jlno7(at)aim.com Guest
Posted: Mon May 04, 2009 7:25 am Post subject: prop questions |
I have a 87 Kitfox 1 with 2 modifications with a three blase wooden
prop. At the ehd on one of the blades is a hairline crack about 2.5 cm
long. I polyurethaned and sanded it. Is that sufficient or do I need
to replace it? Can you replace one blade or do you need to replace all
three?
Jerry Novak
N299JK
Pulaski, WI
matronics(at)bob.brennan. Guest
Posted: Mon May 04, 2009 7:51 am Post subject: prop questions |
Hi Jerry,
A crack in a wood propellor blade is reason to replace it yes. You
undoubtably have a GSC prop and they will replace a single blade for you but
they need the other two blades to match and balance it. I would recommend
contacting them first and then sending all three blades. They will make sure
the other two are ok and might even replace the defective blade at a reduced
cost.
Verify that you have a GSC prop and go to
http://www.ultralightprops.com/index.html
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade GSC prop
Wrightsville Pa
Fox5flyer Guest
Posted: Mon May 04, 2009 8:06 am Post subject: prop questions |
If it is a GSC prop I would email or write them and await their
recommendation. Same goes for pretty much any of the other vendors. GSC is
generally very good at supporting their products. A closeup photo helps.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 406+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
dave
Posted: Mon May 04, 2009 1:12 pm Post subject: Re: prop questions |
Your GSc is likely expired if it is that old.
I would bet if original 3 blade it will be the square root ends and not adjustable.
I have GSC 66 " of a 532 3 blade with only 10 hours on it since new last year. I would sell for 450 $
I have a GSC inflight adjustable 70 " with Warp blades and nickel leading edges . 1500 $
Here is what happens to them when they fail
http://www.cfisher.com/gsc
I sell all brands of props new and some used. What engine and gearbox ratio you have ?
Dave
dave(at)cfisher.com
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Mon May 04, 2009 6:41 pm Post subject: prop questions |
Does the crack go all the way through the blade or is it a surface crack?
Pics?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Roger Lee
Posted: Mon May 04, 2009 6:46 pm Post subject: Re: prop questions |
Hi Jerry,
You could not have fixed the prop deep inside the grain. It will grow whether you see it or not from vibration. Toss the blade or prop and start new. If it comes apart in flight some day it may not be pretty. If the prop is from 1987 it is past its life anyway and you got your money's worth.
Better safe than sorry.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Fox5flyer Guest
Posted: Tue May 05, 2009 4:09 am Post subject: prop questions |
I fail to see what a small crack in the tip of a (as yet type unknown) prop
blade has to do with a blade letting go at the hub. Again, my advice is he
should go to the manufacturer where the real experts can advise him and
leave the scare tactics and sales pitch to the politicians.
Deke Morisse
Mikado Michigan
- Joseph Joubert
Posted: Tue May 05, 2009 4:54 am Post subject: prop questions |
Sorry to respectfully disagree here Deke but having recently had such issues
drilled into me so that I could get my Repairman's ticket I feel I need to.
Any grain crack or evidence of delamination in a wooden structure in an
aircraft application is reason to ground the aircraft until it is replaced,
especially in a prop. Nicks and dings to a certain size, with no evidence of
damage to grain or lamination, can be sanded and re-coated. In class we had
to evaluate actual rejected wooden parts to try and find the defect, some
were really hard to find.
Any grain crack or delamination in a prop blade can quickly propagate to the
hub with catastrophic results. No inspector would let an airplane fly with
that kind of defect, not even to get home.
I was the orignal reply to Jerry's question - recommending he send the
blades back to the manufacturer for inspection and replacement as necessary
and I stick by that, but as an inspector I would stamp that aircraft as
non-airworthy. It's not scare tactics, it is an FAA requirement.
