crankcase sealant question A-65
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
bcharvet(at)bellsouth.net
PostPosted: Tue Dec 29, 2009 7:59 pm    Post subject: crankcase sealant question A-65 Reply with quote
I'm having a hard time finding any Loctite 515, as specified in the TCM
SIL99-2B document to seal my crankcase halves (A-65). Since this is
going in a Pietenpol, I guess I don't have to use exactly what they
specify, but I was wondering what others have used with success, besides
the Permatex #3 Aviation/Loctite 515/silk thread to seal their crankcase
halves.
Ben Charvet
Mims, Fl
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
eclarsen81(at)aol.com
PostPosted: Tue Dec 29, 2009 9:05 pm    Post subject: crankcase sealant question A-65 Reply with quote
Ben,
Loctite also owns Permatex so there are a few things you can use. For
direct cross loctite 515 to Permatex's version 51531.
I like using the 518 (Permatex 51813) as it is slightly thicker and
compensates for older cases that someone used a screwdriver to separate
and heat induced case pucker between bolt holes.
Use the silk thread as well and the materials sparingly.
Since motorcycles and boat motors are assembled in similar fashion,
they all have their own "brands" as well, but I have been using the 518
successfully for many years.
Another manufacturer is Hernon and they should have a cross reference
sheet. they may be harder to come by.
A Google search will turn up supply houses for any of the above.
Good Luck on your project.
Ed
n4546v(at)mindspring.com
PostPosted: Tue Dec 29, 2009 10:56 pm    Post subject: crankcase sealant question A-65 Reply with quote
Hey Ben:
Here's a place to order if you want it:
http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=1654570&PMT4NO=76906963
We've used it lately on a O-200 and a C-145. No oil leaks and we were
advised to skip the silk thread which we did. Also used it to seal the
flange of a E-185 scavange oil pump against the accessory case. Haven't
test run yet, but we're hoping for good news.
Best Regards,
Randy, Las Vegas
dsleepy47
PostPosted: Wed Dec 30, 2009 1:45 pm    Post subject: crankcase sealant question A-65 Reply with quote
You can get Loctite 515 at McMaster Carr. Various sizes C from $5.37 for 0.2 oz tp $70 for 10.1 oz.
Deems Herring
I'm having a hard time finding any Loctite 515 C as specified in the TCM
going in a Pietenpol C I guess I don't have to use exactly what they
specify C but I was wondering what others have used with success C
besides the Permatex #3 Aviation/Loctite 515/silk thread to seal their
crankcase halves.
Ben Charvet
Mims C Fl
Hotmail: Trusted email with Microsoft’s powert/01/' target='_new'>Sign up now. [quote][b]
dsleepy47
N1491R
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
