maurice609(at)live.com Guest
Posted: Mon Jun 08, 2009 5:25 pm Post subject: on Ailerons |
Hi:
My RV6a is now painted C the elevators had to be re balance C now I am aligning the Ailerons.
Iadjusted the rods C so that both ailerons are perfectly aligned with Flaps/and Wing tips. stick C Vertical
and center. Al this was done...there is no play that I can feel or hear...
So C on the ground everything is well....but C when flying C I notice C ailerons are not aligned C when
flying straight and level..there is a difference of about 1/4' C on each side...
I cannot understand... I called Van's they did not understand my question C or do not know what to do..
Any suggestions C ideas? Everything was perfect before paint...
Again C everything looks and feels C aligned...on the ground..
thanks for comments
maurice
rv6a
Windows Live™ SkyDrive™: Get 25 GB of free online storage. Get it on your BlackBerry or iPhone. [quote][b]
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
c.ennis(at)insightbb.com Guest
Posted: Mon Jun 08, 2009 8:23 pm Post subject: on Ailerons |
Maurice,
If the misalignment is with the flaps..it's not unusual for the flaps to position slightly higher in flight then on the ground, due to lifting loads. Having said that, as long as the flaps/wings are symmetrical during flight I wouldn't worry about a slight misalignment. But that's me, I gave up on perfection while building my 6A and decided to settle for the best I could do. As an aside, lifting loads will also remove all the slack from the ailerons and possibly cause a slight misalignment with the wing tip trailing edge.
I hope this helps.
Charlie Ennis
