		Kelly McMullen
				 Posted: Sat Jan 16, 2010 6:44 am    Post subject: 10 SB |
				I for one am disappointed with this design. When I first saw the
 description I was hoping the hook was operated by the door handle, and
 had motion 90 degrees from what the pictures show. That would have
 been a major improvement. Unfortunately, this isn't any better than
 the solution I saw at Copperstate of installing a second handle inside
 and out, that operated a bottom of door latch.
 I'm not clear from the pictures, is the tab on the outside always
 straight out, recessed when latched? or what? I sure hope one of our
 fine CNC parts suppliers can engineer a better solution. Most of the
 ideas that put another arm on the door handle to operate some sort of
 bottom latch seem promising, perhaps difficult to make work cleanly.
 On Sat, Jan 16, 2010 at 7:26 AM, orchidman <gary(at)wingscc.com> wrote:
  sean(at)stephensville.com wrote:
 > Mailing list only members enjoy the quoted portion.  Each his own.
  But not 10 million copies of the SB from Vans. [Laughing]
  Gary Blankenbiller
  RV10 - # 40674
  (N2GB Flying)
  http://forums.matronics.com/viewtopic.php?p 81793#281793
A&P/IA, EAA Tech Counselor
KCHD |
		Jim Berry
				 Posted: Sat Jan 16, 2010 10:24 am    Post subject: Re: 10 SB |
				Kelly,
 The tab on the outside moves up and down in the slot, but does not retract at any time. The slot can be made smaller in both dimensions than as shown in Van's pictures. Mine is just big enough to get the job done.
 If you want a prettier safety latch, look at the rear door latch on the new Diamond DA40.
 Guys, the SB threads have been great. I have not seen such rancor since primer wars.
 Jim Berry
 40482
 N15JB
		luis(at)cristabelle.net Guest
				 Posted: Sat Jan 16, 2010 10:47 am    Post subject: 10 SB |
				How about VANS redesigning the door too make the doorsafer tobegin
 with.  If more doors fall off with this added latch (hypotheticaly),
 what's next more SBs andmore "add-on" hardware?  Anyone should be able
 to lock a door! Time to redesign it!
 Sent from my iPod
 On Jan 16, 2010, at 1:24 PM, "Jim Berry" <jimberry(at)qwest.net> wrote:
  Kelly,
  job done.
  since primer wars.
  Jim Berry
  40482
  N15JB
  http://forums.matronics.com/viewtopic.php?p 81813#281813
				 Posted: Sat Jan 16, 2010 11:12 am    Post subject: 10 SB |
				Luis;
 No offense but the doors are built by the builder themselves. Many have
 already made their own mods to hinges, the doors themselves, etc to the
 doors and with proper planning (confirm passengers know how to close the
 door) there really isn't an issue with the doors. The problem is the plastic
 that Vans gives as hinges are simply not the right solution, the doors
 naturally have an issue with the rear not closing correctly as the door is
 pulled from the front more than the rear.
 When you get to this point you'll know that the hinges are the first thing
 that Vans should have modified.
 Pascal
 Sent: Saturday, January 16, 2010 10:47 AM
 Subject: Re: Re: 10 SB
  How about VANS redesigning the door too make the doorsafer tobegin  with.
  If more doors fall off with this added latch (hypotheticaly),  what's next
  more SBs andmore "add-on" hardware?  Anyone should be able  to lock a
  Sent from my iPod
 > Kelly,
 > done.
 > new Diamond DA40.
 > primer wars.
 > Jim Berry
 > 40482
 > N15JB
		scottmschmidt(at)yahoo.co Guest
				 Posted: Sat Jan 16, 2010 11:32 am    Post subject: 10 SB |
				I suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com
 I have done the same and have asked Van's to retract the Service Bulletin and offer the latch as an additional and optional latch just as the indicator lights were offered.
 I want to summarize what I have heard here.
