ATV tundra tires
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
Dub
PostPosted: Wed Jun 10, 2009 9:40 am    Post subject: ATV tundra tires Reply with quote
XXX
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
K5YAC
PostPosted: Wed Jun 10, 2009 11:44 am    Post subject: Re: ATV tundra tires Reply with quote
That sounds cool. What a neat vision your comment just put in my head. Big fat ATV tires would look kind of cool... and I would think that with ATV racing, there should be some strong and lightweight wheels out there with decent braking systems.
Side load issues perhaps?
Mark Chouinard
Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear
www.mykitlog.com/k5yac
http://www.westcoastpiet.com/images/Mark%20Chouinard/pictures.htm
bcharvet(at)bellsouth.net
PostPosted: Thu Jun 11, 2009 4:40 am    Post subject: ATV tundra tires Reply with quote
I'm flying around in a cub yellow Baby Ace right now, and frequently fly
over woods, etc. Having the aircraft in a brighter color than olive
drab could make it easier for someone to find you in an off-airport
emergency. I also carry one of the new Spot GPS transmitters that is
quite comforting. Depending on the terrain you will be flying over, you
might want to think twice about camouflaging your Piet. Just a
thought. It would look pretty nice painted up as an observer and I
entertained the same thoughts earlier in my build before I started
flying again.
Ben
I plan to color mine up in OD Green with Allied Forces invasion stripes on the wing. Big fat ATV tires would look kind of cool... and I would think that with ATV racing, there should be some strong and lightweight wheels out there with decent braking systems.
Mark - working on wings
http://forums.matronics.com/viewtopic.php?p 47600#247600
K5YAC
PostPosted: Thu Jun 11, 2009 6:27 am    Post subject: Re: ATV tundra tires Reply with quote
Yep, good idea.
I edited my post prior to your reply because I'm really not 100% sure on the finish, but... I am an 82nd Airborne Division veteran and to me, everything looks better in OD Green. Besides, how can I strafe trains and supply routes with an observer paint scheme? Ok, ok... just kidding.
Mark Chouinard
Catdesigns
PostPosted: Thu Jun 11, 2009 7:08 am    Post subject: Re: ATV tundra tires Reply with quote
Take a look at Ty Daniels wheels on his Pietenpol. I believe he used ATV tires and rims. Typically, the knobs are cut off and the tire sanded smooth. Sounds like a lot of work but looks really good.
http://www.westcoastpiet.com/new_page_54.htm
I think there was a drawing of an adapter plate for ATV rims in one of the old BPA newsletters. I will try to dig it out tonight and scan it.
Chris
Chris
Sacramento, CA
WestCoastPiet.com
kirkh1(at)gmail.com
PostPosted: Thu Jun 11, 2009 7:19 am    Post subject: ATV tundra tires Reply with quote
Also check photos for Leon Stephan's Piet at
http://mykitplane.com/Planes/photoGalleryList2.cfm?AlbumID 82
On Jun 11, 2009, at 10:08 AM, Catdesigns wrote:
<Catdesigns(at)att.net>
scan it.
Chris
Chris Tracy
Sacramento, CA
WestCoastPiet.com
http://forums.matronics.com/viewtopic.php?p 47683#247683
conceptmodels(at)tds.net
PostPosted: Thu Jun 11, 2009 9:17 am    Post subject: ATV tundra tires Reply with quote
Speaking of camouflage, my Piet, (see cover of current BPA News
letter) NX20795 has those orange stripes painted on the wing because
the plane blended in with the Iowa landscape and couldn't be seen by
other aircraft flying above it especially in the spring and fall.
Of course, now flying in green Wisconsin, it's not a problem.
Roman Bukolt, NX20795
fly over woods, etc. Having the aircraft in a brighter color than
olive drab could make it easier for someone to find you in an off-
airport emergency. I also carry one of the new Spot GPS
transmitters that is quite comforting. Depending on the terrain you
will be flying over, you might want to think twice about
camouflaging your Piet. Just a thought. It would look pretty nice
painted up as an observer and I entertained the same thoughts
earlier in my build before I started flying again.
Ben
> head.
K5YAC
PostPosted: Thu Jun 11, 2009 9:43 am    Post subject: Re: ATV tundra tires Reply with quote
Alright, point taken... but if someone can't see invasion stripes floating over tree tops, they need to work on their scan.
Crap, someone turned of the "img" feature... gotta do it the old way I guess.
 Filesize:  48.11 KB
 Viewed:  1352 Time(s)
Mark Chouinard
zharvey(at)bentoncountyca
PostPosted: Thu Jun 11, 2009 3:55 pm    Post subject: ATV tundra tires Reply with quote
Ben. I also fly with the SPOT transmitter and it is comforting. Well worth
the price.
Gene
Catdesigns
PostPosted: Fri Jun 12, 2009 8:36 pm    Post subject: ATV tundra tires Reply with quote
I scanned the drawing for the adapter plates that was in the old BPA
newsletter. It is for wheel rims that came on the Kitfox not ATV rims. I
tried looking up the company in the article and they don't seem to be in
business anymore. I bet you could figure something out like this for ATV
wheels or other rims. The other interesting par of the article is the
weight of his landing gear, 17.6 pounds. That is the finished weight for
one side including the V's. Wow! Just one of my wheels weigh 18 pounds and
that does not include the wood or axel. If you want to save weight go with
the steel gear.
Chris
Sacramento, CA
WestCoastPiet.com
Wheel_hub.PDF
Download
 Filename:  Wheel_hub.PDF
 Filesize:  55.33 KB
 Downloaded:  105 Time(s)
Chris
Sacramento, CA
WestCoastPiet.com
rameses32
PostPosted: Sat Jun 13, 2009 6:35 am    Post subject: Re: ATV tundra tires Reply with quote
That picture brings tears to my eyes, in 1992 I had a chance to buy a C47 in flying condition for $50,000. I didn't have the money then, and there is now way of picking one up that cheap ever again.(Sniff, sniff)
Charley
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
