How often do you rebuild your Mikuni Fuel pump?
donaho1(at)verizon.net
PostPosted: Tue Jan 19, 2010 1:32 pm    Post subject: How often do you rebuild your Mikuni Fuel pump? Reply with quote
Hi All, When I flew the Quicksilver MX, I had an in flight fuel pump
failure. The MX used the Mikuni, rectangular pump. After that failure, I
started rebuilding it every other flying season. The little flapper valves
always looked wrinkled and in need of replacement. When I built the
Firestar II it called for the dual round Mikuni pump. I continued with my
bi-annual fuel pump rebuild, however, the parts I replaced always looked
like new. I am thinking a rebuild every other year is overkill. Any
thoughts before I order a rebuild kit? Thanks in advance. Lanny
PostPosted: Tue Jan 19, 2010 8:29 pm    Post subject: How often do you rebuild your Mikuni Fuel pump? Reply with quote
Lanny/Gang:
I guess you could stretch it to three years if two years is an overkill.
Let us know if you have a fuel pump failure between two and three years.
Wink
Ralph B
PostPosted: Wed Jan 20, 2010 10:55 am    Post subject: Re: How often do you rebuild your Mikuni Fuel pump? Reply with quote
I have gone over 7 years without a pump replacement (rectangular). They are reliable and this is a good thing. During the last 3 years, I switched to a round Mikuni dual pump and tied the output lines together. I don't have any plans to change it.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
mark.shimei(at)gmail.com
PostPosted: Fri Jan 22, 2010 9:50 am    Post subject: How often do you rebuild your Mikuni Fuel pump? Reply with quote
I had one in a Phantom for 7 years...260 hrs never touched it...but that should not be a benchmark for your re-build time.
Mark...Ultrastar with 60hrs and counting
Lanny/Gang:
Wink
