daseitz(at)cfl.rr.com Guest
Posted: Sat Apr 01, 2006 1:29 pm Post subject: 914 Oil pressure |
My 914 has developed a fluctuation on the oil pressure gauge recently. I
have a UMA 1 1/2" gauge with the rotax sender. The gauge is very sensitive
and will fluctuate wildly sometimes. I tried another sender with same
results. No wiring problem found anywhere. Today I installed a mechanical
oil pressure gauge to see what it did. While flying it does fluctuate a
little, not wildly like the electric probably due to the dampening effect of
the very small diameter long oil line going to the gauge. It looks like the
problem is in the oil system not the gauge.
Has anyone had this kind of bouncing of the oil pressure in their 914?
What did you find was the cause?
Dean Seitz
N284A XS Tri 914 Airmaster CS
Ivor Phillips
Posted: Sun Apr 02, 2006 4:16 am Post subject: 914 Oil pressure |
Hi Dean
Check the oil pressure relief valve is not sticking, Or the spring isn't
damaged, At the same time i would change the oil and filter, I would use the
genuine Rotax oil filter, Another possibility is air is being drawn in to
the oil galley, Between the oil tank and pump, Also check the rubber sealing
ring on top of the oil tank.
http://www.ultralightnews.ca/rotax912/912-914oilPump.htm
Oil Filters
Only the Rotax-recommended oil filter (part 825 701) should be used. Only
those filters assure the correct pressure for bypass valve operation. Other
filters have less filtering surface and are not made to withstand the high
oil pressures the Rotax 4-stroke engines operate at.
To be avoided:
a.. Any other filter than Rotax part 825 701. There are no equivalents or
substitutes!
b.. Contrarily to what some rumours would like you to believe, Rotax does
not authorize the use of any other filter!
Subject: 914 Oil pressure
| Quote: | oil pressure gauge to see what it did. While flying it does fluctuate a
of
the
Ivor Phillips