Wrightsville Pa
dave
Posted: Tue May 05, 2009 6:12 am Post subject: Re: prop questions |
Deke, Get the chip off your shoulder eh !!
this is a safety issue, A GSC prop from 1987 is 22 years old man. Might work fine, but it way past TBO .
When you call it scare tactics ? What the heck that mean that you a moderator and will not let others speak the truth and facts?
I SELL PROPS, I promote safety as well. Prop departure is scary, I have first hand experience in flight do you ?
When was your last prop failure> ?
Dave < -- Facts from 3 decades of aviation not from the armchair .
| Fox5flyer wrote: | I fail to see what a small crack in the tip of a (as yet type unknown) prop
Deke Morisse
Mikado Michigan
- Joseph Joubert
Paul A. Franz, P.E.
Posted: Tue May 05, 2009 10:48 am Post subject: prop questions |
On Tue, May 5, 2009 5:06 am, fox5flyer wrote:
Whoa! You sure got a couple violent responses to this posting! Who'd have known? I
agree with your assessment for the most part though.
Comments were made suggesting this prop was beyond TBO. Hmmm, I'm not convinced there
is a TBO per se, for wood props and hubs. TBO on props usually applies to ones with a
pitch control mechanism. Maybe that "5 years, 5 hundred hours" condition that's stated
for GSC is applicable.
Unless there is something you'd judge would cause that prop to have its tip crack
grow, I agree that it's probably OK to fly on. But if the crack is due to a tip
strike, that might mean the base has been weakened. If the crack is due to picking up
gravel and damaging the finish, it is likely repairable. Several techniques can be
used to force epoxy into the crack. Just like you can seal cracks in a windshield, you
can force epoxy into a crack. My guess is that there has to be a pretty tight finish
intact all around the injection point for it to work though.
If you were the factory and your advice could subject you to liability, how would that
temper your response? I might be inclined to utter in a knee jerk reaction - 'we
better get out of this business before the lawyers bankrupt us'. Some one else might
react with a less fearful approach. Maybe, lets have a look before we tell them we
can't stand behind any repairs made to this old propeller. Yet another might be, let's
carefully inspect the bases and evaluate whether or not we can repair the cracks at a
lesser cost than replacing one or all of the blades.
If the subject prop is a GSC, getting them in the loop seems to me will get you on the
right track and you'll be relieved at knowing just what you're supposed to do.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
"The ideal tyranny is that which is ignorantly self-administered by its
victims. The most perfect slaves are, therefore, those who blissfully
and unawaredly enslave themselves. A truth's initial commotion is
directly proportional to how deeply the lie was believed. It wasn't the
world being round that agitated people, but that the world wasn't flat.
When a well-packaged web of lies has been sold gradually to the masses
over generations, the truth will seem utterly preposterous and its
speaker a raving lunatic."
-- author Dresden James
_________________ Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Fox5flyer Guest
Posted: Tue May 05, 2009 12:34 pm Post subject: Re: prop questions |
Bob, thanks for the respectful response. If you go back and read both of my emails I think you'll see that we were saying the same thing. I was recommending that Jerry go direct to the manufacturer for their opinion on the best course of action. I did not recommend that he fly the airplane, nor would I ever do that. More than likely GSC (if it was a GSC) would ask him to send in his blades for inspection and may either recommend a new blade or all three. I said this because it is very easy to give personal advice to someone over the internet when you don't have to live with the result.
Deke
(The armchair pilot with 1500+ hours mostly TD)
Oh, yeah. I flew two hours this morning down to Midland MI and back. Had lunch with a cutie and had smooth air both directions. Doesn't get much better.
| matronics(at)bob.brennan. wrote: | Sorry to respectfully disagree here Deke but having recently had such issues
Wrightsville Pa
Posted: Tue May 05, 2009 1:11 pm Post subject: prop questions |
Deke,
I absolutely agree with you on returning the blades to the manufacturer and
yes we were saying the same thing, I just wanted to add a bit of gravity to
the advice. I know we are experimental pilots and can do as we please, but
as a certified inspector I would reject a wood prop blade with a crack for
use without question, other than hung on a wall with a clock in it.
