phil" <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)>
  December.
  or fuse.
  Phil
A&P/IA, EAA Tech Counselor
KCHD |
		bcondrey
				 Posted: Fri Apr 03, 2009 3:17 pm    Post subject: Which Quickbuild Would You Recommend? |
				Dave,
 The SB wings are largely repetition - 2 essentially identical parts.
 Each of them have a lot of ribs.  There is nothing at all complex about
 building the wings - imagine a much larger scale version of the H-stab.
 Fuel tanks aren't that difficult either, just messy.  They're also
 almost identical to the outboard leading edge assemblies, except for the
 proseal
 The SB fuselage is a lot more involved - longerons to be bent/twisted,
 lower forward/aft cabin skins to be rolled around a hardwood form, etc.
 The fuselage requires a lot more head scratching than the wings.
 Just depends on why you're considering QB - if it's to avoid complex
 construction go with the QB fuselage, if it's to avoid a lot of
 repetitious, mundane type of building then go with QB wings.
 Bob
 N442PM (flying)
		taildragon(at)msn.com Guest
				 Posted: Fri Apr 03, 2009 4:12 pm    Post subject: Which Quickbuild Would You Recommend? |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Maybe it just comes down to why you are building. Build everything yourself  if you can. If you are short on time, because of age or because of "life  happening", then consider quick build. I say "consider quick build" because in a  perfect world the quick builds would be, well, perfect but we know they have  their short comings. Many building starts end with incompletions. If quick  builds will make the difference between not finishing and flying a mostly self  constructed plane, then the answer is obvious.
  Roger
  Flying a most awesome beast!
 -----Original    Message-----
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
 [mailto:owner-rv10-list-server(at)matronics.com]    On Behalf Of Dave
 Sent: Friday, April 03, 2009    12:25 PM
 To: RV-10 Matronics
 --> RV10-List message posted by: "Dave Fritzsche    (Building)"
 <fritzsch(at)eskimo.com (fritzsch(at)eskimo.com)>
 Dave
 Dave    Fritzsche
 40813
 Puyallup,    p;    Navigator  Photoshare, and    title=http://www.matronics.com/Navigator?RV10-List    href="http://www.matronics.com/Navigator?RV10-List">http://www.matronicp;     via the Web  title=http://forums.matronics.com/    href="http://forums.matronics.com">http://forums.matronics.com
 _p;          generous    bsp;                       title=http://www.matronics.com/contribution    href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