 Issues with the door will arise if:
 -Poor door construction causing a bow during flight (Construction error) (Fix: Re-build door or add Van's center latch)
 -Pins are not inserted far enough into the aluminum frame (Construction error) (Fix: Re-build pins to extend into aluminum frame)
 -Door handle interlock is not engaged (Construction error and/or pilot error) (Fix: Ensure handles are locked before flight, possible rebuild of interlock)
 -Door pins were  locked outside of cabin (Pilot error)(Fix: Add door check to checklist)
 I am fine with Van's offering this as an optional kit but when they say on the service bulletin that it is mandatory, I have a problem.
 This is 100% different from the previous SB where we added stiffeners to the vertical stabilizer and empenage.
 I want everyone to fly safe and keep our insurance as low as possible, I don't see this as the solution though.
 We need to take personal responsibility to build to the highest quality and use our checklists thoroughly.
 Any system that is put into place (such as our checklists) is never fixed with more protection devices, system only work and are improved through training and discipline.
 This solution is like adding a fixed gear to the bottom of a retractable landing gear aircraft. It will be there just in case you don't put the gear down.
 The warnings lights and center latch  should be optional as 100% safe flight can be accomplished with the stock system.  I do feel there are may pilots flying safely without even the lights because of their training and checklist discipline.  The experimental category will always have construction issues and must accept personal responsibility for that and not burden the whole fleet with the quality shortcomings of the few.
 I want everyone to fly safe, have fun and explore this world with their planes and I appreciate Van's offering a system that solves a problem that a few of RV-10's have with the doors bowing as a total replacement of the door is very expensive.
 Again, please write Van's and ask for the removal of this SB and make it optional.
 Scott Schmidtscottmschmidt(at)yahoo.com
 Sent: Sat, January 16, 2010 11:24:03 AM
 Subject: Re: 10 SB
		dlm46007(at)cox.net Guest
				 Posted: Sat Jan 16, 2010 11:39 am    Post subject: 10 SB |
				You mean you don't want a belt, suspenders, elasticized waist and special
 Velcro adhesive? I measured my pins this morning and the OD of the pins
 range from .436 to .438; theoretically they should be .4375. In 225 hours
 they may have worn 15/10000 of an inch; I probably will replace them at
 engine overhaul. Otherwise after door closure, I just touch each of them
 twice before each departure.
				 Posted: Sat Jan 16, 2010 12:10 pm    Post subject: 10 SB |
				once again Scott I agree with your suggestion. Thinking  through the letter and it will go out today, this isn't a solution it’s a  bandaid. With the negative feedback seen it is obvious most of us have no  intention of doing this mod so why force me as a builder to "have  to".
  Sent: Saturday, January 16, 2010 11:31 AM
  I  suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com (info(at)vansaircraft.com)
 To:  rv10-list(at)matronics.com
 Subject: Re: 10  SB
		bcondrey
				 Posted: Sat Jan 16, 2010 12:24 pm    Post subject: 10 SB |
				Scott,
 I’m just now catching up on this but agree with all points below and have already sent an email to Van’s.  I would also add (and did in my email) that many builders have also added door pin guides (IFLYRV10.com) which have conical receivers for the pins to address the potential issue of misalignment when the door is initially closed.  Further, these increase the surface area that the pins contact which prevents the wallowing out of the hole in the door frame that some have experienced.  Even with these guides installed though, the pins should extend through the actual door frame.
 My point was also that the SB is fine, just don’t make it mandatory.
 N442PM (flying with no door latching issues)
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
  Sent: Saturday, January 16, 2010 12:31 PM
 Scott Schmidt
				 Posted: Sat Jan 16, 2010 1:31 pm    Post subject: 10 SB |
				Pascal,
 If vans plastic hinges are crappy, vans should upgrade the part.  If
 this is a concern from the factory, then why not fix it so new
 assemblies (finish kits) reflect a safer door.  Maybe they need to
 consult with cesna on securing the doors.  Ranting here....  I don't
 know how much the builder has to create while constructing the doors.
 I'm just gathering tools right now.  But really, why not fix it from
 the getgo.
 Sent from my iPod
 On Jan 16, 2010, at 2:09 PM, "Pascal" <rv10builder(at)verizon.net> wrote:
  Luis;
  have already made their own mods to hinges, the doors themselves,
  etc to the doors and with proper planning (confirm passengers know
  how to close the door) there really isn't an issue with the doors.
