Tail Light (White navigation Light)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
hgmckay
PostPosted: Wed Jul 08, 2009 5:12 pm    Post subject: Tail Light (White navigation Light) Reply with quote
Gentlemen:
I have an Allegro 2000. The rear white navigation light has burned out. This
light is a clear horizontal light attached to the top of the rear vertical
stabilizer, and appears to be in a small glass enclosure about ¾” in
diameter. I have no instructions on how to replace this light. Do I remove
the entire unit, or is there a bulb inside the unit? Unfortunately there are
no instructions on how to do this. Can anyone enlighten me on how to fix
this unit?
Hugh McKay
Allegro 2000
N661WW
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
ledson
PostPosted: Thu Jul 09, 2009 7:38 am    Post subject: Re: Tail Light (White navigation Light) Reply with quote
Hugh,
The taillight on my Allegro 2000 appears to be a LED light. Knowing that LED lights have a service life of thousands of hours makes me wonder if it may be something other that the bulbs failing. I've never removed mine ( there hasn't been the need) so I have no idea on how to remove or service it. I would suggest that you contact Doug Hempstead for guidance.
Larry
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
