Posted: Mon Sep 14, 2009 12:09 pm Post subject: Aztec baffle for Rv-10 |
I am getting an overhauled Aztec Engine (IO-540-C4B5.) and it comes with the baffles. Anyone know if I can use the baffles from the Aztec on a RV-10 even if it meant doing modifications?
thanks!
Pascal
Kelly McMullen
Posted: Mon Sep 14, 2009 3:40 pm Post subject: Aztec baffle for Rv-10 |
I wouldn't bank on it. Baffling above the engine is made to fit the
specific cowling. The Aztec cowl is very bulbous, compared to the RV
cowl. If you don't mind doing a LOT of cutting and fitting, you could
do it, but not a real productive use of your time.
You can of course use the intercylinder baffles on the bottom of the cylinders.
On Mon, Sep 14, 2009 at 12:57 PM, Pascal <rv10builder(at)verizon.net> wrote:
| Quote: | I am getting an overhauled Aztec Engine (IO-540-C4B5.) and it comes with the
thanks!
Pascal
A&P/IA, EAA Tech Counselor
KCHD |
