Flap actuator
airvair601(at)yahoo.com
PostPosted: Tue Jan 10, 2006 10:18 am    Post subject: Flap actuator Reply with quote
Ok folks I am about to open a can of worms with this question and I do it as a last resort and with several caveats. I need some info about the flap actuator on the XL. My partner and I are HDS builders who, because and for no other good reason than we WANT to, are designing and installing flaps on our HDS. We have designs for electrical and mechanical instillations and are assessing the financial and weight costs for both.
lgingell
PostPosted: Tue Jan 10, 2006 10:51 am    Post subject: Re: Flap actuator Reply with quote
That sounds like the beast. I got my kit from ZAC, and it included a flap motor that had a sticker "Weight: 5lbs" on it, along with limit switches. I believe this same thing may have been/is used on Cessna's too.
It is an "aircraft part" rather than a multipurpose motor, which would explain the cost.
Feels like it weighs more than the rest of my airframe.
I just looked at my parts list, and it is D1450036-3.
..lance (who barley uses his flaps...)
Zodiac XL/Jab 3300
http://lancegingell.com
nfivesl(at)yahoo.com
PostPosted: Tue Jan 10, 2006 11:05 am    Post subject: Flap actuator Reply with quote
Phill:
I'm a plans builder and used a Warner Electrak 1,
linear actuator that seems to work well although I
haven't made my first flight yet. The following
series of pictures should help you see what I did as
well as show a part number you can read from the
photograph. It was pretty simple to get the geometry
right so that it uses up all the travel. I prefer
this actuator over the one ZAC uses because it has
internal limit switches. This is why you want it to
use up all the travel in both directions. It goes to
full travel in about 6 seconds.
http://www.cooknwithgas.com/11 21 04 Flaps.JPG
http://www.cooknwithgas.com/11 21 04 Flaps2.JPG
http://www.cooknwithgas.com/11 27 04 Actuator.JPG
http://www.cooknwithgas.com/11 17 04 Actuator.JPG
I have other photographs posted on my "Fuselage" page
of this installation. Send me a private email if you
have further questions.
Scott Laughlin
601XL / Corvair
working on FWF
601zv(at)ritternet.com
PostPosted: Tue Jan 10, 2006 11:14 am    Post subject: Flap actuator Reply with quote
The XL actuator I received from ZAC has that part number, is a Commercial
Aircraft Products item, and weighs 71.1 ounces.
