Alternator Drive Coupling Failure
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
FlyboyTR
PostPosted: Mon Nov 09, 2009 12:30 pm    Post subject: Alternator Drive Coupling Failure Reply with quote
My engine is an IO-240. I am now on my third Alternator Drive Coupling. This part (635796) is used on many different TCM engines. My engine was originally installed new from TCM. In 2006 and at 271 hours the original coupling failed. The cost of a new TCM coupling was $1,600 at that time. I replaced it with a rebuilt coupling for $450.
Now…254 hours later, the coupling has failed again. New cost is 2K, rebuilt is $525. My engine has to be removed to access the alternator…so this is not only a gross inconvenience…it’s also a costly little part that has a history of premature failure.
TCM tells that it is designed to fail to protect the engine and that failure is normal. OK…THANKS! My alternator has not failed/locked up! However, the couplings continue to fail. My average amperage load is about 6 amps (not much work for a 60 amp alternator). I am typically not switching on/off high amperage loads.
This is a link to my original thread on this problem. There are pictures of the original failed part at the bottom on the thread. http://forums.matronics.com/viewtopic.php?p=77593
Does anyone have any suggestions as to why these parts continue to fail? Is there another alternative? Thanks
Travis
Very Happy
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
