		vince(at)devonwindmills.c Guest
				 Posted: Mon Mar 27, 2006 9:20 am    Post subject: a stall between 2 fools |
				Dear Pat,
             Do I read you right, you are flying tandem monoplanes ,flying fleas. and canards.? Unfortunately all my life Ive flown proper aeroplanes either with a tail or no tail atall, The only feature that stops them diveing to the ground is either a CofG beyond aft limits ,or the down force aerodynamically generated at the back of the whole caboodle.The tail is behaving like an upside down wing, that is why it is symetric,or flat on top,If it stops sucking down the tail goes up, and the nose goes down, It can stall ,but does so in the upside down sense.Or are you pulling my willy??
                 Vnz Wilyflier
 Vince Hallam
 please phone rather than email for best results!
 07941 313141
 01803 316191
 www.devonwindmills.co.uk
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		pj.ladd(at)btinternet.com Guest
				 Posted: Mon Mar 27, 2006 12:42 pm    Post subject: a stall between 2 fools |
 symetric,or flat on top,>>
 Hi Vince,
 sorry but if it is symmetric the bottom must be like the top, which is flat.
 To generate lift we need a curved surface which the tail plane patently does
 not have.
 In theory the tail plane is not needed on a properly balanced aircraft
 except to interfere with the airflow to enable the pilot to change direction
 or correct for unstable air.
 I still think the VG`s merely stop the boundary layer from breaking away and
 would still like to see some smoke or tuft tests in a wind tunnel.
 By the way, where did you get this Flying Flea stuff from?  I did actually
 see one when I was a kid and was very impressed as what kid woudn`t have
 been. However they were banned in the UK after a few crashes and the many
 planes which were being built in garages all over the place were never
 finished. The problem was that the plane would get into an irrecoverable
 deep stall. They continued to fly on the Continent however and still do
 though the grandson (I think) of the original designer has produced an
 updated but still pretty idiosyncratic replacement. Several usually fly from
 France to the UK in the Spring for our main ultralight gathering. They are
 rather like the deux chevaux car. Very French.
 Cheers
 Pat
		a58r(at)verizon.net Guest
				 Posted: Mon Mar 27, 2006 4:35 pm    Post subject: a stall between 2 fools |
				"sorry but if it is symmetric(al) the bottom must be like the top,
 which is flat.
 patently does
 not have."
 Mirable scriptu! No lift from a flat plate? Next, the battle of
 Bernoulli vs Newton, or who lifts yer wing?
 regards,
 Bob N.
		Steven Green
				 Posted: Mon Mar 27, 2006 4:54 pm    Post subject: a stall between 2 fools |
				And paper airplanes can't fly!
  _________________ Steven Green |
		Kirk Smith
				 Posted: Mon Mar 27, 2006 5:12 pm    Post subject: a stall between 2 fools |
				which is flat.
  	  | Quote: | 	 		   To generate lift we need a curved surface which the tail plane
  patently does
  not have."
 Unless we bend it in the middle......
				 Posted: Mon Mar 27, 2006 5:40 pm    Post subject: a stall between 2 fools |
 Steven G:
 Nor a sheet of plywoood.
 DO NOT ARCHIVE
  _________________ John Hauck
Titus, Alabama |
		Ed in JXN
				 Posted: Mon Mar 27, 2006 11:05 pm    Post subject: a stall between 2 fools |
				And Langewiesche is flippin' over about now, too.
 Ed in JXN
 Do not archive.
				 Posted: Tue Mar 28, 2006 5:01 am    Post subject: a stall between 2 fools |
				Mirable scriptu! No lift from a flat plate? Next, the battle of  Bernoulli
 vs Newton, or who lifts yer wing?>>
 Zounds and forsooth!.What have I got myself into?
 Nevertheless, I will try to fight my corner.  Yes, a flat plate, say held
 out of the car window at an angle, will deflect a flow of air and produce an
 opposite force. Held at zero angle of attack it will not. An airofoil
 section  at zero AoA, WILL produce lift.
 In each case the lift is produced by changing the direction of the airflow
 The tail plane I contend acts like the flat plate and exerts no force until
 the elevator is moved. Then the tailplane and elevator, considered as one,
 take on a roughly airofoil shape and it is this which produces the `lift`,
 deflects the airflow and the resultant force moves the tail up or down. In
 the case of the rudder, which no one normally reckons as producing lift the
 same thing turns  right or left. The rudder after all is only a tailplane
 turned through 90 degrees.
 I can hear the bell going for the second round already. Ding ding!
 Cheers
 Pat
		Ed in JXN
				 Posted: Tue Mar 28, 2006 7:59 am    Post subject: a stall between 2 fools |
				Hi Pat,
         I'd guess Bob's statement of "No lift from a flat plate? Next, the
 battle of  Bernoulli vs Newton, or who lifts yer wing?" was meant
 tongue-in-cheek.  Lift does not need an "airfoil shape" to be produced, only
 relative wind and angle-of-attack.  In a tornado, do not houses and other
 large, previously unairworthy objects fly?  I would heartily disagree with
 your statement, "Then the tailplane and elevator, considered as one, take on
 a roughly airofoil shape and it is this which produces the `lift`, deflects
 the airflow and the resultant force moves the tail up or down."  The
 elevator in this case can be said to deflect the air (Newton) more than it
 creates an airfoil with the horizontal stab (Bernoulli).  Combinations of
 principals like these explain why aerobatic aircraft with fully-symmetrical
 surfaces are able to fly.
         I would hold that there are no absolutes in aerodynamics theory,
 only combinations of known principals.
         Where's Topher when you really need him??
 Ed in JXN
 Do not archive.
				 Posted: Tue Mar 28, 2006 8:37 am    Post subject: a stall between 2 fools |
				I would hold that there are no absolutes in aerodynamics theory, >>
 Hi Ed,
 the way I am struggling to hold up my end of this argument I tend to agree.
 After all, bumblebees are airodynamically not supposed to be able to fly.
 Sorry but I can not agree that because a gale blows your trailer into the
 next State it can be said that it is flying. I am not sure what it is doing
 mind you.
 Regarding the fact that symmetrical wings with no apparent airofoil keep
 high speed fighters in the air I can only assume that they are always at a
 small angle of attack. Then, I would agree that with sufficient power even a
 flat plate will fly.
 I still think that my example of the tail fin not producing any force in
 either direction until rudder is applied is valid, and if that is the way it
 works vertically then the same thing will work horizontally.
 Anyway I am off to sunny Cyprus in the Mediterranean at sparrows fart
 tomorrow and I hope you have all got this sorted out before I return in a
 weeks time.
 Cheers
 Pat
		n79rt(at)kilocharlie.us Guest
				 Posted: Tue Mar 28, 2006 12:25 pm    Post subject: a stall between 2 fools |
 held
 produce an
 airflow
 until
 one,
 `lift`,
 In
 the
 tailplane
 Cheers
 Pat
 <snip>
 Pat you shot down your own argument...your example of the flat plate out
 the car window explains it...even if the elevator is perfectly in line
 with the horizontal stab they are noticeably nose down relative to the
 airflow...so they are indeed generating DOWNFOCE...
 Jeremy Casey
