912ULS Coolant
Tommy Walker
PostPosted: Sun Jul 26, 2009 1:18 pm    Post subject: 912ULS Coolant Reply with quote
Ro-Taxers,
I think most 912 owners in the U.S. use dex cool antifreeze in a 50/50 ratio in their cooling systems.
I have a gallon of Prestone 50/50 premix that states it can be mixed with any glycol type antifreeze.
Is anyone using this brand and do you have any comments about using it?
Tommy Walker in Alabama
Tommy Walker
N25A - Anniston, AL
arno7452(at)bellsouth.net
PostPosted: Sun Jul 26, 2009 1:44 pm    Post subject: 912ULS Coolant Reply with quote
I have a 912ULS that cost about $20,000. Why would you take a chance. Why
not drain it and fill it up with a known antifreeze? Seems like a more cost
effective insurance.
Ken
Roger Lee
PostPosted: Sun Jul 26, 2009 4:34 pm    Post subject: Re: 912ULS Coolant Reply with quote
Hi Tommy,
Most any will work. Only so many ways to make antifreeze. Most that we come into contact with are either propylene or ethylene glycol although there are a few others. Any 50/50 will work. Needs to be silicate free. Some antifreeze's don't mix with DexCool. Make sure that if you use a DexCool antifreeze that you only put something back in that is Dex Cool compatible. Many Rotax engines do come with DexCool. If you need to just top off a low reserve tank then distilled water works best. If you are changing your coolant then flush out any old DexCool before putting something else back in.
Antifreeze is a substance added to a solvent, such as water, to lower its freezing point. Antifreeze is typically added to water in the cooling system of an internal-combustion engine so that it can be cooled below the freezing point of pure water (32 degrees F) without freezing. Ethylene glycol is the most widely used automotive cooling-system antifreeze, although methanol, ethanol, isopropyl alcohol, and propylene glycol are also used. In automotive windshield-washer fluids, an alcohol (e.g., methanol) is usually added to keep the mixture from freezing; it also acts as a solvent to help clean the glass. The brine used in some commercial refrigeration systems is an antifreeze mixture; it is typically a water solution of calcium chloride or propylene glycol.
WHY, because
In particular, alkali metal silicates have been found excellent for protecting aluminum
against corrosion. In glycol-based radiator protectants, however, they tend to form
gels or even to precipitate, so creating a need for special silicate stabilizers.
Examples of constituents of such combinations of active substances include salts of
organic acids which, especially in the form of their alkali metal salts, are efficient
corrosion inhibitors, whereas the free acids are less effective or may even be corrosive.
The incidence of free acids in radiator protectant formulations as a possible result,
for example, of oxidation processes or the ingress of nitrous gases into the cooling
system is therefore highly undesirable. It is for this reason that radiator protectant
formulations contain small amounts of agents known as reserve alkalinity donors
which have a buffer action in the relevant pH range and so prevent the formation
of free acids. Examples of compounds employed as reserve alkalinity donors are
amines and phosphates and, in particular, the less expensive borax. Such corrosion
inhibitor compositions are described, for example, in EP-B-0 229 440 and
EP-A-0 308 037.
Because of the above-described disadvantages associated with the use of silicates as
corrosion inhibitors for aluminum, in recent developments a trend has been noted to
omit them and instead use other active substances. Under these conditions, however,
the reserve alkalinity donor, borax, is highly corrosive, and so can no longer be used.
The use of phosphates in modern-day radiator protectant formulations is likewise
undesirable. This applies to an even greater extent to amines, on the basis of their
characterization as potential nitrosamine formers."
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
PostPosted: Sun Jul 26, 2009 4:53 pm    Post subject: 912ULS Coolant Reply with quote
Hey Rog,
What does one of those nitrosamines look like? I got to check my fluids.
Ken
Tommy Walker
PostPosted: Sun Jul 26, 2009 5:00 pm    Post subject: Re: 912ULS Coolant Reply with quote
Ken,
Thanks for your reply. I was under the impression that Prestone was the most popular anti-freeze in the U.S., but then, what do I know?
Tommy
Do Not Archive.
Ken
Tommy Walker
N25A - Anniston, AL
goodings(at)yorku.ca
PostPosted: Mon Jul 27, 2009 10:36 am    Post subject: 912ULS coolant Reply with quote
We have had only 50/50 Prestone in our 912ULS since October, 2003. There
have been no problems. BUT use the orange variety (premium, or some
such???), not the green variety. An AME told us that there are a lot of
"solids" (?) in the green type, which are not good for the engine.
John and Peter Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto
jay(at)horriblehyde.com
PostPosted: Tue Jul 28, 2009 8:26 am    Post subject: 912ULS Coolant Reply with quote
Perhaps you should ask my mates Mike and James what they used Smile
They are about to arrive at Oshkosh (this afternoon) after having flown from
Johannesburg in South Africa (left Saturday 18th June) and flew non-stop, 20
hours, to Sao Tome, just south of Nigeria; then to Guinea; then a giant hop,
22 hours flying non-stop across the Atlantic to Belem, Brazil; then to
Virgin Islands; then Florida and today en-route to Oshkosh.
They are flying a 2 seater, low winged, Light Sport, 912 engined aircraft
that they designed and built themselves, called the Sling.
When we filled the aircraft up we used whatever we could get at the nearest
service station as long as it was silicate free- we were working practically
around the clock against a deadline at a remote airfield, so no time to get
the exact right stuff...
