IO-240 B1B
ftyoder(at)yoderbuilt.com
PostPosted: Sun Jan 03, 2010 4:51 pm    Post subject: IO-240 B1B Reply with quote
FYI
Upon removing my cowl, in order to change oil, I found blue fuel stain below the mechanical fuel pump.
I turned on the elect. boost pump a found fuel leaking out of the mechanical pump at the diaphragm (gasket) behind the mixture lever. I found the diaphragm to be hard and cracked. Cont. part no. 2095, I think.
I plan on replacing the gasket to confirm that was the source of the leak.
The engine was new in 95 and has 370 hrs. I would think it would last longer!
richard_trickel(at)yahoo.
PostPosted: Mon Jan 04, 2010 7:01 pm    Post subject: IO-240 B1B Reply with quote
Tim and others with the IO-240
I have been having trouble with my engine fuel system for some time.  I just cannot get it to run right, Anybody have some expert advise,
Rich
--- On Sun, 1/3/10, F. Tim Yoder <ftyoder(at)yoderbuilt.com> wrote:
Subject: IO-240 B1B
To: "OC Baker" <bakerocb(at)cox.net>, kis-list(at)matronics.com
Date: Sunday, January 3, 2010, 4:50 PM
FYI
et=_blank rel=nofollow>http://www.matronics.com/Navigator?KIS-List
