Forced landing in Ohio
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
bryanmmartin
PostPosted: Sun Apr 09, 2006 4:11 pm    Post subject: Forced landing in Ohio Reply with quote
I was planning to fly down to Sun 'N' Fun on the first of April in my
Zodiac. The weather that morning in the Detroit area was crappy so I waited
around until noon. At that time there was a 2000 foot overcast with 3000
foot tops and it had quit raining. The weather south of Ohio was reported as
clear so I decided to take off and see. I flew under the Detroit class B at
about 1500 feet and started to see some breaks in the overcast.
An hour into the flight I was just southeast of the Toledo class C when the
engine suddenly started shaking and lost about 600 RPM. I was about 5 miles
north of Wood County Airport (1G0) so I pulled the throttle and started
gliding towards the airport. All my guages were in the green and the engine
stayed running but very rough. When I got down to about 200 feet above the
ground with nothing but plowed fields and a crowded freeway below me I
realized I wasn't going to be able to glide to the airport. The engine was
still making power so I shoved the throttle back in and managed to get about
200 feet per minute climb rate out of it. It was enough to get me lined up
on runway 18 with a 15 knot crosswind directly from the west. I called up
the unicom and anounced my intentions and then made a safe landing.
After I taxied up to the terminal, I shut it down and got out and started
looking for the trouble. Everything looked OK from the outside of the
engine. No oil or coolant leaks and no appearant damage. I didn't have
enough tools with me to do muc troubleshooting so I barrowed the courtesy
car to go down to the store to buy a spark plug wrench. I finally determined
that I had no compression on the number 1 cylinder and when I pulled that
plug, there was impact damage to the electrode. My preliminary determination
was some sort of valve train failure. Since I couldn't do much to fix the
problem right then and it wasn't fit to fly home, I tied it down for the
night and called to reserve a rental car.
The folks at Wood County treated me very well they even offered to put the
plane in a hangar for the night. One of the instructors was giving a lesson
that day and gave me a ride up to Toledo Express Airport so I could pick up
my rental, saving me the expense of a taxi ride.
I drove the rental home that night and the next day drove up to Midland to
get my trailer and my dad and brother to help me recover the airplane. We
then drove down to Bowling Green to tear down the plane for the haul back
home. The people at the airport let me use put the plane in a hangar to
dissasemble it for the trip back. It's a good thing they did, it was pouring
down rain by the time we got done loading in the trailer. We got the plane
back to my hangar at Ray and got the rental returned to the local depot and
got back to Midland at about 2 AM. Monday evening, I decided to use some of
my frequent flyer miles to complete the trip to Lakeland and let the
airplane wait until I got back.
Today I finally got to my hangar to start tearing down the engine to see
what went wrong. I heard stories about valve guide failures in some of the
EA81 engines so I thought I might find the same thing with mine. It turns
out that the problem wasn't the valve guides. A big chunk of the intake
valve in the number 1 cylinder broke off and did mayhem inside the engine.
The piston had a bunch of holes in it and had several cracks clear across
the face of the piston. The piston skirt must also be all broken up because
you can rock the piston back and forth in the cylinder. There also seems to
be some collateral damage to the intake valve in the number 3 cylinder,
probably by bits of metal getting blown back into the intake manifold. Our
resident engine expert took a look at the valve and decided that it was a
fatigue failure possibly caused by a slight misalignment of the valve. There
is some evidence that the valve was hitting harder on one side of the port
than the other. I've put 145 hours on the engiine since I bought from
Stratus.
I plan on pulling off the other head to check it and will probably send both
of them off to RAM for rebuild.
Bryan Martin
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
Bryan Martin
do not archive.
frank.hinde(at)hp.com
PostPosted: Sun Apr 09, 2006 4:34 pm    Post subject: Forced landing in Ohio Reply with quote
Bryan....Glad you made it down OK!
Well we can't put this one down to valve guide slippage but if it was
misalignment it still points to unacceptable work by the shop that
Stratus uses to do its cylinder head work.
Of course this is conjecture based on the message below.
Sounds like you managed the situation well except it might have been
prudent to not let the altitude decay so much before wringing what power
you could out of the motor. I realise of course that engine performance
decreases with altitude but would suggest giving it all she could would
be better done at 2000 feet rather than 200. When you rebuild this
engine (or more to the point when RAM DOES ALL THE MACHINING WORK ON
YOUR REPLACEMENT ENGINE BLOCK(if that's whats required)) you will find
it's a pretty cheap engine compared to the damage that could have been
caused if your engine did not make any power at 200 feet.
