		Deems Davis
				 Posted: Tue Apr 21, 2009 6:21 pm    Post subject: Transponder questions |
				Today, I was informed by tower that they were not receiving my
 transponder, (GTX 327). Once back on the ground, I dug out the
 installation manual, and found a diagnostic 'page' on the display that
 purports to display the encoder input altitude, It displays both the
 binary, as well as the decoded altitude, In this case it was displaying
 1300 ft (baro adjust altitude at the field was 1400). To my uneducated
 mind this suggests that the encoder is providing some (perhaps
 erroneous). Alltitude info to the transponder. So. where should I look
 next?  I originally had the 'pole' antenna installed, but changed it out
 for the Commant blade style, Is the antenna/coax/ connections the next
 logical place to look.
 Any suggestions gladly received?
 Deems Davis
 N519PJ Phase1
		gengrumpy(at)aol.com Guest
				 Posted: Tue Apr 21, 2009 6:36 pm    Post subject: Transponder questions |
				Might be time to invest in the IFR cert if you have an avionics guy on
 your airport.......
 grumpy
 On Apr 21, 2009, at 9:18 PM, Deems Davis wrote:
  that purports to display the encoder input altitude, It displays
  both the binary, as well as the decoded altitude, In this case it
  was displaying 1300 ft (baro adjust altitude at the field was 1400).
  To my uneducated mind this suggests that the encoder is providing
  some (perhaps erroneous). Alltitude info to the transponder. So.
  where should I look next?  I originally had the 'pole' antenna
  installed, but changed it out for the Commant blade style, Is the
  antenna/coax/ connections the next logical place to look.
  Deems Davis
  N519PJ Phase1
		Kelly McMullen
				 Posted: Tue Apr 21, 2009 6:38 pm    Post subject: Transponder questions |
				Were they not seeing transponder reply, or just altitude? IMHO, you
 need a transponder certification anyway. Atlantic, nee Westwind used
 to have that capability, and relatively cheap for VFR cert. Since you
 are in Class B 30 mile arc, you need a fix pronto before the FSDO
 takes an interest.
 On Tue, Apr 21, 2009 at 7:18 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
  Today, I was informed by tower that they were not receiving my transponder,
  (GTX 327). Once back on the ground, I dug out the installation manual, and
  found a diagnostic 'page' on the display that purports to display the
  encoder input altitude, It displays both the binary, as well as the decoded
  altitude, In this case it was displaying 1300 ft (baro adjust altitude at
  the field was 1400). To my uneducated mind this suggests that the encoder is
  providing some (perhaps erroneous). Alltitude info to the transponder. So.
  where should I look next?  I originally had the 'pole' antenna installed,
  but changed it out for the Commant blade style, Is the antenna/coax/
  Deems Davis
  N519PJ Phase1
A&P/IA, EAA Tech Counselor
KCHD |
		Deems Davis
				 Posted: Tue Apr 21, 2009 7:40 pm    Post subject: Transponder questions |
				Kelly they aren't seeing anything, and I'm not seeing any
 'pings/replies' on the unit in the panel. I agree, this needs to get
 fixed before going aloft again, don't want to wake up the bear. I do
 need the cert, but I need to have something certifiable, which at
 present I don't. I'm going to go down the antenna route, coax, pins,
 shield, connectors, ground, etc. and see if that leads to an improvement.
 Deems
 Kelly McMullen wrote:
  takes an interest.
 > Deems Davis
 > N519PJ Phase1
		Kelly McMullen
				 Posted: Tue Apr 21, 2009 8:06 pm    Post subject: Transponder questions |
				You are fortunate in that there is at least one, probably two ATC
 radars that should splash DVT if you are clear of the hangars, on the
 north ramp. PHX has a new one at Union Hills and Central Ave, and of
 course Luke's radar is pretty new and also close by. So if you power
 up from external power, you should be able to test ping on the ground.
 With the unit getting power, lighting up, either your antenna isn't
 feeding a signal in, to trigger a reply, or the transponder output is
 no good. Avionics shop may be willing to see if it works on the bench,
 gratis. Infant mortality is not unheard of.