  The problem is the plastic that Vans gives as hinges are simply not
  the right solution, the doors naturally have an issue with the rear
  not closing correctly as the door is pulled from the front more than
  the rear.
  thing that Vans should have modified.
  Pascal
 > <luis(at)cristabelle.net>
 > (hypotheticaly),  what's next more SBs andmore "add-on" hardware?
 > Anyone should be able  to lock a door! Time to redesign it!
 > Sent from my iPod
 >> Kelly,
 >> since primer wars.
 >> Jim Berry
 >> 40482
 >> N15JB
		ricksked(at)cox.net Guest
				 Posted: Sat Jan 16, 2010 1:46 pm    Post subject: 10 SB |
				Man do you have a lot coming!!
 Sent via BlackBerry by AT&T
		bcondrey
				 Posted: Sat Jan 16, 2010 2:01 pm    Post subject: 10 SB |
				Plastic hinges?  Parts WD-1018 & WD-1019 are steel - only part that is "plastic" are the blocks in the door for guiding the pins (C-1009 and C-1017) and the thin parts (C-1010 Cabin Pin Blocks) that cover the holes in the door frames.  FWIW, the C-1010 parts are best replaced with the aluminum guide blocks supplied by IFLYRV10.com and others.  These are supplied with bullet shaped pins that thread into the stock door pins (and the sensor magnet is built in instead of having to epoxy into the stock pin).  The opening on the guide blocks have conical openings to guide the pins into place.  This is the single best safety mod for the doors that exists.
 There's a lot of hype about the doors and while they certainly could have been designed better, they are functional as long as the builder takes the time to get the doors built properly and the latching mechanism aligned properly.  Finally, checking for doors properly latched is a standard preflight check for even most certified planes!  Granted, a Cherokee or Piper door probably won't fly off if unlatched, but that's missing my point.
 Besides, if you install the SB latch you'll have matching "fugly" with the interior door handle!
 RV-10 N442PM (flying)
				 Posted: Sat Jan 16, 2010 2:41 pm    Post subject: 10 SB |
				Yea, don't remind me.  But can't wait at the same time.  It's nice to
 see trials and tribulations.  By the time I get to the doors, it will
 be a non issue.
 Sent from my iPod
		kearney
				 Posted: Sat Jan 16, 2010 3:12 pm    Post subject: 10 SB |
 I can say with absolute certainty that a Piper door won't fly off if
 unlatched. In fact, the off field landing checklist has the door being
 unlatched and opened so it doesn't jam in case of an accident.
 There are also aftermarket interior handles that remove the "fugly" from the
 inside. After spending all this time getting Steve Deniri's billet handles
 mounted, I now am being asked to install something that looks like it was
 made by the Orcs of Mordor!
 I would prefer to pay some $$$ to get better hinges (ala Cirrus) if they
 could be made to work on a -10. Then door openings become the non event they
 should be.
 We can put all kinds of systems / proceduers etc in place but the reality is
 that the VAN's door design is sub par. Even the most disciplined military
 pilots make mistakes so why would we expect recreational GA pilots to
 achieve perfection.
  	  | Quote: | 	 		  From an esthetic point of view, I am disappointed. Surely Van's knows how
 much effort builders are putting into their planes to make them look every
 bit as polished and then some as "manufactured" a/c. Today I walked by an
 SR22 and admired how nice its doors looked. Then I winched when I realized
 that the SB has me cutting an unfinished hole into my door and then having a
 stub of aluminium poking out. This seems like a Rube Goldberg answer to a
 poor door design. At the very least they could have made a kit that gives a
 more "finished" look.
 I wish VAN's would bite the bullet and come up with a more "professional"
 looking solution that deals with the real problem - a poor locking design.
 The fact that every -10 builder (at least the ones I know of) are tossing
 the delrin door blocks in favour solid AL door guides speaks volumes.
 Just my $0.02
 Les
				 Posted: Sat Jan 16, 2010 4:03 pm    Post subject: 10 SB |
				My mistake I did mean the Cabin pin blocks. Thanks for the correction. We
 agree on every point  I replaced the pins and blocks with Steve's Aluminum
 as well.
