-3 degrees flaps
Goto page 1, 2, 3  Next
Strasnuts
PostPosted: Thu Jul 02, 2009 6:28 am    Post subject: -3 degrees flaps Reply with quote
I have read countless archives on the flap "up" position. I am still trying to get the wingtips flush with the aileron and flap in the "up" position. My question is: What is the -3 degree from? The top skin? Right now when my flaps hit the stops (rear spar contact) the flaps are symmetrical but greater than -3 degrees, more like -4. For the ones flying, what stops the flaps in the up position? The spar or the flap motor?
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rene(at)felker.com
PostPosted: Thu Jul 02, 2009 7:15 am    Post subject: -3 degrees flaps Reply with quote
Mine were over 3 degrees. I did not measure them when I built the wings.
Just put them up to the stop and lined up the aileron and wingtip. I had a
heavy left wing during my phase one, that is when I checked. Left and right
wing were a little different. So I fixed that, and it helped resolve my
heavy wing. But, in the end the heavy wing is more of a factor of fuel load
and single fat pilot...........as long as I use the left tank first when I
am solo.....no problem. I went out the other day with 24 in the right tank
and 30 in the left...solo and guess what....heavy left wing.......
Rene' Felker
RV-10 N423CF Flying
801-721-6080
bcondrey
PostPosted: Thu Jul 02, 2009 7:39 am    Post subject: -3 degrees flaps Reply with quote
Alignment instructions are in section 44 of the plans (page 44-5).
Without the flaps attached you position the flap motor to the fully up
(reflex) position. Then you position the flaps in the fully up position
defined as when they stop against the rear wing spar doubler. You then
attach the pushrods connecting the flaps.
So, real answer is that the flap motor limit is aligned to match up with
the flap hitting the rear wing spar doubler. Wingtips can be a
challenge - it's actually easier to wait until the wings are attached to
the plane, flaps are attached and aligned. Then align the ailerons to
flaps and clamp in place - at this point and finally make any
adjustments to the wingtips. Make sure when you do this that you have
the elevators in neutral alignment. There's a slight (1/4" or so)
movement of the ailerons as you move the elevators from full up through
full down due to the geometry of the aileron to stick attach linkage.
Bob
N442PM (flying)
Strasnuts
Thanks, I will leave the flaps at the stops and center the ailerons and
wingtips to that position.
Rene, I would still like to see your RV. I am out of OGD a lot in the
citation. My tail number is N458MT.
If you see me out there stop by. I always use Kemp Jet on the south side.
Sean
780 Hours
SuperSTOL 60 hours
Tim Olson
PostPosted: Thu Jul 02, 2009 7:54 am    Post subject: -3 degrees flaps Reply with quote
The spar stops the flaps, but, you then need to adjust the
motor so it shuts off immediately before the flap hits the
spar so the motor doesn't keep running.
That should give you somewhere around -3 degrees.
Tim Olson - RV-10 N104CD
the flap motor?
-------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 FUEL
TANKS N801VR reserved
http://forums.matronics.com/viewtopic.php?p 51125#251125
dmaib@me.com
The -3 degrees is relative to the chord of the wing and is nothing
you can adjust. Follow the instructions and do what you are doing.
Align the ailerons with the flaps, with the flaps up to the stops,
and then align the wingtips with the ailerons. As I recall, the
important part was getting someone to help push the wingtip securely
into position and hold it while drilling.
exactly $.02 worth.
David Maib
40559
the flap motor?
Cust. #40936
A&P, ATP
RV-10 FUEL TANKS
N801VR reserved
David Maib
RV-10 #40559
New Smyrna Beach, FL
Strasnuts
PostPosted: Thu Jul 02, 2009 8:13 am    Post subject: -3 degrees flaps Reply with quote
Thanks everyone. A unanimous answer!!
I get to start on my fuselage today! Smile)))))
780 Hours
SuperSTOL 60 hours
jesse(at)saintaviation.co
I second the recommendation to fit the wingtips when the wings are on
the plane. This way full up on the flaps will be against the rear
spar doubler and the bottom skin on the flap should be flush with the
bottom skin on the fuselage. Then you can "clamp" the aileron flush
with the flap and fit the wingtip to the aileron. It is also very
important, as Bob mentioned, to have the elevator installed and in
neutral.
This brings up another question. Has anybody else been installing
their wingtips with hinges instead of the screws? I remember it was
in an RVAtor a couple of years ago. It really works well and makes
the wingtip a TON easier to take off and put back on.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
position
then
with
attached to
through
Bob
N442PM (flying)
robin1(at)mrmoisture.com
PostPosted: Thu Jul 02, 2009 8:32 am    Post subject: -3 degrees flaps Reply with quote
BTW when I retract the flaps all the way up 30 minutes into the flight
the plane flies faster.
