Wheel Bearing Nut Size
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
ledson
PostPosted: Thu Jun 25, 2009 4:57 am    Post subject: Wheel Bearing Nut Size Reply with quote
I've ordered new tires from Desser and am preparing to put them on. My question is, does anyone on the forum know the size of the wheel bearing nut so that I can buy the correct wrench?
Larry Edson
N4362C
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
aerosiam
PostPosted: Thu Jun 25, 2009 7:20 pm    Post subject: Re: Wheel Bearing Nut Size Reply with quote
Larry
It is a large castellated nut with a cotter pin. It should be just snug to slip the cotter pin thru but not tight. A large adjustable wrench with long jaws works fine. It cannot loosen and tightening it will crush the bearings
Paul
ledson
PostPosted: Fri Jun 26, 2009 4:20 am    Post subject: Re: Wheel Bearing Nut Size Reply with quote
Paul,
Thanks for the information. I was aware of the construction of the system, what I was trying to find out is the dimension of the castellated nut. It appears to be over an inch is size and I would like to buy the correct size wrench so that I don't damage it with an adjustable one.
Larry
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
