Hot offer for Nanchang CJ6 aircraft parts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List
Nanchang CJ6
PostPosted: Mon May 04, 2009 5:11 pm    Post subject: Hot offer for Nanchang CJ6 aircraft parts Reply with quote
Part number Description Chinese Description Quantity Unit Price(USD)
1 DZ-5 Spark Plugs 电嘴(火花塞) 200个 22
2 QS-2 Brake valve differential 刹车分布器 4个 420
3 BG12-1A Instrument altimeter 高度表 1个 191
4 FL-3 Compass amplifier 罗盘放大器 5个 137
5 ZH-4 Instrument compass indicator 罗盘指示器 3个 82
6 GY-1 Fuel pressure 压力表传感部 2个 119
7 ZWH-1 Instrument cyl. Temp 温度表指示器 4个 101
8 ZZ30-1C Instrument tach single needle 转速表指示器 29个 131
9 DH-2 Boost coil 起动线圈 6个 135
10 TS-1 Prop governer 调速器 4个 465
11 CP-15 Petrol Pumb(gasoline) 汽油泵 2个 412
12 CB-32A Engine oil pump 滑油泵 4个 691
13 BC10 Instrument vsi (rate of climb) 升降速度表 5个 88
14 BAV-3 Instrument current voltage 电流电压表 1套 100
15 BYJ-1 Instrument manifold press 进气压力表 4个 82
16 CSR-1 Air radiator 空气散热器 4个 505
17 H2-6112-00A/1 2 Oil house R/H 汽油箱 左右 各4个 674
18 Propeller blade 螺旋桨叶 4个 3236
19 BDP-2B Instrument Horizon 地平仪 2个 1026
20 301 Clock front cockpit 航空时钟 2个 336
21 2UC2-7 Instrument oil indicator 油量表指示器 1个 494
22 BYQ80-1A Air pressure guage 冷气压力表 2个 52
23 QS-1 Brake valve reducing 减压活门 7个 150
24 KY-2C Air Compressor 空气压缩机 2个 382
25 SB-1 Pump manual fuel wobble pump 手摇泵 2个 138
26 QHQ-14 Carburetor 汽化器 2个 121
- The Matronics Beech-List Email Forum -
http://www.matronics.com/Navigator?Beech-List
Sarah's E-mail:lcdzkj@live.cn
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List All times are GMT - 8 Hours
