Tundra tires
lowflyer
PostPosted: Mon Jun 01, 2009 8:20 am    Post subject: Tundra tires Reply with quote
Has anyone put the Goodyear 26" tundra tires on their Kitfox? If so, how did you like them? They are made for the blimp operations and I have heard they are pretty stiff even with low pressure. You also have to be careful with really hard breaking because you can rotate the tire on the rim and can snap the valve stems off the tube. They also weigh about 22lbs each. That's 44lbs of tires. Is this worth it?
I would also appreciated any comments on 8.00x6 and 8.50x6 tires as well.
Also, Alaskan Bushwheel is now making a 26" and 29" tire for light sport aircraft that are lighter then the regular ones the produce. They are called Airstreaks. Anyone have any experience with these tires or the regular Bushwheels?
Any feed back would be great.
Chris...
2000 Model IV Speedster
Great Planes VW 2180 76hp
260 hours.
Chris Budd
buddcr(at)yahoo.com (buddcr(at)yahoo.com)
jdmcbean(at)kitfoxaircraf
PostPosted: Mon Jun 01, 2009 9:29 am    Post subject: Tundra tires Reply with quote
Chris,
  The Goodyears are nice tires but heavy.
We are a dealer for the Alaskan Bushwheel and have a set of the 26” for our aircraft. They are much lighter.
I know we are working with them to make a tire that is of the same design but a size between the 800 and the 850.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Chris Budd
Sent: Monday, June 01, 2009 10:20 AM
To: KitFox List
Subject: Tundra tires
Chris...
260 hours.
Chris Budd
dcubj3(at)terra.com.br
PostPosted: Tue Jun 02, 2009 6:43 pm    Post subject: Tundra tires Reply with quote
Hi
Each Goodyear 26" tire weight is 23 lbs. (pair is 46 lbs)
What about Alaskan Bushwheel ??
26" Goodyear U$S 520 each
26" Alaskan U$S 1000 each
price difference justify weight difference?
FD
Brazil, SA
PostPosted: Wed Jun 03, 2009 7:47 am    Post subject: Tundra tires Reply with quote
Airsteaks are 20 lbs ea.
Fly Safe !!
John McBean
Ph 208.337.5111
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Francisco Drovetta
Sent: Tuesday, June 02, 2009 8:42 PM
Subject: Re: Tundra tires
Hi
FD
Brazil, SA
----- Original Message -----
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Monday, June 01, 2009 2:28 PM
Subject: RE: Kitfox-List: Tundra tires
Chris,
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
To: KitFox List
Chris...
260 hours.
Chris Budd
http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
- Release Date: 06/01/09 06:09:00
5
6
7
8
9
