Trim servo wiring
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
Jimmy Young
PostPosted: Tue Dec 15, 2009 12:32 pm    Post subject: Trim servo wiring Reply with quote
I started building my 750 recently. I've got the Hrz Stblzr done and am about to rivet the Elevator assembly. I've installed the trim servo and cut the rod to the right length, run the wires and have the 5' wire coiled up.
I started thinking about things down the line. At some point, after the plane is completed, I'm assuming the day will come when I may need to take the tail section off for whatever reason, i.e., repainting, painting for the first time, repairs. I'm thinking that it would be a good idea to install a 5-pin connector where the 5' wire attaches to the wiring run thru the fuselage. This would make tail section removal much simpler. Is anyone else out there doing anything similar?
Jimmy Young
building N750ZX
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
Geoff Heap
PostPosted: Fri Jan 08, 2010 11:38 am    Post subject: Re: Trim servo wiring Reply with quote
Why not Jim. I'm doing it at my (701) wing roots and also at the elevator for the trim and tail light.....Geoff BTW Is it true that the 750 is like the 701 except that the plans are complete?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