 On Tue, Apr 21, 2009 at 8:30 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
  Kelly they aren't seeing anything, and I'm not seeing any 'pings/replies' on
  the unit in the panel. I agree, this needs to get fixed before going aloft
  again, don't want to wake up the bear. I do need the cert, but I need to
  have something certifiable, which at present I don't. I'm going to go down
  the antenna route, coax, pins, shield, connectors, ground, etc. and see if
  Deems
 > takes an interest.
 >> transponder,
 >> and
 >> decoded
 >> is
 >> So.
 >> Deems Davis
 >> N519PJ Phase1
KCHD |
		Barry Chapman
  Joined: 16 Apr 2008 Posts: 11 Location: Lone Wolf, OK
				 Posted: Wed Apr 22, 2009 3:43 am    Post subject: Transponder questions |
				Since the antenna was changed out, some things come to mind.  1) was the coax re-hooked back up to the new antenna?  2) A way to troubleshoot would be to put the pole antenna back on and see if they see you, if they do then it's the new antenna; if not then it's the xpdr or the wiring. 3) You could have messed up the antenna coax connector when you chnged the antenna out.  4) Anyone near by that would be willing to let you put your xpdr in their plane?  Would be a quick way to see if it is the xpdr or your wiring.
  Hope this helps
  Barry Chapman
  RV9A
 Sent: Tuesday, April 21, 2009 11:03:35 PM
 Subject: Re: Transponder questions
 --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
 On Tue, Apr 21, 2009 at 8:30 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
  	  | Quote: | 	 		   --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
  Deems
 > takes an interest.
 > On Tue, Apr 21, 2009 at 7:18 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
 >> transponder,
 >> and
 >> decoded
 >> is
 >> So.
 >> Deems Davis
 >> N519PJ Phase1
 &bsp;                 -Matt Dralle, ===========
  _________________ Barry Chapman
RV-9A in progress
Tail complete, Wings here, Engine needs rebuilt |
		msausen
  Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
				 Posted: Wed Apr 22, 2009 4:34 am    Post subject: Transponder questions |
				That was kinda my thought too.  If the coax is quick and easy to get to check that first otherwise I would see if someone can bench test it just you you can eliminate that as a possibility.  If you suspect the unit, let me know and I can send you my 327 to give a try.
 Michael
		Tim Olson
				Forgive me for asking the obvious, but, you did select
 ALT mode on the transponder, correct?  I've seen some
 people go flying without doing that (if you don't provide
 some way for the transponder to auto-sense you're flying)
 and then not get any altitude readout to ATC.
 Deems Davis wrote:
  Deems
 > takes an interest.
 >> transponder,
 >> manual, and
 >> decoded
 >> altitude at
 >> encoder is
 >> transponder. So.
 >> installed,
 >> Deems Davis
 >> N519PJ Phase1
		jim(at)CombsFive.Com Guest
				 Posted: Wed Apr 22, 2009 4:43 am    Post subject: Transponder questions |
				(1) Check to see if the transponder is showing the reply indicator on the display.  That is an indication that it is attempting to transmit.  (I had a bad cable and even though the unit was doing the reply, it was not going out).  The cable connector was faulty (My fault!)(2) Check the setup in the transponder as to what it is expecting from the EFIS.  You may need to check the EFIS manual for the proper setup. Jim C40192 - Flying - 58 hours!--------------------------------------------------------------------------------------------------------------------------> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>Today, I was informed by tower that they were not receiving mytransponder, (GTX 327). Once back on the ground, I dug out theinstallation manual, and found a diagnostic 'page' on the display thatpurports to display the encoder input altitude, It displays both thebinary, as well as the decoded altitude, In this case it was displaying1300 ft (baro adjust altitude at the field was 1400). To my uneducatedmind this suggests that the encoder is providing some (perhapserroneous). Alltitude info to the transponder. So. where should I looknext?  I originally had the 'pole' antenna installed, but changed it outfor the Commant blade style, Is the antenna/coax/ connections the nextlogical place to look.Any suggestions gladly received?Deems DavisN519PJ Phase1   [quote][b]
				 Posted: Wed Apr 22, 2009 4:57 am    Post subject: Transponder questions |
				It might be a good idea to pull out your unit & slide it in another
 plane to verify the unit is good.  Then I'd check for continuity & no
 short in the antenna cable.  If that checks good, then maybe the
 antenna, but it probably is something simple & obvious once you get to
 checking.
