RV6-List:
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
robertrv607(at)yahoo.com
PostPosted: Tue May 05, 2009 12:38 pm    Post subject: RV6-List: Reply with quote
Scott:
thanks for the info. You said you would not trust, any attachment with nut plates...
why? I assure you that nut plates is the best for anything...
The only thing is the work involved on Fiberglass, you would have to reinforce the area
etc... that is why I wanted to know a different way..
robert
rv6a
--- On Tue, 5/5/09, Smcm75(at)aol.com <Smcm75(at)aol.com> wrote:
Subject: Re: RV6-List:
To: rv6-list(at)matronics.com
Date: Tuesday, May 5, 2009, 2:19 PM
In a message dated 5/5/2009 9:50:23 AM Eastern Daylight Time, maurice609(at)live.com writes:
fairings, is any way, without using plate nuts
I used high quality sheet metal screws placed about every 3" with a dab of RTV on the tip. Start out with #4x1/2" if the hole starts to open up and the screw losens move up to the next size. I have 150 hrs. on my original screw set without having to replace any of the originals. I wouldn't trust any method of fairing attachment than nut plates and/or sheet metal screws.
Scott Morrow
A Good Credit Score2931x1201367171/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=115%26bcd=May5509AvgfooterNO115>See yours in just 2 easy steps!
=nofollow target=_blank>http://www.matronics.com/Navigator?RV6-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
- The Matronics RV6-List Email Forum -
ronlee(at)pcisys.net
PostPosted: Tue May 05, 2009 3:34 pm    Post subject: RV6-List: Reply with quote
I think he meant OTHER Than nutplates or screws.
Ron
Smcm75(at)aol.com
PostPosted: Tue May 05, 2009 4:29 pm    Post subject: RV6-List: Reply with quote
In a message dated 5/5/2009 7:35:17 PM Eastern Daylight Time, ronlee(at)pcisys.net writes:
I said that I wouldn't trust any attachment WITHOUT NUT PLATES OR SCREWS unless you want to bond them on to the skin or rivet them. That will make them a little difficult to remove.
Scott
A Good Credit Score is 700 or67171/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=115%26bcd=May5509AvgfooterNO115>See yours in just 2 easy steps!
PostPosted: Fri May 08, 2009 5:52 am    Post subject: RV6-List: Reply with quote
OK   thanks
Maurice
Date: Tue C 5 May 2009 20:27:40 -0400
In a message dated 5/5/2009 7:35:17 PM Eastern Daylight Time C ronlee(at)pcisys.net writes:
You said you would not trust C any attachment with nut plates
Scott
ronics.com
Insert movie times and more without leaving HotmailŪ. See how.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