 My point is Vans should upgrade that piece and modify the plans with some
 mods- easy ones before forcing a mandatory SB on some boat anchor concept, I
 think there are other better ways.  Write the letter Scott encourages us to
 do. Scott at Vans obviously listened to one (1) builder ask to have the SB
 plans put on the web, I think if many wrote with a request to change the SB
 Vans might very well do so. Just offer a solution- like remove mandatory as
 many have already made safety changes that do not need this SB..  replace
 cheap parts with better parts, find ways to assure the rear closes
 better..etc..
 Pascal
 From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
 Sent: Saturday, January 16, 2010 2:00 PM
 Subject: RE: Re: 10 SB
  exists.
  point.
				 Posted: Sat Jan 16, 2010 4:06 pm    Post subject: 10 SB |
				much of what you see here will be a non issue as most have better solutions
 for parts, just make sure you take notes to not buy the landing gear parts-
 specifically the front nose axles, rims.. all from Matco directly.. there's
 more but I leave that to you to discover what they are as much is being
 improved by Vans, FWF hoses being a start..
 Take your time and enjoy the journey I spent months accumulating tools
 before I ever started, took a Sportair class too.
 Pascal
 Sent: Saturday, January 16, 2010 2:40 PM
  Yea, don't remind me.  But can't wait at the same time.  It's nice to  see
  trials and tribulations.  By the time I get to the doors, it will  be a
  non issue.
  Sent from my iPod
		dmaib(at)mac.com Guest
				 Posted: Sat Jan 16, 2010 6:01 pm    Post subject: 10 SB |
				AD's for certified airplanes almost always contain language allowing
 for "alternate means of compliance" and that is just how I am
 treating this SB. I installed the iflyrv10 aluminum door pin blocks,
 increased the travel of the rods, installed the door warning system,
 and it plays beautifully through Vertical Power and gives me a master
 warning, a separate pilot or co-pilot door message, and a warning
 tone in the headsets. I consider that a robust alternate means of
 compliance and will keep the kit, and perhaps install it if I ever
 decide to sell the airplane. That's the end of the story as far as I
 am concerned.
 David Maib
 40559
 Flying
 correction. We agree on every point  I replaced the pins and blocks
 with Steve's Aluminum as well.
 some mods- easy ones before forcing a mandatory SB on some boat
 anchor concept, I think there are other better ways.  Write the
 letter Scott encourages us to do. Scott at Vans obviously listened to
 one (1) builder ask to have the SB plans put on the web, I think if
 many wrote with a request to change the SB Vans might very well do
 so. Just offer a solution- like remove mandatory as many have already
 made safety changes that do not need this SB..  replace cheap parts
 with better parts, find ways to assure the rear closes better..etc..
 Pascal
  exists.
		Tim Olson
				 Posted: Sun Jan 17, 2010 9:41 am    Post subject: 10 SB |
				I've been following the SB thread since it started, deciding not
 to get into it right away.  It seems that usually people start
 going off on tangents about how crappy the door design is, or
 how various door designs would be superior...never mind that
 without some major work/time/expense there's no real way any
 builder will have an improved door design.  The kit "is what it
 is", and if you really want the pains of major door redesign,
 then hey, I'm all for it, but I believe that when it comes right
 down to reality, most of you would rather just finally have a
 nice flying RV-10 to fly, for a reasonable price, in a minimal
 amount of years of built time.  Any departure from the plans
 usually adds time and expense, and a door redesign would involve
 both, and only lots of testing and time would end up proving
 if it were even a successful modification.
 Then it comes to handles, latches, locks, and all that stuff.
 Sure, there are some nice flush latches.  No, Van's didn't
 design in door locks.  Yeah, you can buy add-on internal
 handles.  In reality, I don't really view ANY of these things
 as significant items.  They're almost entirely cosmetic,
 and many of those cosmetics may mean something to various
 individuals, but others may not care a bit.  For me, I'm
 perfectly happy with the looks of the internal door handle.