I will also respectfully disagree with Paul Franz (sorry Paul!) who agrees
with us "for the most part". Wood has grain and laminates, that once
separated can easily split along that separation. Using epoxy on the split
is like using epoxy on a small crack in a piece of glass. Despite the epoxy
the strength has been compromised and pressure on the surface could easily
propagate the crack or split, epoxy will not stop it. As I said earlier -
epoxy is a good fix for dings and dents and nicks in wood, but unacceptable
as a repair to a grain or laminate split.
Wooden propeller inspection requirements and repair procedures can be found
in detail in FAA document AC 43.13-1B - "Aircraft Inspection, Repair &
Alterations. Acceptable methods, techniques & practices".
And Paul if there are any aircraft part manufacturers out there that behave
like you described in your "If you were the factory and your advice could
subject you to liability..." response I would steer well clear of them, but
I don't personally know of any wood propeller manufacturer that in any way
fits your description so I don't think we should be trying to scare list
posters away from working with the manufacturers.
Wrightsville Pa
Lynn Matteson
Posted: Tue May 05, 2009 2:11 pm Post subject: prop questions |
Better to be out flying than to sit at the computer making the
accusations fly, eh, Deke? Too bad I didn't know about your flight to
Midland....I and two other planes flew up to Mt. Pleasant for
lunch....hell, that's only 25 miles apart. Coming back was a bit
bumpy though.
Lynn Matteson
Jabiru 2200, #2062, 644.7 hrs
Sensenich 62x46 Wood prop
Status: flying
On May 5, 2009, at 4:34 PM, Fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
result.
Deke
> such issues
> need to.
> in an
> replaced,
> evidence of
> class we had
> defect, some
> propagate to the
> fly with
> the
> necessary
> aircraft as
> Wrightsville Pa
http://forums.matronics.com/viewtopic.php?p 42820#242820
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Tue May 05, 2009 4:13 pm Post subject: prop questions |
Lynn, my friend. Even if I'd known that your lameness was nearby I probably
wouldn't have met up with you anyway. I had something much better going on!
When I took off from Midland about 1500 it was a little bit choppy, but
after climbing out to 3500 it smoothed right out and stayed that way until I
got home. Even had a small tailwind.
Life is good!
Deke
Subject: Re: Re: prop questions
lunch....hell, that's only 25 miles apart. Coming back was a bit bumpy
though.
Lynn Matteson
Status: flying
> Deke
> much better.
>> issues
>> to.
>> replaced,
>> evidence of
>> had
>> some
>> to the
>> with
>> necessary
>> Wrightsville Pa
Float Flyr
Posted: Tue May 05, 2009 4:50 pm Post subject: prop questions |
It all depends on the crack... but I second your opinion that the only ones
to consult on it are the manufacturers of the blades.
Cheers
Noel
Getting closer to getting the 912 in the air
Kitfox III-A
Float Flyr
Posted: Tue May 05, 2009 4:53 pm Post subject: prop questions |
Perhaps it's the scary tone that Deke doesn't like... but as you say, it is
scary! Like most on the list I would not fly with it until it has been
passed by the manufacturer. Now ask me if I think the manufacturer would
pass it... not a chance.
Noel
Kitfox III-A
Float Flyr
Posted: Tue May 05, 2009 5:02 pm Post subject: prop questions |
Per se??? I don't know about pre-se but I sure know about what is written
on the manufacturers home page. Sure there is no way the manufacturer can
make you take the prop off your plane but how smart would it be to fly it
knowing the guy who designed and built it thinks it has not been safe for
many years and you can see potential catastrophic damage to it.
I'm not trying to scare the heebie geebies out of any one just to say it as
it is. If you think the blades can be restored send them back to GSC for
evaluation and rebuilding. If not enjoy a nice fire.
Noel
Kitfox III-A
