MurphyMoose-List Digest: 6 Msgs - 01/13/10
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
jwill3638(at)aol.com
PostPosted: Sat Jan 16, 2010 6:44 am    Post subject: MurphyMoose-List Digest: 6 Msgs - 01/13/10 Reply with quote
Hello George, I'm going to take your advice and install a fuel return line. I don't have a filter between the mechanical pump and the carb. Its a straight line. Should I attach the return line before the mechanical pump or after it? I use two facet pumps, one from each fuel tank to keep positive pressure to the mechanical pump. Jim Williams
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
evanfisk(at)shaw.ca
PostPosted: Mon Jan 18, 2010 10:25 am    Post subject: MurphyMoose-List Digest: 6 Msgs - 01/13/10 Reply with quote
my moose fuel tanks have 4 fittings on the root ribs. 2 smaller ones up front for fuel
site gauge and cross venting.
there's a larger one mid tank along bottom edge and a similar sized one near trainilg edge
just fore of the flap hinge attach bracket.
Plan to install finger strainers and main fuel line to this second most rearward fitting.
anybody know what the mid tank fitting is used for?
evan fisk
Moose sr 282
winnipeg
westcoastkitplanes(at)gma
PostPosted: Mon Jan 18, 2010 10:46 am    Post subject: MurphyMoose-List Digest: 6 Msgs - 01/13/10 Reply with quote
Evan,
I've never seen 4 fittings on the Root Rib, usually just 3 on the vertical side of the root rib and 1 other fitting (water drain) on the under side.  Is this what you have? If not, can you provide a picture and I should be able to make some sense out of it for you.
Cheers,
Jeff
On Mon, Jan 18, 2010 at 10:23 AM, e fisk <evanfisk(at)shaw.ca (evanfisk(at)shaw.ca)> wrote:
[quote] my moose fuel tanks have 4 fittings on the root ribs. 2 smaller ones up front for fuel
evan fisk
Moose  sr 282
winnipeg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