 I don't mind the external handle, although I've seen nicer
 than mine.  And, I don't mind the door not locking.  I maintain
 that I'd much prefer a door ALARM system to a door LOCK system,
 because I just want to scare them away BEFORE they rip
 my fiberglass apart on the door, or break the plexi on
 my window.  But that again is just a personal perspective.
 None of these add-ons are really significant.
 The exception to these insignificant add-ons is the addition
 of the rivethead/iflyrv10.com door pin receivers made out
 of aluminum.  I really wish that during my build, I would
 have had the opportunity to have these, and know all the things
 we know today.  I think a new builder is crazy not to build
 those out of aluminum.  I'm not necessarily convinced that
 for someone like me, with completed doors, it's an easy
 upgrade to try to cut my pin ends and thread in the magnetic
 ones, so I haven't gone that route.  I'm also not a huge
 fan of permanent or electro magnets in the doors, as I know
 that I've heard enough about how sensitive good magnetometers
 are to know that I'd rather avoid magnets if possible.  My
 doors have glassed over screws on the outside, and I just
 haven't wanted to tackle any pin modifications right now.
 I really HAVE been meaning to order the aluminum guides
 though.  I'd love to have those, and I've lost enough to
 chipped paint and fiberglass from that rear pin.  My
 original idea was an embedded stainless striker plate to
 protect the paint, and some day I'd love to be motivated
 enough to fix that.
  From a functional standpoint I think the doors are fine.
 They work, and I've flown now over 585 hours with them and
 am not disappointed at all, other than the rear pins that
 have chipped my paint.  From a safety standpoint, I know
 my pins go THROUGH the metal door frame, and I know that
 when I latch the door all the way, it's a definite lock,
 and I can't rotate my lever at all. So once I button my
 family into the plane and inspect the door gaps, I know
 that we're not going to lose the door.
 My plane was doing it's first flight just before Van's
 came out with the door warning lights. I still have the
 bag of hardware on the bench, awaiting my installation.
 I've read Scott's comments about how EVERYONE should
 have warning lights.  I can't disagree.  I think warning
 lights are a great idea.  I also like Vic's idea of
 adding a throttle position sensor to them so that they
 don't light up when you're at low power for ground taxi...
 because you don't want to become complacent.  Personally
 though, I feel that my extra-diligent operation of the
 doors is REINFORCED by my lack of lights.  I know a lot
 about a lot of incidents that happen.  People tend to
 tell me when they hear things.  I hadn't heard about the
 recent one a couple weeks ago though.  Anyway, there have
 been enough departed doors that I share the concern deeply
 that other builders have.  But, I feel that the concern
 is not for the doors....it's for the PILOTS.  If you build
 a door per original plans, and inspect it properly before
 flight, and have pins that extend properly, you will NOT
 lose a door.  If I had lights, and started to look for
 the lights every time in lieu of a door gap inspection,
 I would become complacent and reliant on that circuitry.
 Yes, you can make those light systems pretty bulletproof,
 and perfectly aligned and activated...but you can't take
 a sloppy pilot checklist who's rushing through his preflight
 while trying to race against...well, any of the pressures
 that push us, and force him to look at the lights.  That
 is NOT to say the lights aren't a good idea.  But they
 are NOT an acceptable substitute for a good door gap
 inspection either.  We know what happens to these doors if
 they're not latched, so nothing short of a perfect
 inspection is acceptable.  If you give a perfect inspection,
 then any and all hardware additions really, truly,
 aren't necessary.  They're all band-aids against poor
 pilot awareness.  But, for the record, I do think
 the lights are a good idea. I actually have a to-do item
 on my calendar that I look at weekly, to order a door
 alarm system and once I find the right system, I plan
 to install it with the door pin sensors and lights to
 provide a loud horn alarm that I can engage with a key
 FOB, as a theft deterrent, with the side benefit of having
 door latch indicator lights.
 Now on to the new SB.  I agree, it shouldn't be mandatory.
 It would have been nice to have them engage the RV-10
 ownership for an acceptable fix,  but they didn't.  I agree
 that the latch is ugly, especially from the outside.