When my last valve guide failure happened I was fourtunate to be able to
thrash it up to 4000 feet before I attempted to cross some very
unhospitible terrain, lakes, town etc...So I could pretty much glide to
the runway.
Bryan, if your smart there is no "probably" about send the other head to
Ram...YOU MUST send both to RAM. With respect you don't know if Stratus
uses old valves or if they are new ones. You also have no idea if the
workmanship in the other head is any better than the one that
failed...Please don't even think of running the other head without RAM's
stepped valve guide conversion, new springs and new SS valves.
Fourtunatly Once Ram has sorted the heads the motor should be very
reliable. If the bore is scored though, also have RAM rebore this (or a
another core block) because they (as far as I know) are the only ones
using a boring plate that takes account of the distortion from torquing
the heads bolts which apparently is significant.
d3dw(at)msn.com
PostPosted: Sun Apr 09, 2006 5:25 pm    Post subject: Forced landing in Ohio Reply with quote
Bryan,
Frank's advice is good.
The same thing happened to me at 4000 ft. One cylinder quit due to the spark plug gap being closed due to a blow from a chunk...of the valve guide.
MY POINT though is that I got a replacement cylinder from Mikel, free of charge, but it failed too from the same problem...loose valve guides that were inappropriately installed...with knurling just like the original failure.
I think he may use a better method now, but why take the chance. Do it right now is my advice. don walker
PostPosted: Sun Apr 09, 2006 6:45 pm    Post subject: Forced landing in Ohio Reply with quote
I believe the "better method" that Stratus uses is a circlip on a
standard sized valve guide...And that was the setup I had on my last
failure...In other words it failed just like the rest of them.
They may have upgraded their methods since my last failure but to be
quite blunt Ron Carr and I walked through the process he would use, the
parts he would supply and he is the only rebuilder I would feel
comfortable has the required level of knowledge and access to CNC
machine tools to make the required parts for a safe engine.
In the grand scheme of things the cost is peanuts compared with the
potential alternative.
Frank
1500 bucks spent on multiple cylinder head rebuilds! But I love my
engine now.
PostPosted: Sun Apr 09, 2006 6:47 pm    Post subject: Forced landing in Ohio Reply with quote
Oh incidently....I would ask RAM to proveide standard sized valves
rather than the oversize he normally does...Reason being you will want
to check your carb jet sizes, mine needed to be upsized quite a bit...If
you do have the oversized valve guides be prepared for some time to size
the carb jets (Bing has a manual on how to do it),...Someone else may
have the jet sizes they used with the RAM larger valves...Might save
some time...
Frank
larry(at)macsmachine.com
PostPosted: Mon Apr 10, 2006 5:56 am    Post subject: Forced landing in Ohio Reply with quote
Bryan,
Sorry to read of your engine problems. I've attached a record of the
jetting and setup for my Stratus with Ram
Performance heads, larger valves, springs etc. Definitely worth the
effort to have Ram do your heads.
I would disagree with Frank on the valves, because the larger valves
Ram uses are better material and the jet
sizes are known and proven for this setup. I have a 2.76 mid-range jet,
a 176 main jet, the circlip on my
jet needle (with 2 identity rings) on the third notch from the top, and
are using the original foam filters to maintain
a restricted flow of air for proper mixture and exhaust gas
temperatures. These are from 1350 to 1450 degrees.
I'm going to try a 178 main jet to reduce the full throttle EGTs by 25
to 50-degrees F. Cruise at 4600 rpm has
EGTs in level flight at about 1375-deg F.
The Ram performance heads sound a little better and needs these jets to
compensate for more airflow. The
larger valves and heavier springs, with better porting increases
performance a bit and is very worth while.
If I can be of any further assist, please just ask.
Larry McFarland
Stratus.
PostPosted: Mon Apr 10, 2006 6:17 am    Post subject: Forced landing in Ohio Reply with quote
Ya I would have to agree with this posistion Larry, as you wrote down
your jet sizes (which I should have done too save folks a bunch of work)
then the better material and proven longevity of the Ram setup makes the
larger valves worthwile...Why change a good thing even if I did not
detect any performance increase.