If you read their logs (see
http://www.airplanefactory.co.za/world/default.asp) you'll see that some
very dodgy mogas was also used- even across the Atlantic
Jay
Jay Hyde
HH Enterprises
Aircraft Manufacture, Engineering and Flying
Mobile phone: 083 300 8675
International: +27 83 300 8675
ronlee
PostPosted: Mon Aug 17, 2009 11:22 am    Post subject: Re: 912ULS Coolant Reply with quote
I have Evans coolant in my 912uls as per Rotax recommendation, unless they have changed. It's been in there for 150 hours and seems to perform well. I live in the desert South West where It is very hot! I have never had to add a drop since new.
Isn't anyone else using Evens coolant in their engines and if they are are, are they having any negative results?
Ron Lee
Tucson, Arizona
Roger Lee
PostPosted: Mon Aug 17, 2009 9:05 pm    Post subject: Re: 912ULS Coolant Reply with quote
Hi Ron,
It's been a while. When are you coming over for breakfast at Ryan? Evans is good, but in some cowling configurations it makes the temps too hot. Evans raises the temps any where from 25F-40F depending on your application. In my Ct it took the temps over max during the warmer months. I had no choice, but to go back to 50/50 or swap coolants out from summer to winter.
Rotax still allows 50/50 you are just supposed to use 248F as a max water temp or you can use the CHT because they are not far off from each other. My oil temps where way to high, too. Evidently your Zenith has good cooling under the cowl. Fully exposed engines do well with Evans.
Roger Lee
Tucson, Az.
Cell 520-349-7056
C_Pickett
PostPosted: Tue Aug 18, 2009 4:13 am    Post subject: Re: 912ULS Coolant Reply with quote
There was a thing on the SeaRey site a while back that Evans is flammable.
Roger Lee
PostPosted: Tue Aug 18, 2009 6:09 am    Post subject: Re: 912ULS Coolant Reply with quote
Evans can burn if brought to a high enough temp. If this gets to this temp then you probably have bigger problems to worry about. If you worry about Evans igniting then what are you going to do about your fuel and oil burning issue. Those are far worse. Even 50/50 will burn. You can and should have your oil, fuel and coolant lines in firesleeve. Usually if Evans burns it is already involved in a fire. There is a small chance if Evans where to hit a hot exhaust pipe in a small enough quantity then it might flame , but does not sustain a flame. IF it burst out all out once like splitting the line then it gets cooled below its ignition temp.
So can Evans burn, yes, but so does everything else under the cowling.
Roger Lee
Tucson, Az.
Cell 520-349-7056
Ollie Washburn
PostPosted: Tue Aug 18, 2009 7:23 am    Post subject: 912ULS Coolant Reply with quote
 I have used Evans for over 500 hrs here in FL. and no problems. Also have never added any.
Ollie
On Mon, Aug 17, 2009 at 3:22 PM, ronlee <rlee468(at)comcast.net (rlee468(at)comcast.net)> wrote:
[quote]--> RotaxEngines-List message posted by: "ronlee" <rlee468(at)comcast.net (rlee468(at)comcast.net)>
Ron Lee
Tucson, Arizona
http://forums.matronics.com/viewtopic.php?p=258243#258243
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Ollie RV6-A & Rans S7S
Central FL
Roger Lee
PostPosted: Tue Aug 18, 2009 7:31 am    Post subject: Re: 912ULS Coolant Reply with quote
Evans is a good product, unfortunately it doesn't work well in all applications. Some of us just can't dump enough heat from under the cowling to keep temps down. Some have very good cooling and Evans would be a very good choice.
Roger Lee
Tucson, Az.
Cell 520-349-7056
rparigor(at)suffolk.lib.n
PostPosted: Tue Aug 18, 2009 8:12 am    Post subject: 912ULS Coolant Reply with quote
Hi C_Pickett (C_Pickett(at)mac.com) " There was a thing on the SeaRey site a while back that Evans is flammable. [url=http://forums.matronics.com/viewtopic.php?p 58393#258393]http://forums.matronics.com/viewtopic.php?p 58393#258393[/url] "I did some testing with burning aeroplane liquids including Evans:http://contrails.free.fr/engine_burn_baby_burn_en.phpAs far as Evans I am going to use it in my 914 install, note though if you have a massave leak it won't be too much of a concern, but a small shooting pinpoint leak aimed at the exhaust will create a pretty impressive continuous fire that a 50/50 leak probably will not.Ron ParigorisOne other interesting fact is shooting oil on hot exhaust will catch fire at a lower temperature than 100LL! [quote][b]
Roger Lee
PostPosted: Tue Aug 18, 2009 3:22 pm    Post subject: Re: 912ULS Coolant Reply with quote
Hi Guys,
Here is some useful info on Evans and 100LL.
I'm a retired HazMat Fire Captain of 28 yeas so the MSDS sheets have been a way of life.
Evans: (boiling point 370F)
Flash point 225F
auto ignition 1054F
Flammable limits 2.6 to 12.5%
100LL:
Flash point -51F
Auto ignition 840F
Flammable limits 1.2 to 7%
I'll take Evans over 100LL.
There are way too many things that burn well and ignite well under the cowl to worry specifically about Evans. How many do a total rubber hose and rubber mount replacement every 5 years?
Roger Lee
Tucson, Az.
Cell 520-349-7056