 I'm pretty confident that I won't be putting it in, at least
 as-delivered.  I don't want that rectangular tab outside
 and the open slot for water entry any more than many people
 do.  I don't think it's a bad idea though, either.  I think
 it's not truly a NECESSARY addition, but it is a safety
 device, and therefore it may prevent some operational issues
 that are pilot induced, so I actually support those who feel
 that it's necessary. I say GO FOR IT.  If you like that
 "feel good" addition to the door latching, great.  I agree
 that it should NOT be a mandatory SB...especially since
 there are alternate methods to accomplish the same thing that
 may actually look/work better and be far more visually
 acceptable at the same time.  Regardless, I don't think
 I plan to install that particular design as delivered.  I
 would be more inclined to perhaps leave the slot on the
 door, but NOT put the tab on the outside.  Think about this
 for a second, for all you people who want door locks....
 Envision the same mechanism, but with just the slot.
 through the slot you stick a long allen-key type key
 rod.  Inside the latch is a hole that this key fits
 in.  So, when you come up to the plane and want to
 open the door, you insert the key and tip the latch.
 What is the downside? Well, if you're unconscious
 in the plane after a crash, rescuers can't open that
 latch.  But, if they can open the door handle, do you
 REALLY think that one single latch is going to prevent
 them from getting to you, considering how weak the
 door attachment is anyway?  I highly doubt it.  A screwdriver
 jammed in the door gap so they could open it enough to
 rip the door off is about all it would take.  Yeah, maybe
 not perfect.  You don't like the idea?  I don't blame
 you....I'd rather have no center latch at all.
 Or how about this....you make the latch not just spring
 loaded, but lock-openable from the inside.  So now you
 can have the "key" function as described above, but as
 part of an emergency checklist you take the opportunity
 to disengage that lock.  Why worry about disengaging it...
 the door pins will hold the door anyway.  So you disengage
 the lock, then do your emergency landing.
 Or, take it another step further....leave an external
 operating latch mechanism, but change it to a button of
 some sort that has added mechanics to operate the latch.
 I would be much more likely to leave a button on the outside
 of my door than that square tab.
 Still, none of those ideas really turn me on.  I still
 think that a properly latched door that is diligently
 inspected, is not a worry.  My final idea is one that
 I've been bouncing around in my own head.  I picture
 attacking it from the other side...the bottom.  How about
 a door latch pin, L-shaped rod, that is built in to the
 sidewall of the airframe by your seat.  This pin can be
 manually lifted, inserting the pin through the bottom
 of the door.  To reinforce the door, you drill a hole and
 make a fiberglass hard point in the door at that spot.
 So you lift the pin, it goes into the door bottom, and
 then you fold the "L" tab of the pin to the side so it
 isn't sticking out at you....maybe even add a machined
 block into that sidewall that has 2 L-shaped recesses,
 where it can recess slightly in the locked and unlocked
 position.  Again, this latch is only activated from inside
 the cockpit, preventing rescuers from unlocking that
 lock....but again, I'm SURE you could kick that door out
 if that were the only pin, and I'm SURE that they could
 rip it off from the outside if they needed to....and
 that's in the much smaller chance that you have an
 actual survivable crash....the chances are higher that
 you'll be a sloppy pilot and lose the door.  But, during
 any portion of flight where you worry about off-airport
 landings... (for instance, as I'm flying over water,
 enroute to the Bahamas), you just pull that pin to the
 un-latched position. You don't NEED that latch to be
 secured, if the rest of the door is secured.  In fact,
 if you just TESTED that latch before flight, it would
 PROVE your pins are secured on the door sides, and you
 probably don't even need to leave the door center latch
 in place.  But, if you can JUST remember that this latch
 is something you need to open before an emergency landing,
 then it would be a fine method of compliance, and I
 bet you could hide it visually better than most other
 method.
 I've also liked Seano's mechanical methods of adding a
 3rd pin, operated by the latch.  For people just starting
 the build, I would actually think that if this issue
 is one you're passionate about, then THAT is probably your
 BEST way to deal with it. I'd LOVE to have that option
 be one that an already built-and-painted door could have
 added, but I doubt that's possible.  I'm not obviously
 passionate enough about it to rip open my door and build
 such a thing, but for a new builder, hey, get him to
 give you the drawings and spend some time on it...you
 can avoid this ugly-a$$ latch that the SB calls for if you
 do.