Robin
jeff(at)westcottpress.com
PostPosted: Thu Jul 02, 2009 9:11 am    Post subject: -3 degrees flaps Reply with quote
It's observations like this that make this list such a valuable asset.
Robin
jcumins(at)jcis.net
PostPosted: Thu Jul 02, 2009 9:26 am    Post subject: -3 degrees flaps Reply with quote
I second that completely!!!!
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
bcondrey
PostPosted: Thu Jul 02, 2009 9:35 am    Post subject: -3 degrees flaps Reply with quote
Another tidbit - when I flew with Alex D. last year for transition
training he demonstrated that the takeoff roll will increase by a couple
hundred feet if you've got the flaps in reflex instead of 0 degrees.
Bob
dlm46007(at)cox.net
PostPosted: Thu Jul 02, 2009 9:43 am    Post subject: -3 degrees flaps Reply with quote
The aircraft was designed to be flown in cruise with reflexed flaps; why
would anyone cruise with partial flaps? My flaps are selected full up
shortly after takeoff. Any hanging flap just increases lift by increasing
angle of attack and thus increases induced drag; hence lower airspeed for a
given power setting.
rene(at)felker.com
PostPosted: Thu Jul 02, 2009 9:49 am    Post subject: -3 degrees flaps Reply with quote
I am not out there much these days, but.......Friday and Saturday morning I
will be out there giving flights to people I have promised.....any chance
you will be around then?
I am in hanger S-525, a couple of rows south of the tower...
Rene' Felker
RV-10 N423CF Flying
801-721-6080
dave.saylor.aircrafters(a
PostPosted: Thu Jul 02, 2009 9:56 am    Post subject: -3 degrees flaps Reply with quote
You shouldn't stall the flap motor.  It should get to the end of its travel and keep running (some shut off with a position switch, but the concept is the same).  The bottom of the flaps should be even with the belly when they are all the way up.
On Thu, Jul 2, 2009 at 7:28 AM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
--> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
drfred(at)suddenlinkmail.
PostPosted: Thu Jul 02, 2009 10:14 am    Post subject: -3 degrees flaps Reply with quote
Alex had me use about 5 deg down for takeoff. Works well. You still
have to remember to put them back up. Smile
Dr Fred.
Off to Denver in am.
Bob
Tim Olson
It can help when at high altitudes to keep your
climb rate better, if you maintain zero degrees.
jcumins(at)jcis.net
PostPosted: Thu Jul 02, 2009 11:06 am    Post subject: -3 degrees flaps Reply with quote
Ok here comes my 2 cents worth. Being a retired Flight engineer, we have to
educate you guys about the -3 degree reflex and zero degrees. As it has
been said it is based upon the cord line of the wing.
If you drew a cord line it would be straight from leading edge to the
trailing edge of the flaps with the flaps in the 0 degree position. With
the flaps in the -3 degree reflex position that cord line would bend up 3
degrees starting at the leading edge of the flap.
So the zero degree position gives the wing its original airfoil shape as
designed, and the lift verses drag index is a set reference. Thus higher
lift and same lift area and the drag index is the set amount as designed.
The 3 degree position actually just reduces the drag index by bringing the
aft trailing edge of the wind up and actuallr decreases the amount of lift
at slower speeds. Thus the longer take off roll in the -3 degree position.
But faster cruise speed.
The index of lift vers drag and a very different animal in each airfoil.
All large air frames use slotted follower flaps to extend the wing area
making the amount of lift greatly increased vers the drag index of the take
off flaps position. This can be very confusing to a lot of people and it is
about a week class in aero dytnamics to really understand how the wing area-
lift vers drag and drag index can change greatly with very small amount of
flap movement.
I will be glad to chat with any one off line and help educate any one if
they want a more in detail lesson on this matter.
Have a great and safe flying weekend and 4th of July,
And GOD bless each and every one of you and this great country.
John Cumins
40864 Priming elevators waiting for it to cool off.
Tim Olson
PostPosted: Thu Jul 02, 2009 11:29 am    Post subject: -3 degrees flaps Reply with quote
I'm not sure if you're saying that I'm wrong, or not. Smile
When I said it helps you keep a good climb rate, I was
intending to mean that you get a tiny bit more lift
out of the zero degree setting vs. the -3 degree setting.
So if you're up high over 10,000' and having very
slow climb rates, you can get a small bump in climb
rate by going back to zero. Now, you could also
get a better climb rate at lower altitudes, but, the -10
generally climbs so well that it may be just as
practical to "set it and forget it" once you are climbing
out.
Is that correct from your perspective as a Flight Engineer,
or not?
flap movement.
John Cumins
pitts_pilot(at)bellsouth.
PostPosted: Thu Jul 02, 2009 11:53 am    Post subject: -3 degrees flaps Reply with quote
Why not keep it on the list so the casual reader might learn something
too??? If not, add me to your 'flap' list!!
Linn
John Cumins wrote:
SNIP
John Cumins
Page 1 of 3
