Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Sun Aug 16, 2009 10:45 am Post subject: Torque Wrench Extensions |
Well, now that I found my Hartzell installation manual (!), there appears to be a need for a "special" tool that I don't have. Because the bolts for the prop require and "end-wrench" of sorts to tighten, it presents somewhat of a problem when trying to torque them. The manual shows an end-wrench looking thing that has the 7/16" on one end and a 3/8" drive on the other end. I looked though the Craftsman and Snapon web sites, but didn't find anything like this. Where might I buy one?
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
FWF
_________________ Matt Dralle
Posted: Sun Aug 16, 2009 11:52 am Post subject: Torque Wrench Extensions |
I don't know if this will help: Harbor Freight (or Sears etc)has
crowfoot wrenches (94426) and they're on sale right now.
Linn
Matt Dralle wrote:
Thanks!
RV-8 #82880 N998RV
FWF
khorton01(at)rogers.com Guest
Posted: Sun Aug 16, 2009 11:53 am Post subject: Torque Wrench Extensions |
On 16-Aug-09, at 14:43 , Matt Dralle wrote:
| Quote: | Well, now that I found my Hartzell installation manual (!), there
You can cobble together an equivalent device. I used a very short
(about 3" long) combination wrench, a bolt, a washer and nut and some
duct tape. The washer is put over the bolt, then the nut is screwed
on tight. This is used to transfer the torque from the socket on the
torque wrench to the closed end of the combination wrench. Use some
duct tape to secure the socket, bolt, washer, nut and combination
wrench together. Of course you'll need to apply the standard
correction to the torque wrench setting to compensate for the extension.
Kevin Horton
RV-8
Ottawa, Canada
http://www.kilohotel.com/rv8
46.65 KB |
4240 Time(s) |
45.28 KB |
4240 Time(s) |
Kellym
Posted: Sun Aug 16, 2009 3:14 pm Post subject: Torque Wrench Extensions |
Known as a Crow's foot wrench. Craftsman will work. There are folks that
sell lower cost "Hartzell" prop wrenches. Check Avery, Cleaveland, etc.
Matt Dralle wrote:
Thanks!
RV-8 #82880 N998RV
FWF
KCHD |
mrobert569(at)hotmail.com Guest
Posted: Sun Aug 16, 2009 4:41 pm Post subject: Torque Wrench Extensions |
MAC tools has the best one fro this application.
Mike Robertson
[quote] Date: Sun C 16 Aug 2009 11:43:55 -0700
To: rv8-list(at)matronics.com; rv-list(at)matronics.com
Subject: Torque Wrench Extensions
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Well C now that I found my Hartzell installation manual (!) C there appears to be a need for a "special" tool that I don't have. Because the bolts for the prop require and "end-wrench" of sorts to tighten C it presents somewhat of a problem when trying to torque them. The manual shows an end-wrench looking thing that has the 7/16" on one end and a 3/8" drive on the other end. I looked though the Craftsman and Snapon web sites C but didn't find anything like this. Where might I buy one?
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.=======================
Windows Live: Keep your friends up to date with what you do online. Find out more.
Paul Valovich
Posted: Tue Aug 18, 2009 5:43 pm Post subject: Torque Wrench Extensions |
Matt,
I fiddled with the special tool problem for a long time and finally said the hell with it and bought one from Avery. One of those expensive tools that proved indispensible for the five minutes or so it took me to torque the prop bolts. If you can get to Inyokern (IYK) I’ll lend it to you; if you email me your home address I’ll mail it to you.
Paul Valovich
pvalovich(at)dcscorp.com (pvalovich(at)dcscorp.com)
RV-8A N192NM Reserved (again)
bmeyette
Posted: Tue Aug 18, 2009 8:56 pm Post subject: Torque Wrench Extensions |
I'm curious - what was the special tool from Avery? Do you have an Avery part number? I'd like to see what it looks like. I just torqued my MT prop bolts and used a simple 3/8" SD crowfoot on the torque wrench.
brian
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul
Sent: Tuesday, August 18, 2009 9:34 PM
To: rv-list(at)matronics.com
Subject: Re: Torque Wrench Extensions
Matt,
Paul Valovich
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| No virus found in this incoming message. Checked by AVG - www.avg.com 270.13.58/2309 - Release Date: 08/18/09 06:03:00 [quote][b]
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