 So the door stuff is an argument I really don't care to dive
 in too deeply to.  I think it all comes down to the pilot.
 I think there are many good ways to prevent the problem
 even with a stupid pilot.  But to date, I'm not finding
 any good ways to really fix the issue mechanically, in an
 ideal way, on an already painted RV-10....so, I maintain
 my added diligence.  I have no big worries. I have 585
 happy hours with the design as it is now.  Can it be done
 better? Sure.  If I were building my doors today, would
 I do it better? SURE!  Is the difference in comfort level
 worth me tearing it all apart now?  Nope.  I just want
 to end up with those aluminum guides, and an alarm
 system some day, and I'll be plenty satisfied.  If I
 add a 3rd pin now, it'll probably be through the bottom,
 as I described.
 Oh, and don't worry too much about me selling my plane
 and having to implement the SB per plans...I don't plan
 on selling.
 Tim Olson - RV-10 N104CD
				 Posted: Sun Jan 17, 2010 11:51 am    Post subject: 10 SB |
				Tim, I have been thinking the exact same thing about a latch in the center that can only be engaged from inside the cockpit.
 It would still require a high level of checklist discipline.  I agree with you on the lock, if they want in, they will get in.
 I find that a cover is plenty good (out of sight out of mind) and if I ever go to Mexico or the Baja my plan is to just take off the outside door handles.
 I am getting the sense that this SB is a CYA for Van's more than anything from some of the comments here, VAF and personal e-mails.
 Again, that is disappointing to me.  From a great solution standpoint on a scale from 1-10 I give this solution a 1 or 2.
 Oh well, I think a 10 can be achieved for the same cost as the proposed.
 All I would hope  for is the verbiage on the SB to change from:
 Required Action: Install Door Safety Latch   to   Required Action: Optional Door Safety Latch
 Time of Compliance: Before Further Flight     to   Time of Compliance:  Optional
 I do believe some great ideas and great solutions will and are coming out of this so this probably I won't take up any more of my time and I will start coming up with some ideas that we all can share.  There are a ton of super smart and talented people on this list.
 I just can't wait to see what comes out of Goeff's camp.  I am expecting a voice activited with a thumb print sensor.  And from Tim I am looking for an iPhone app that both opens and closes the doors and has a built in "Door Ajar" alarm that is displayed on the iPhone screen.
 N104XP
 675 Safe Hours
 Sent: Sun, January 17, 2010 10:39:47 AM
  --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
 enough to fix that.
 method.
 do.
 better?
				 Posted: Sun Jan 17, 2010 1:03 pm    Post subject: 10 SB |
				I just realized that Van's has a "Letters and Notices" section which is where the RV-10 door indicator lights are.
 This is where this center latch belongs. That would move it completely out of the SB section.
 http://www.vansaircraft.com/public/notices.htm
 Sent: Sun, January 17, 2010 12:49:41 PM
 N104XP
 675 Safe Hours
 enough to fix that.
 method.
 do.
 better?
		gengrumpy(at)aol.com Guest
				 Posted: Sun Jan 17, 2010 1:30 pm    Post subject: 10 SB |
				I have just written Van's to support Scott's suggestion.
 Remember that SBs are optional in the FAA's eyes, not mandatory.
 And a previous post on keeping this in our hands rather than letting some insurance adjuster get their hand in the mix is good advice.
 I'm waiting for a more elegant solution for retrofit from some of our excellent CNC engineers!!
 grumpy
 On Jan 16, 2010, at 1:31 PM, Scott Schmidt wrote:
  	  | Quote: | 	 		  I suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com (info(at)vansaircraft.com)
 Scott Schmidtscottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
 From: Jim Berry <jimberry(at)qwest.net (jimberry(at)qwest.net)>
 Subject: Re: 10 SB
 tp://www.matronics.com/Navigator?RV10-List
 nics.com
 w.matronics.com/contribution
 =  [quote][b]