Incidently, even though I did not write down my jet sizes I am almost
sure I ended up with a 180 main jet so you might order two sizes while
your in the ordering mood. I found that Bing would accept returns minus
a 10% restocking fee.
Incidently....with the single valve spring it sure is nice to be able to
see all those shiny Phospher bronze guides sitting in the correct place
when one ajusts the valve clearance...Smile
Cheers
Frank
Ram uses are better material and the jet sizes are known and proven for
this setup. I have a 2.76 mid-range jet, a 176 main jet, the circlip on
my jet needle (with 2 identity rings) on the third notch from the top,
and are using the original foam filters to maintain a restricted flow of
air for proper mixture and exhaust gas temperatures. These are from
to 50-degrees F. Cruise at 4600 rpm has EGTs in level flight at about
1375-deg F.
compensate for more airflow. The larger valves and heavier springs,
with better porting increases performance a bit and is very worth while.
PostPosted: Mon Apr 10, 2006 11:34 am    Post subject: Forced landing in Ohio Reply with quote
Hey Bryan,
Out of interest, were the guides still in position and not broken...Just
wondering if the guide slipped and caused the valve to fail, maybe by
catching a chunk under the seat or between piston and valve head?
Just a thought...
Frank
waited around until noon. At that time there was a 2000
bryanmmartin
PostPosted: Mon Apr 10, 2006 11:59 am    Post subject: Forced landing in Ohio Reply with quote
The valve guides all seem to be intact and in their proper position. The
valve doesn't have any play in the guide.
Bryan Martin
on 4/10/06 3:34 PM, Hinde, Frank George (Corvallis) at frank.hinde(at)hp.com
wrote:
<frank.hinde(at)hp.com>
Hey Bryan,
Just a thought...
Frank
Bryan Martin
do not archive.
jpkarnes2000(at)msn.com
PostPosted: Mon Apr 10, 2006 12:02 pm    Post subject: Forced landing in Ohio Reply with quote
PostPosted: Mon Apr 10, 2006 12:04 pm    Post subject: Forced landing in Ohio Reply with quote
I wonder if Mykal replaced the guides or if they are the original from
Subaru...What are they made of?...Bronze or cast iron?
Frank
bryanmmartin
PostPosted: Mon Apr 10, 2006 12:11 pm    Post subject: Forced landing in Ohio Reply with quote
They appear to be bronze, they are gold colored.
Bryan Martin
do not archive.
on 4/10/06 4:03 PM, Hinde, Frank George (Corvallis) at frank.hinde(at)hp.com
Frank
Bryan Martin
do not archive.
PostPosted: Mon Apr 10, 2006 12:18 pm    Post subject: Forced landing in Ohio Reply with quote
Then they have definatly been replaced by Stratus. When you send them to
Ram, just ask him to have a quick look and tell you why he thinks the
valve might have failed, before he pops the guides out of course.
Frank
PostPosted: Mon Apr 10, 2006 6:12 pm    Post subject: Forced landing in Ohio Reply with quote
After an overheating incident in 2002 and resulting blown head gaskets, I had the engine rebuilt by Mykal. I have been flying since then with the belief that the valve guides were trustworthy since they were redone during the rebuild. After the current discussion, I have decided to not fly until the valve guides are installed by RAM. Thanks, guys, for the advice and support!=0D=0A=0D=0AJohn Karnes=0D=0AZenith 601 HDS=0D=0ASuquamish, WA
PostPosted: Mon Apr 10, 2006 8:50 pm    Post subject: Forced landing in Ohio Reply with quote
Good for you John!
One of my so called improved circlipped phospher bronze guides failed
just like the other two failures that Stratus did!
Its amazing the excuses I got as to why that happened...."You over
heated it!"...no I didn't and even if I did so what?...Guides should
still NEVER come out....You ran both ignitions at the same time and the
two ignitions interferred with each other!....Oh really?....fuzzy logic
if ever I herd it..Yeah and so what?....The Moon is made of green cheese
too but ...OH ok that was my addition.
I kid you not the first two reasons were bonafide excuses I got from
Mykal as to why it was my fault the guides fell out.
If anyone else is reading this and is still driving around the sky
without RAM heads...well you're a braver man than I am!
All of this is just my humble (not) opinion having researched and made
my own valve guides and seats for my old air cooled Norton...guides
never fell out of that motor for sure and they won't out of a RAM head
either!
Frank
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