 Jesse Saint
 Saint Aviation
 jesse(at)saintaviation.com
 352-427-0285
 On Apr 21, 2009, at 11:30 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
  replies' on the unit in the panel. I agree, this needs to get fixed
  before going aloft again, don't want to wake up the bear. I do need
  the cert, but I need to have something certifiable, which at present
  I don't. I'm going to go down the antenna route, coax, pins, shield,
  Deems
 > takes an interest.
 >> transponder,
 >> manual, and
 >> the
 >> the decoded
 >> altitude at
 >> encoder is
 >> transponder. So.
 >> installed,
 >> Deems Davis
 >> N519PJ Phase1
		Deems Davis
				 Posted: Wed Apr 22, 2009 6:14 am    Post subject: Transponder questions |
				Thanks to all who responded with information & suggestions. I did verify
 in the air that the ALT func was selected, but no replies were being
 seen in the panel. I hadn't thought of swapping, but that's a great
 idea, shouldn''t be too hard to find someone to help out on that end.
 Short of that, I'll have to tear out the center console and it's gadgets
 in order to get into the tunnel where the antenna and cable are
 mounted/routed.
 URGH!!!
 Deems
		rv6(at)att.net Guest
				 Posted: Wed Apr 22, 2009 8:06 am    Post subject: Transponder questions |
				Make sure antenna is grounded to mounting area.  Might need to rough up the
 aluminum on inside of cockpit if it is painted or primed, use an aluminum
 plate with nut plates to accept antenna screws.  The plate should ground to
 the skin.
 Jerry
				 Posted: Wed Apr 22, 2009 8:21 am    Post subject: Transponder questions |
				Before you do all that, make sure you pull out and re-seat the radio
 in the tray real well.  Many times it is just a bad connection between
 the radio and the tray itself...
		Bob Turner
				 Posted: Wed Apr 22, 2009 9:21 am    Post subject: Re: Transponder questions |
				BTW, the altitude readout on the transponder is pressure altitude. To check its accuracy, set the aircraft altimeter to 29.92".
  _________________ Bob Turner
RV-10 QB |
		robin1(at)mrmoisture.com Guest
				 Posted: Wed Apr 22, 2009 9:30 am    Post subject: Transponder questions |
				Is that the pain of which you were speaking?
 Robin
		Deems Davis
				 Posted: Wed Apr 22, 2009 2:12 pm    Post subject: Transponder questions |
				Yeah, and I was kinda hoping that I had made my last trip upside down
 underneath the panel until annual time!!!
 Deems
  Robin
		Deems Davis
				 Posted: Wed Apr 22, 2009 7:19 pm    Post subject: Transponder questions |
				Jerry, after noodling on this, I actually think this might be the
 culpret. And will be the 1st place I look. I changed out the original
 'pole' antenna for a 'blade' type during the build process, and in doing
 so I also installed a doubler, in looking back at the photo log it
 appears that I primed the double before attaching it !?!? . I pulled the
 unit and took it to an avionics shop on field today and they put it on
 their tester and said it was clean, so either the encoder & connections
 or antenna & connections.
 Thanks to all for the help so far.
 Deems
 I also tried the unseat and reseat step.
 Jerry Calvert wrote:
  the skin.
  Jerry
		Kelly McMullen
				 Posted: Wed Apr 22, 2009 8:01 pm    Post subject: Transponder questions |
				You also could disconnect the encoder, after verifying the antenna
 grounding and see if it works in Mode A only. KISS. One step at a
 time, get the basic unit working, then the encoder.
 On Wed, Apr 22, 2009 at 8:16 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
  Jerry, after noodling on this, I actually think this might be the culpret.
  And will be the 1st place I look. I changed out the original 'pole' antenna
  for a 'blade' type during the build process, and in doing so I also
  installed a doubler, in looking back at the photo log it appears that I
  primed the double before attaching it !?!? . I pulled the unit and took it
  to an avionics shop on field today and they put it on their tester and said
  it was clean, so either the encoder & connections or antenna & connections.
  Deems
 > the
 > to
 > the skin.
 > Jerry
KCHD |
