Need help with desicsion
rvg8tor
PostPosted: Fri Oct 23, 2009 5:25 am    Post subject: Need help with desicsion Reply with quote
I am running a 60 amp alternator in my system and can't decide which way to go with the wire size to the main bus. #8 is good to 57 amps, my max continuous load is 45 amps. If I get right up to the 60 amp load for some reason this will exceed the wire limits, I will also have a 60 am ANL.
Is the #8 wire a compromise or is it just fine, or should I go up to #6? I do have the #6 wire, so it is not a matter of saving $, just the weight, the only thing I would need is some lugs. I bought the #6 wire without really thinking this through. I want to do this the best way possible, not just what will work. So since materials are not the issue which way would you guys and gals go.
Thanks for the help, am I over thinking this!
Cheers
Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor
rjquillin
PostPosted: Fri Oct 23, 2009 6:43 am    Post subject: Need help with desicsion Reply with quote
Cheers
I'll wade into this only to suggest rather than just using the somewhat generic wire capacity tables, dig into Chapter 11 of AC43-13-1B and work it out with actual numbers. What will the IR (voltage) drop be for your proposed run length based on the load, resistance, temperature, altitude, bundling and such of your chosen cable. Is your calculated voltage drop acceptable?
AC43-13 has a suggestion:
b. Voltage Drop in Wires. The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage when the generator is carrying rated current or the battery is being discharged at the 5-minute rate. The tabulation shown in table 11-6 defines the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment ground.
Ron Q.
rvg8tor
PostPosted: Fri Oct 23, 2009 6:55 am    Post subject: Re: Need help with desicsion Reply with quote
Ron,
Good point, I have done the voltage drop with the table in AC43 but have not done the further study of altitude and such. I will work though it, as far as voltage drop with the amps and the cable length #8 is the answer. Thank you for pointing this out.
Mike
Cheers
Ron Q.
Mike "Nemo" Elliott
RV-8A QB (Engine)
longg(at)pjm.com
PostPosted: Fri Oct 23, 2009 7:09 am    Post subject: Need help with desicsion Reply with quote
Mike,
I guess the question is are you feeling lucky or conservative? No, the
wire won't melt down if you get to a 58 amp draw. Tefzel will run hot a
long time before it deteriorates and dissolves the connector and
destroys all your components. If you want to be safe and are not worried
about the few extra ounces, use the #6.
If you want to be a nerd you can buy a micro processor, program the
imbedded code and attach it to a thermocouple sensor on the wire, thus
monitor the temperature for a while. Who's got that much time? We gotta
go fly.
If the #8 suits your load pattern and length calculations, then use it.
I think a common misconception is that if you have a 60 amp alternator,
that the alternator is constantly trying to burn up your 10 amp load
with 60 amps of pressure. The alternator works on demand, so it won't
produce more than you need. Think of it as a throttle. If you demand
more, you'll get more. You could put a 150 amp alternator on there and
run a #8 wire to it. Just depends on demand and the design of your
system.
Remember, it's the voltage that kills you not the amperage. Remove the
VARs and you've got nothing.
Glenn
PostPosted: Fri Oct 23, 2009 7:38 am    Post subject: Need help with desicsion Reply with quote
Assuming that you're alternator b-lead is 4' long,
a 6AWG at 4 mOhms/Ft will drop 60 x .004 x 4 = .96
volts at full load. If your alternator is an externally
regulated device then the regulator senses BUS voltage
instead of B-terminal voltage and it will compensate
for the voltage drop. However, if internally regulated,
the bus will run about 1.0 volts low during full load
operations. In practice, you'd never be able to realize
that loading because loads on the alternator are a
combination of system requirements + battery recharge
currents. For a 14.2v setpoint, a 13.2v bus wouldn't
significantly stimulate the battery to soak up the
joules it would like to have if the bus were actually
higher.
If your alternator is externally regulated, then
voltage drops in the b-lead only limit your minimum
speed for full alternator output . . . which at
take-off or cruise settings is not a limiting
factor.
The trends are moving toward internally
regulated (b-lead sense) and small b-lead feeders
COMBINED with all other wires between the alternator
and battery can stack up voltage drops that will
impact battery recharge performance. This is why
the Z-figures generally show 4AWG or larger for
b-lead feeders . . . and all other fat-wires.
Having said that, unless your battery is seriously
discharged, these simple-ideas in physics have
little perceivable effect on your operations.
Going to the wire tables is not particularly
useful for fat-wire calculations since their
recommendations are based on temperature rises
that generally fall WELL BELOW that which the
wire will tolerate in your airplane. The hard-
hat consideration is for voltage drop under the
worst case conditions. There are additional
voltage drops to be considered for the full-
up system.
Know that automobiles tend to use fat-wires that
are a lot smaller than the aviation community
would find acceptable for meeting design goals.
At the same time, except for a severely discharge
battery, automobiles almost never encounter conditions
that exploit the full capability of the
alternator. I've often suggested that if it
were my airplane and the batteries were up front,
I'd craft all the fat-wire paths with 4AWG welding
cable for reasons that are not readily revealed by
praying over the wire table . . .
rnewman(at)tcwtech.com
PostPosted: Sun Oct 25, 2009 3:16 pm    Post subject: Need help with desicsion Reply with quote
I believe you slipped a zero. 6 awg is 0.4 mOhms per foot so the voltage
drop on 4 feet is just under 0.1 volts.
An easy rule of thumb to remember is 10 awg wire is 1 milliohm per 1 foot,
every three wire sizes doubles the resistance. (so 7 awg would be about 2
milliohms per foot.)
-Bob Newman
mrspudandcompany(at)veriz
PostPosted: Sun Oct 25, 2009 4:47 pm    Post subject: Need help with desicsion Reply with quote
Bob N.,
I believe you slipped in the wrong direction. #7 AWG is larger than #10 AWG
therefore the resistance should be less.
Roger
PostPosted: Sun Oct 25, 2009 5:23 pm    Post subject: Need help with desicsion Reply with quote
oops. I sure did. ,#7 awg would be 1/2 mohm..#13 is 2 mohms . my
bad
-Bob Newman
PostPosted: Mon Oct 26, 2009 12:43 pm    Post subject: Need help with desicsion Reply with quote
voltage drop on 4 feet is just under 0.1 volts.
Oops! Good eye. You're correct.
foot, every three wire sizes doubles the resistance. (so 7 awg
would be about 2 milliohms per foot.)
Yup, wrote about that in several places . . . but
drop to 7 gets you 0.5 mOhm/ft and 6 awg would necessarily
be lower. See:
http://www.aeroelectric.com/articles/wiresize.pdf
Thanks for the heads-up
( -Thomas Paine 1776- )
